[Plugin] Contour Lines (Didier Bur)
Postby charly2008 » Wed May 25, 2011 5:50 pm
So far I've used this plugin only for terrains. One can also use it for the even division of geometric bodies or faces. I've only just found out by chance.
Charly
3
User avatar
charly2008
Re: [Plugin] Contour Lines (Didier Bur)
Postby pilou » Wed May 25, 2011 5:56 pm
Better if you give the address of the plug: contour lines :enlight:
It was not on the list ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby charly2008 » Wed May 25, 2011 6:10 pm
Hi Pilou,
I checked again and found also a similar plugin "Contour Maker" from TIG. Here are both links:
http://rhin.crai.archi.fr/rld/plugin_details.php?id=83
http://rhin.crai.archi.fr/rld/plugin_details.php?id=82
Charly
User avatar
charly2008
Postby pilou » Wed May 25, 2011 6:11 pm
Funny plugs indeed :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby 66searcher » Mon Jun 13, 2011 8:30 pm
charly2008 wrote:Hi Pilou,
Charly
what's the differences between these plugins?
http://hamidtoliat.deviantart.com/
User avatar
66searcher
Postby TIG » Mon Jun 13, 2011 8:32 pm
Charly
Of course mine is better :shock:
Test both they are slightly different ;)
User avatar
Global Moderator
Postby fossa » Mon Jun 13, 2011 10:29 pm
What plugin did you use to do the piping on the pyramid?
fossa
Postby charly2008 » Mon Jun 13, 2011 11:18 pm
Hi Fossa,
there are also some slightly different tools.
Charly
User avatar
charly2008
Postby fossa » Tue Jun 14, 2011 12:19 am
Thanks. I'll look into those. Been needing a good pipe tool. Sketchup work around here is slow so it just wasn't on the top of the list.
fossa
Postby Ben Ritter » Wed Feb 08, 2012 8:59 pm
I've recently tried this ruby script and it doesn't create any contour lines. Does the surface have to be a group or individual faces? I've tried both, without any success.
Ben
Ben Ritter
Postby 3eighty » Wed Feb 08, 2012 9:59 pm
Just wanted to say the Ruby Plug=in Library is a very nice thought out and designed site..So simple to use...Thank You..
3eighty
Postby Didier Bur » Thu Feb 09, 2012 12:51 pm
You can select individual faces in the model space or individual faces in the context of a group (but not the entire group itself)
Please post here what the Ruby console says when using the tool.
Regards,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: MrZiMCo and 15 guests
Visit our sponsors:
