[Plugin] Pen Tool +
[Plugin] Pen Tool +
Postby Rich O Brien » Wed May 18, 2011 12:27 pm
Pen Tool +
NOTE: If upgrading from 1.5 then please delete the Pen Tool+.rb file and rob_hsltool folder from your plugins folder.
Overview:
To help when manually stitching softened meshes
To quickly creates curves with lines
To sketch guide lines, points
To create lines with or without faces
Description:
Similar to native Line Tool in use but has 7 primary features :-
    [1] Soft Draw allows the sketching of softened/smoothened lines (Hidden Geometry On)
    [2] Hide Draw allows the sketching of hidden lines (Hidden Geometry On)
    [3] Guide Draw allows the sketching of guide lines
    [4] Weld Draw allows the sketching of curves
    [5] Edge Draw allows the sketching of edges [lines] without making faces
    [6] Line Draw allows the sketching of edges with faces
    [7] Point Draw allows the sketching of construction points
Usage:
Run via 'Draw' menu or via the 'Pen Tool +' toolbar
Requirements:
Tested on SU8+ only (PC)
Installation:
Please get the latest version from the SketchUcation PluginStore
Download
NOTE: If upgrading from 1.5 please delete the Pen Tool+.rb file and rob_hsltool folder from your plugins folder.
Version 1.1
- VCB Fix
- Edge Draw added
Version 1.2
- Group/Component bug fixed
- Midpoint 'jumping' on intersection' fixed
Version 1.3
- Weld bug addressed (don't click too fast when using Weld Draw mode)
Version 1.4
- Line Draw and Point Draw added
Version 1.5
- Clash addressed
Version 1.6.0
- Added Extension compatibility and custom folder goodness
Version 1.7.0
- Fix glitch with 'langhandler' which meant that in newer SketchUp versions lines always started at the origin, and some tools failed completely. [TIG]
Many thanks goes to TIG for helping me out with this tool.
4
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Re: [Plugin] Pen Tool + 1.0 (18/5/2011)
Postby boofredlay » Wed May 18, 2011 12:36 pm
Nice. I especially like the Weld Draw. :thumb:
User avatar
boofredlay
Global Moderator
Postby Rich O Brien » Wed May 18, 2011 12:38 pm
It can be a bit funky but that's part of it's charm ;)
User avatar
Rich O Brien
Administrator
Postby boofredlay » Wed May 18, 2011 12:45 pm
Funky already :D
I am getting artifacts with the Weld Line. See image.
Also when you close a loop with the weld line then push/pull the face the edges created by the operation are not all soften/smoothed.
I am running a PC with Windows 7.
Great start however.
I will be out the rest of the day so I won't be able to respond for a while.
User avatar
boofredlay
Global Moderator
Postby thomthom » Wed May 18, 2011 12:50 pm
Well well well - Rich is becoming a scripting monkey. :D
I'll congratulate you by making a feature request: ;)
Tool that draws normal Edge.
The difference from the native Edge Tool: Doesn't auto generate faces. It can be bloody annoying at time that SketchUp keeps trying to generate faces for each edge created.
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Wed May 18, 2011 12:53 pm
I wanna live the rock'n'roll life you enjoy
User avatar
Rich O Brien
Administrator
Postby mitcorb » Wed May 18, 2011 1:39 pm
Congratulations, Rich.
User avatar
mitcorb
Top SketchUcator
Postby SketchUpNoobie » Wed May 18, 2011 1:47 pm
Useful tool Rich. :thumb:
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Postby Dave R » Wed May 18, 2011 1:49 pm
Good start Rich. You'll need to get some shades like ThomThom has. :D
So now the requests begin. If you enter a length for the line in the VCB, the line is drawn but the tool continues from the start point rather than the end. Is it possible to fix that so it behaves like the native Line tool? And you only get one shot at entering the length of the line so if you change your mind or make an error when typing the length, you have to Undo and start over. Can that be fixed to operate like the native Line tool? Maybe both things go hand in hand?
User avatar
Global Moderator
Postby Rich O Brien » Wed May 18, 2011 2:10 pm
what shades?
Yes, feel free to do so
Like peanuts and gum Dave
User avatar
Rich O Brien
Administrator
Postby Dave R » Wed May 18, 2011 2:24 pm
what shades?
Those things over his eyes. What are those things anyway?
User avatar
Global Moderator
Postby Rich O Brien » Wed May 18, 2011 2:26 pm
Eyebrows?
