[Plugin] Contour Lines (Didier Bur)
Postby charly2008 » Wed May 25, 2011 5:50 pm
So far I've used this plugin only for terrains. One can also use it for the even division of geometric bodies or faces. I've only just found out by chance.
Charly
3
User avatar
charly2008
Re: [Plugin] Contour Lines (Didier Bur)
Postby pilou » Wed May 25, 2011 5:56 pm
Better if you give the address of the plug: contour lines :enlight:
It was not on the list ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby charly2008 » Wed May 25, 2011 6:10 pm
Hi Pilou,
I checked again and found also a similar plugin "Contour Maker" from TIG. Here are both links:
http://rhin.crai.archi.fr/rld/plugin_details.php?id=83
http://rhin.crai.archi.fr/rld/plugin_details.php?id=82
Charly
User avatar
charly2008
Postby pilou » Wed May 25, 2011 6:11 pm
Funny plugs indeed :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby 66searcher » Mon Jun 13, 2011 8:30 pm
charly2008 wrote:Hi Pilou,
Charly
what's the differences between these plugins?
http://hamidtoliat.deviantart.com/
User avatar
66searcher
Postby TIG » Mon Jun 13, 2011 8:32 pm
Charly
Of course mine is better :shock:
Test both they are slightly different ;)
User avatar
Global Moderator
Postby fossa » Mon Jun 13, 2011 10:29 pm
What plugin did you use to do the piping on the pyramid?
fossa
Postby charly2008 » Mon Jun 13, 2011 11:18 pm
Hi Fossa,
there are also some slightly different tools.
Charly
User avatar
charly2008
Postby fossa » Tue Jun 14, 2011 12:19 am
Thanks. I'll look into those. Been needing a good pipe tool. Sketchup work around here is slow so it just wasn't on the top of the list.
fossa
Postby Ben Ritter » Wed Feb 08, 2012 8:59 pm
I've recently tried this ruby script and it doesn't create any contour lines. Does the surface have to be a group or individual faces? I've tried both, without any success.
Ben
Ben Ritter
Postby 3eighty » Wed Feb 08, 2012 9:59 pm
Just wanted to say the Ruby Plug=in Library is a very nice thought out and designed site..So simple to use...Thank You..
3eighty
Postby Didier Bur » Thu Feb 09, 2012 12:51 pm
You can select individual faces in the model space or individual faces in the context of a group (but not the entire group itself)
Please post here what the Ruby console says when using the tool.
Regards,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: dearfun, munra1974 and 33 guests
Visit our sponsors:
