by TIG » Sat Apr 23, 2011 2:07 pm
There have been several threads about 'Grow' [they keep growing  ]... so it's been decided to make one new central point where it'll be based - and that right HERE! Usage: Move/Place Objects,Select them and pick Grow. Pick Point. Enter desired data in dialogs and see results. Undo is in 1 step. Note that non-grouped Faces and Edges can stick together after 'Growing'. Play around to see types of results... Shape, location, scale, order all produce different results... Linear Scaling goes 1 2 3 4 5 6 7... on any scaling factor Exponential + goes 1 2 4 8 16 32... on any scaling factor != 1 Exponential - goes 1 1/2 1/4 1/8 1/16 1/32... on any scaling factor != 1 Fibonacci + goes 1 1 2 3 5 8 13... on any scaling factor Fibonacci - goes 1 1 1/2 1/3 1/5 1/8 1/13... on any scaling factorDownload
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Khai » Sat Apr 23, 2011 2:50 pm
..and what does it do?
Khai
- Name: Khai
- SketchUp version: 2017
- License type: Free/Make
- Level of SketchUp: Intermediate
by Gaieus » Sat Apr 23, 2011 3:07 pm
Khai wrote:..and what does it do?
Grows. Take one every evening (and one extra before sex but never more than two a day)
- Name: Csaba Pozsárkó
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
by TIG » Sat Apr 23, 2011 3:18 pm
Gaieus! I've added an explanation to the download page... It's been around so long that I forgot that it might be new to some of you...
- Global Moderator
- Name: TIG
- License type: Pro
by Gaieus » Sat Apr 23, 2011 3:20 pm
Ah well, sorry for the bad joke indeed (I could not resist however)
- License type: Pro
by solo » Sat Apr 23, 2011 3:35 pm
Csaba,you have grow.rb confused with viagra.rb.
- Global Moderator
- Name: solo
- License type: Pro
- SketchUp use: other
by Gaieus » Sat Apr 23, 2011 3:44 pm
You know, at my age you take everything whose label says "grow".
- License type: Pro
by TIG » Sat Apr 23, 2011 3:50 pm
I've heard that the super-strength-viagra - like you use - is so potent, that if you don't swallow it quickly enough you get a stiff-neck
- Global Moderator
- Name: TIG
- License type: Pro
by Rich O Brien » Sat Apr 23, 2011 4:00 pm
Keep on topic guys. I'd hate to have to shaft you outta here. So quit the dickin' around. It is easter after all. The time to reflect on what rose from the dead only to disappear again.
There's a frontroom and a backroom....reverse faces
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
- SketchUp use: engineering and mechanical design
by pilou » Sat Apr 23, 2011 4:11 pm
Note that this version [v2.1] is unchanged from the previous one you might have found somewhere else - it's just been rehoused here !
So if I have the last previous one, non need to download this one?  My favorite one
- Top SketchUcator
- Name: Pilou
- SketchUp use: hobby
by TIG » Sat Apr 23, 2011 4:13 pm
Pilou wrote:Note that this version [v2.1] is unchanged from the previous one you might have found somewhere else - it's just been rehoused here !
So if I have the last previous one, no need to download this one?
Correct. I suspect you already have the latest version. Reinstalling it won't do any harm - it'll just be a waste of two minutes that you'll never see again
- Global Moderator
- Name: TIG
- License type: Pro
by pilou » Sat Apr 23, 2011 4:32 pm
yes old but yet 2.1 2007 01 21
- Top SketchUcator
- Name: Pilou
by TIG » Sat Apr 23, 2011 4:39 pm
Pilou wrote:I suspect you already have the latest version
It IS an 'oldie but a goldie'... It would probably benefit from a webdialog interface etc etc... BUT four or five years ago when I wrote it it was the best I could do... It still works!!!
- Global Moderator
- Name: TIG
- License type: Pro
by Jim436 » Mon Apr 25, 2011 2:22 pm
A question about "growing" things. No, not that, sketchup things.
To try to explain. Okay, starting with something 10 units long in the red direction. Say it's just a line. And rotations all zero. Now if I set x copy scaling to 1.1 and xcopy scaling type to exponential, I get copies in the sequence: 11, 12.21, 13.331 ....units length. What I expected, each new copy is 1.1 times the length of the previous copy. Good.
Now do the same thing only with xcopy scaling set to linear. (as I am hoping to get copies in the series: 11, 12, 13, 14 ....