There's a fix coming on the VCB issue and an extra Edge Draw mode that doesn't create faces
User avatar
Rich O Brien
Administrator
Postby jason_maranto » Wed May 18, 2011 2:28 pm
Very cool idea -- thank-you! :enlight:
Best,
Jason.
User avatar
jason_maranto
Re: [Plugin] Pen Tool + 1.1 (18/5/2011)
Postby Rich O Brien » Wed May 18, 2011 3:32 pm
Little update with Thom's and Dave's suggestions [not Eric's :? ]
User avatar
Rich O Brien
Administrator
Postby Gaieus » Wed May 18, 2011 3:39 pm
Well, Rich, congrats, really. I remember when Remus also wrote a plugin - now "non-scripters" are slowly becoming a minority here... :roll:
I remember a wise man once answering this question:
Q wrote:Do you build or have you built any SketchUp Ruby Scripts?
like this...
A wrote:There are so many talented and generous ruby scripters out there that it would be a waste of resources to start playing with it and keep hindering them in their work with my basic questions...
And sorry for not having been able to me of more help - I have just come back home.
Nice icons, too!
User avatar
Postby Rich O Brien » Wed May 18, 2011 3:47 pm
Thanks Csaba, there are still some little gremlins [not Mike] to iron out
User avatar
Rich O Brien
Administrator
Postby Dave R » Wed May 18, 2011 3:50 pm
Thanks Rich.
Out of curiosity, is this what I should see when I open the ZIP file?
User avatar
Global Moderator
Postby Rich O Brien » Wed May 18, 2011 3:58 pm
try again
User avatar
Rich O Brien
Administrator
Postby Dave R » Wed May 18, 2011 4:03 pm
Cool! 8-)
User avatar
Global Moderator
Postby hebeijianke » Wed May 18, 2011 4:04 pm
Rich O'Brien wrote:try again
There something wrong
hebeijianke
Postby Rich O Brien » Wed May 18, 2011 4:10 pm
Bit more info?
User avatar
Rich O Brien
Administrator
Postby ken » Wed May 18, 2011 4:20 pm
I use rollers, wheels and axles that I wish to add a guidelines though the center for alignment that will be part of the group. It would be nice, if I could draw a guideline between two points, maybe only 12" apart, and have the guide line that is drawn be the size as indicated in the measurement tool bar. So if I wanted to add a guideline to a wheel that is only 12" wide, however, I wish to have the alignment guideline to be 10' long, I could enter the 10' into the measurement tool bar, draw the line between the two center points that are only 12" apart, and have the guideline be drawn 10' long.
So thank you for you plugin.
Ken
OOPS. Didn't see that I could add the length to the guidelines in the VCB. My bad. So disregard the above.
User avatar
ken
Premium Member
Premium Member
Postby hebeijianke » Wed May 18, 2011 4:22 pm
Rich O'Brien wrote:Bit more info?
Weld Draw is not work well
hebeijianke
Postby Dave R » Wed May 18, 2011 4:41 pm
Weld Draw is working fine for me. It all works fine except my second request. But, beggars can't be choosers so I'm not complaining.
User avatar
Global Moderator
Re: [Plugin] Pen Tool + 1.2 (18/5/2011)
Postby Rich O Brien » Wed May 18, 2011 5:00 pm
Version 1.2 (remove old before installing)
thanks to TIG for tweaking again for squashing some bugs.
See first post for latest.
User avatar
Rich O Brien
Administrator
Postby Dave R » Wed May 18, 2011 5:10 pm
Now Weld Draw doesn't seem to draw welded edges.
Soft Draw will convert unsoftened edges to softened but doesn't draw softened wedges from the start.
User avatar
Global Moderator
Postby Rich O Brien » Wed May 18, 2011 5:15 pm
It seems it's only welding when aligned to an axis? Can you confirm?
User avatar
Rich O Brien
Administrator
Postby Rich O Brien » Wed May 18, 2011 5:16 pm
No, it seems to toggling on/off....strange? TIG?
User avatar
Rich O Brien
Administrator
Postby Dave R » Wed May 18, 2011 5:18 pm
It isn't even Friday the 13th.
User avatar
Global Moderator
Re: [Plugin] Pen Tool + 1.3 (18/5/2011)
Postby Rich O Brien » Wed May 18, 2011 9:46 pm
Updated to v1.3
Note:
Weld Draw does not draw welded loops. It will also split if it intersects with any edge and get a little funky. It's primary function it to create a simple curve from drawn edges[lines]
User avatar
Rich O Brien
Administrator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: Aifort, eslam7895, happyfa, owerty1978, raspberrypisig and 17 guests
Visit our sponsors:
