[Plugin] Extrude Edges By Offset v1.0 20110525
Postby TIG » Thu May 26, 2011 3:19 pm
You can download it as part of the zipped set of 'Extrusion Tools' from here http://forums.sketchucation.com/viewtop ... 63#p217663
Copyright 2011 (c) TIG
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
extrudeEdgesByOffset.rb
Usage:
Select two or more Edges, Curves etc to be Offset.
Anything else in the Selection, such as Faces, will be ignored.
The selected edges must be 'coplanar' and should be 'connected' and not
'branching' - otherwise the tool might stop, or unexpected offset results
can occur.
Run the Tool from Plugins > 'Extrude Edges by Offset'.
or click on 'Extrude Edges by Offset' in the 'Extrusion Tools' Toolbar.
[Activate this Toolbar from View > Toolbars if it's not loaded]
If there are < 2 edges or they are not coplanar then a dialog warns and
the tool stops.
A dialog opens, enter the required offset distance in current units or
other units with a units suffix - e.g. if you are working in 'mm'
entering 100 offsets 100mm but entering 4" would offset 4" [101.6mm].
OK to continue, Cancel to stop tool.
Entering a -ve value offsets 'inwards' rather than the default 'outwards'
Note that you cannot enter 0 as the value - you are warned and the dialog
reopens so you can retry, entering 0 again [or Cancel] stops the tool.
The offset entered is remembered across tool uses in the same session.
The selected edges are replicated inside a group and offset by the
desired distance. A loop of edges creates an offset 'doughtnut' form;
a set of edges with open edges is finished with two 'square' ends.
Faces are added to these edges and subdivision coplanar edges are added
across each pair of vertices. You are prompted Yes|No to reverse the
faces [the default is 'up'], then to erase the coplanar edges and finally
to explode the group so that the new geometry merges back into the
active_entities' geometry.
Donations:
Are welcome by PayPal to info @ revitrev.org.
Version:
1.0 20110525 First release.
User avatar
Global Moderator
Re: [Plugin] Extrude Edges By Offset v1.0 20110525
Postby SketchUpNoobie » Thu May 26, 2011 3:51 pm
:sketchstatic:
You're on a roll TIG! Thanks a bunch for these awesome tools. ;) I'll have to try this out this afternoon.
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Postby srx » Thu May 26, 2011 4:20 pm
:D Thank you again!
www.saurus.rs
User avatar
srx
Postby Rich O Brien » Thu May 26, 2011 4:21 pm
Miracles take a day. I'll make a note of that!
Thanks TIG
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Pixero » Thu May 26, 2011 4:48 pm
Thanks.
User avatar
Pixero
Postby pilou » Thu May 26, 2011 6:28 pm
You do it! Bravo!
:fro:
I am anxious to see if repetition is inside :enlight:
Ah there is not! :mrgreen:
Next selection should be the new external result!
And a "Do you want Enter a new Distance if not Satisfy" will be also cool :thumb:
Because result is not always predictable :roll:
This tool + Extrude Edges along a vector = a mega super tool :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby EarthMover » Thu May 26, 2011 7:03 pm
:sketchstatic: :sketchstatic: Woo-hoo! Can't tell you how many times I've wished for this!!!! TIG you are the MAN!
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby pilou » Thu May 26, 2011 8:03 pm
And if after the first selection you can just move the mouse against enter a value
and repeat at the end of the process that will be a task! :enlight:
Left click + Move = Offset, Right click = extrusion ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby Jean-Luc Clauss » Thu May 26, 2011 10:38 pm
Very nice plugin TIG. Thank you so much.
Auteur de guides et de mémos sur SketchUp aux éditions ENI
http://archi-com21.blogspot.fr/
Jean-Luc Clauss
Postby pilou » Fri May 27, 2011 9:44 am
And also because the CTRL + Z lost the first selection! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby numerobis » Fri May 27, 2011 9:45 pm
WOW! very cool! Thank You!!! 8-)
numerobis
Postby pilou » Sat May 28, 2011 11:11 am
if possible
Mouse + click down pressed without release = Offset ,
mouse x y without click down pressed without release = extrude along vector :)
Speedy Galerie
User avatar
Top SketchUcator
Postby shoeb_cars » Sat May 28, 2011 2:36 pm
:bounce: amazing how you do it....i always think n thank u for making such amazing tools whenever i rescued by your tools
respect ++
shoeb_cars
Postby rv1974 » Sat May 28, 2011 3:21 pm
Ofsetting.. Outstanding
Bravo!
rv1974
Postby james123 » Wed Sep 14, 2011 9:33 am
Thank You....
james123
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: popcornpa and 14 guests
Visit our sponsors:
