You can download it as part of the zipped set of 'Extrusion Tools' from here http://forums.sketchucation.com/viewtop ... 63#p217663
Copyright 2011 (c) TIG
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
extrudeEdgesByOffset.rb
Usage:
Select two or more Edges, Curves etc to be Offset.
Anything else in the Selection, such as Faces, will be ignored.
The selected edges must be 'coplanar' and should be 'connected' and not
'branching' - otherwise the tool might stop, or unexpected offset results
can occur.
Run the Tool from Plugins > 'Extrude Edges by Offset'.
or click on 'Extrude Edges by Offset' in the 'Extrusion Tools' Toolbar.
[Activate this Toolbar from View > Toolbars if it's not loaded]
If there are < 2 edges or they are not coplanar then a dialog warns and
the tool stops.
A dialog opens, enter the required offset distance in current units or
other units with a units suffix - e.g. if you are working in 'mm'
entering 100 offsets 100mm but entering 4" would offset 4" [101.6mm].
OK to continue, Cancel to stop tool.
Entering a -ve value offsets 'inwards' rather than the default 'outwards'
Note that you cannot enter 0 as the value - you are warned and the dialog
reopens so you can retry, entering 0 again [or Cancel] stops the tool.
The offset entered is remembered across tool uses in the same session.
The selected edges are replicated inside a group and offset by the
desired distance. A loop of edges creates an offset 'doughtnut' form;
a set of edges with open edges is finished with two 'square' ends.
Faces are added to these edges and subdivision coplanar edges are added
across each pair of vertices. You are prompted Yes|No to reverse the
faces [the default is 'up'], then to erase the coplanar edges and finally
to explode the group so that the new geometry merges back into the
active_entities' geometry.
Donations:
Are welcome by PayPal to info @ revitrev.org.
Version:
1.0 20110525 First release.
[Plugin] Extrude Edges By Offset v1.0 20110525
• Page 1 of 1
Re: [Plugin] Extrude Edges By Offset v1.0 20110525![]() You're on a roll TIG! Thanks a bunch for these awesome tools. ![]() --
SketchUpNoobie: the complete noob in all things SketchUp. Re: [Plugin] Extrude Edges By Offset v1.0 20110525Miracles take a day. I'll make a note of that!
Thanks TIG There's a frontroom and a backroom....reverse faces
Re: [Plugin] Extrude Edges By Offset v1.0 20110525You do it! Bravo! ![]() I am anxious to see if repetition is inside ![]() Ah there is not! ![]() Next selection should be the new external result! And a "Do you want Enter a new Distance if not Satisfy" will be also cool ![]() Because result is not always predictable ![]() This tool + Extrude Edges along a vector = a mega super tool ![]()
Re: [Plugin] Extrude Edges By Offset v1.0 20110525![]() ![]() 3D Artist at Clearstory 3D Imaging
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: [Plugin] Extrude Edges By Offset v1.0 20110525And if after the first selection you can just move the mouse against enter a value
and repeat at the end of the process that will be a task! ![]() Left click + Move = Offset, Right click = extrusion ![]()
Re: [Plugin] Extrude Edges By Offset v1.0 20110525Very nice plugin TIG. Thank you so much.
Auteur de guides et de mémos sur SketchUp aux éditions ENI
http://archi-com21.blogspot.fr/ Re: [Plugin] Extrude Edges By Offset v1.0 20110525
And also because the CTRL + Z lost the first selection! ![]()
Re: [Plugin] Extrude Edges By Offset v1.0 20110525if possible
Mouse + click down pressed without release = Offset , mouse x y without click down pressed without release = extrude along vector ![]()
Re: [Plugin] Extrude Edges By Offset v1.0 20110525![]() respect ++ Re: [Plugin] Extrude Edges By Offset v1.0 20110525Ofsetting.. Outstanding
Bravo! Last edited by rv1974 on Sun May 29, 2011 5:48 am, edited 1 time in total.
• Page 1 of 1
Who is online
Users browsing this forum: GMDATS and 9 guests
