this is some of my works
Re: this is some of my worksand more...
Manta - high-speed underwater vehicle with minimal noise, which is achieved by a water-powered engines. Equipped with 10 torpedo room with Tomahawk missiles, 4 triggers to engage aerial targets, and 2 torpedo bays for hitting flooded and underwater targets. Also there are 2 large caliber guns, and 20 medium-range missiles. Because of its stealth, speed and mobility, this submarine is designed to swim undetected behind enemy lines to gather information or precise destruction of the enemy. (logo mine to) Last edited by cj_sniper on Mon May 23, 2011 3:16 pm, edited 2 times in total.
Re: this is some of my worksLast edited by cj_sniper on Fri Jun 03, 2011 12:31 am, edited 1 time in total.
Re: this is some of my worksexcellent simple shapes cj_sniper !!
your renders are very coloured , but I like them . Good style
Re: this is some of my worksbig big thanks
Re: this is some of my worksChairs for hacienda. Purpose - kitsch, show off and do not like at all, but the convenience of sitting (not lying) to read books and support the back. Approved the spiral arms of (this office has in mind), the material of manufacture: steel plates laminated with warm (Matt) textured plastic, chrome side profiles (green and yellow on the meadow at a verandah color) + Covers with pillows under the fifth point))
Re: this is some of my worksFun stuff!
Re: this is some of my workstoys for children from 1 to 4 years PLANETARY RIDER
child are thrown on the car, parents control the movement of the machine, you can switch on the steering wheel driving a car
Re: this is some of my worksLast edited by cj_sniper on Wed Jun 01, 2011 9:59 pm, edited 1 time in total.
Re: this is some of my worksSome are really really very nice !! Congratulations
doing technical engineering on SketchUp ... without plugins
Re: this is some of my worksStilTeg - thanks
Re: this is some of my worksVery refreshings models!
Re: this is some of my worksthanks
Re: this is some of my worksLED Lamp "Flower Power", the lamp not only change the brightness but also hide behind the petals ... lamp equipped with a clock, alarm and has 3 modes:
1) Manual (adjust themselves what light you need and enable, disable) manipulations performed by touching the touch-mound at the base of the lamp, 2) automatic time (ask what time the lamp is switched on and off in what, as well as the intensity of light) button on the left of the clock 3) Automatic on sensitivity (the base is a light sensor, if the lamp goes dark, the darker the brighter the lamp lights and acc. vice-versa) button on the left of the clock
Re: this is some of my worksHere are a couple of robot (complete sets of furniture, "Hills" was made of 10 pieces, after the crisis ceased to be ordered, as expensive in production)
Roulette "WilderWestern"(to make when he was the height of the gambling business in Ukraine for a chain of casinos, only 5 tables were produced
Re: this is some of my worksLED Park Lamp "Lily"
completely autonomous because powered by solar elements, the body is made of fiberglass, painted in green color is not obtrusive than it does not emit light from the composition of the park, ceiling made of reinforced plastic, inside a LED elements Rod with a metal frame. Lamp height (an element) 3,5 m and 1,1 m. rod removal Destination: lighting fittings, sidewalks, pedestrian zones.
Re: this is some of my works"Jerboa"
the vehicle for movement on Mars Please, register (free) to access all the attachments on the forums.
Re: this is some of my worksJerrycans? What fuel does that Mars vehicle use?
Seriously, interesting concept. Looks like you have paid more attention to curved parts - they look quite segmented on your previous models. Comfortably numb...
Re: this is some of my worksin cans no fuel (fuel - nuclear generator) in their water! Something without which it simply can not survive on Mars (and elsewhere)
Re: this is some of my worksThe rover "TUSHKAN"
Fuel: in the back of the rover is electric generator at a nuclear fuel, the rotation of the wheels is a chain mechanism with independent motors. Type the passengers: the rover descends to a height of 50 cm between the hull and the surface of B, then the door gets up and moves forward allowing access to passengers and the driver to board the transport "A". Features: transport has 4 legs (each of which can be operated independently, which allows him to overcome even the steepest mountain surface) radius of the variability of foot 80 degrees "C". Wheels with tires of low pressure for maximum grip with the ground, equipped with spiked steel inserts. Changing the wheels is made in 3 steps: prepare a spare tire and lift the injured leg of transport, unhook the damaged wheel (turning off the hydraulic lock in the mechanism near the wheels), insert a spare tire in the grooves and re-enable the hydraulic clamps (mounting), thereby fixing the wheel. The wheels have ball bearings at the bottom of the foot, which adds increased maneuverability. Transportation is also equipped with two 40 liter jerry cans with water (so to speak NC) Designed for movement on the surface of Mars during its colonization (or rather for the mountain and crater surfaces), requires the presence of gravity)). Used as a scout the territory. Please, register (free) to access all the attachments on the forums.
Re: this is some of my worksAaah..water jerrycans. Hope they´re properly insulated
Very imaginative work! Comfortably numb...
Re: this is some of my worksNice concepts you got there...keep it up..
Re: this is some of my worksa couple of my works
toy cars Please, register (free) to access all the attachments on the forums.
Re: this is some of my worksmoonwalker for tourists "crater Turtle"
panoramic roof and sides - for better viewing Please, register (free) to access all the attachments on the forums.
Re: this is some of my worksand again retro inspiration
SketchUcation One-Liner AdvertsNeed Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