But what I get is: 23.1 ,37.51, 53.361 ....units length
I'm just not quite understanding this. The linear scaling. Help??
Jim436
by pyroluna » Tue Apr 26, 2011 3:42 pm
Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase!
pyroluna
- Name: Pyroluna
- License type: Pro
- SketchUp use: education
by TIG » Tue Apr 26, 2011 5:12 pm
Pyroluna wrote:Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase!
That IS one of the demos from looooong ago...
- Global Moderator
- Name: TIG
- License type: Pro
by d12dozr » Tue Apr 26, 2011 9:34 pm
Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose!
d12dozr
- Top SketchUcator
- Name: Marcus
- SketchUp version: 2015
- License type: Pro
- SketchUp use: product design
by TIG » Tue Apr 26, 2011 10:17 pm
d12dozr wrote:Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose!
That's why, after some prompting, I resurrected 'Grow' into the mainstream so you might all know/remember it...  Here're some [old] examples... Grow Examples.zip
- Global Moderator
- Name: TIG
- License type: Pro
by d12dozr » Wed Apr 27, 2011 12:48 am
Thank you for those  ...now isn't someone working on a video tutorial?
d12dozr
- Top SketchUcator
- Name: Marcus
- License type: Pro
by TIG » Wed Apr 27, 2011 11:01 am
Grow is so old that there was only 16mm film back then
- Global Moderator
- Name: TIG
- License type: Pro
by d12dozr » Wed Apr 27, 2011 6:23 pm
So a black and white silent film? That works!
d12dozr
- Top SketchUcator
- Name: Marcus
- License type: Pro
by Pherim » Wed May 18, 2011 4:06 pm
It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
Pherim
- Name: Pherim
- SketchUp version: 2016
by TIG » Wed May 18, 2011 4:40 pm
Pherim wrote:It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
This is a known issue - SP messes with some existing base class methods and thereby affects a few other scripts...
- Global Moderator
- Name: TIG
- License type: Pro
by patricprz » Mon Sep 26, 2011 4:16 am
Thanks for recommending this. It works a treat.
patricprz
by Sir.Swaffel » Tue Sep 27, 2011 11:46 am
What would be the best way to let it "grow along path"?
Sir.Swaffel
by TIG » Tue Sep 27, 2011 3:46 pm
Not this tool... Look for Chris Fullemr's ComponentStringer and RickW's ComponentAlongPath ...
- Global Moderator
- Name: TIG
- License type: Pro
by Sir.Swaffel » Tue Sep 27, 2011 4:12 pm
Well I do need some kind of scaling. As you can see from the image, I'm trying to make a spiraling tower. I need to make windows in the vertical segments, but the tower is quite large and the vertical segments get smaller as the tower gets higher. So I need the windows to follow the spiraling path upwards AND have them scaled down according to the height. Then I'm going to subtract them from the vertical segments to create the arched openings. It's a total headache tower.jpg
Sir.Swaffel
by TIG » Tue Sep 27, 2011 4:37 pm
Try DrawHelix for the rail[s] - you can have different start/end radii and a straight-curve for the profile... Capture.PNG Here's quick example, worry about the fripperies like the door-arch later...
- Global Moderator
- Name: TIG
- License type: Pro
by mikenon » Wed Sep 28, 2011 8:42 pm
Hi - This is almost exactly what I need, but I would like to use other functions. Is there a way to alter this so that instead of choosing from linear/exponential/fibonacci I have the ability to select my own values. I need some other periodic functions, like sine-wave. I imagine, the easiest way to do this would be to just allow values to be passed in a list. So if I want 100 copies, I pass in a list with 100 numbers for x-offset. Is this possible?
Mike
mikenon
- Name: mikenon
by TIG » Thu Sep 29, 2011 8:47 am
Yes IF YOU redo the code. It's probably easiest to make a new tool that is run in a way that can take arguments - in your case an array of values, which it then uses to do something. That way the processing is somewhat independent of the outcome... Do not forget that there are already many tools that process CSV/TSV files so in your case you simply have a file in the format x,y,z [and even rotx,roty,rotz,scalex/,scaley,scalez etc] - one 'point' per line and then do something with the point - add cpoints, join up the points with lines etc, place an instance at every point and rotate it/scale it... You could make the 'table' file from Excel osa... IF you explain better what it is you want to achieve and supply a typical xyz... data set I might be able to quickly bodge something together, though I am quite busy...
- Global Moderator
- Name: TIG
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
