[Plugin] Curve Maker v1.2.2 - 7 March 2011
Postby max-cx » Mon Mar 07, 2011 11:18 pm
The Curve Maker plugin has been updated to include more interactive drawing and editing options.
You can now draw and edit a catenary, parabola, sine or cosine curve interactively.
It's pretty much like using the rectangle tool as shown in this example video
http://www.youtube.com/watch?v=M4QUO0PaI_E
You can download the updated plugin from here:
http://www.drawmetal.com/download
max-cx
PluginStore Author
PluginStore Author
Re: [Plugin] Curve Maker v1.2.2 - 7 March 2011
Postby mitcorb » Tue Mar 08, 2011 4:11 am
Hi, max-cx:
Thank you for sharing this information.
User avatar
mitcorb
Top SketchUcator
Postby jsteacy » Tue Mar 08, 2011 4:31 am
Awesome update, thanks!
jsteacy
Premium Member
Premium Member
Postby d12dozr » Tue Mar 08, 2011 5:40 am
Great update, works well! Thanks Terry :thumb:
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby Michaelv » Wed Mar 30, 2011 10:02 pm
Terry,
From one blacksmith (hobbyist) to another, thanks!
I will PM you the 2 scripts to which I added the toolbar.restore line to make the toolbar remember its previous status (displayed or not) on Mac (I think on PC toolbars work differently).
I also have everything working except parabola and catenary, which do not want to work right, it displays a tiny line, which is unrelated and not correct regardless of zoom.
I am on Mac book pro, OS 10.5.8 and Sketchup 8.0.4810. I typically work in mm.
Everything else works just fine.
I can't look at the ruby because it's scrambled so I don't know what's wrong. It could be the default unit. HAHA I just checked and that's exactly what it is. If I start with an inch template instead of mm it works just fine.
Michael
Michaelv
Postby jarynzlesa » Wed Mar 30, 2011 10:41 pm
blacksmith plugin
i like this plugin . thanks :thumb: .
User avatar
jarynzlesa
Postby utiler » Thu Mar 31, 2011 5:28 am
Hi Terry, It seems that the Catenary Icon is not viewing in the toolbar...? Is this the case of am I crazy??
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby max-cx » Fri Apr 01, 2011 8:17 pm
Thanks to Michaelv for identifying a rather ugly "undocumented feature". The catenary and parabola logic was getting confused when the model units was something other than inches. Need to have a little talk with the QA department about that one.
I have also incorporated the suggestion of adding toolbar.restore to the appropriate scripts.
Unfortunately, Andrew, I don't have toolbar icons for the catenary or the parabola at this time.
max-cx
PluginStore Author
PluginStore Author
Postby Gus R » Sat Apr 02, 2011 12:20 am
Excellent plugin Max. The update makes it even better. Now I can create curves including the common helix on the fly and they line up perpendicular to faces. :thumb:
User avatar
Gus R
Postby dtrarch » Sat Apr 02, 2011 1:02 am
max-cx
Just plain thank you. :thumb:
A real bread and butter add-on :D
We do not even have to do the math.
Very very nice
dtr
dtrarch
Premium Member
Premium Member
Postby pilou » Sat Apr 02, 2011 10:43 am
Very cool Plugin! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby JClements » Sun Apr 03, 2011 5:59 pm
Great update. Thanks.
Be slick to have interactive properties for the helix tool'sw diameter and length.
Any possibility of entering of start and end diameter for a helix?
User avatar
JClements
Premium Member
Premium Member
Postby max-cx » Sun Apr 03, 2011 11:25 pm
John -
Thanks for your encouraging feedback.
Will the Archimedes Spiral tool provide what you are after? Using the interactive tool, you can enter two radii to establish the rate at which the diameter of the spiral grows and set the height parameter to specify how tall you want the spiral to be - essentially giving you a tapered helix. See attached figure.
The Archimedes Spiral option in the dialog box off the Plugins menu offers still more control because it lets you specify the radius at each of two particular numbers of turns - the first and the last in your case.
max-cx
PluginStore Author
PluginStore Author
Postby JClements » Mon Apr 04, 2011 3:28 pm
I must have overlooked this. Thanks for the quick reply.
User avatar
JClements
Premium Member
Premium Member
Postby derei » Thu Apr 07, 2011 11:47 pm
Please help!
I need to draw a Archimedes Spiral with this specs:
inner radius: 15mm
turns: 5
distance between turns: 2mm
I got the options panel attached here, but I get lost in it.
What should I input there to have the desired result?
DESIGNER AND ARTIST DEREI.UK
User avatar
derei
Postby derei » Fri Apr 08, 2011 1:29 am
ERROR !
After using the plugin several times, I can't use it anymore. Every time I click OK on Parameters input box, it reappears. No error message, no error in Ruby console. It's a loop. Dialog disappear then is back... and so on.
EDIT: -it happened in the model I was working in. It didn't fixed after close and open. But in new model it worked. It seems that something that was saved inside the model while using the plugin, caused the bug.
User avatar
derei
Postby max-cx » Fri Apr 08, 2011 4:50 am
Is this what you are trying to draw?
max-cx
PluginStore Author
PluginStore Author
Postby max-cx » Fri Apr 08, 2011 4:56 am
The most likely reason the dialog box keeps reappearing is that you have not entered a valid point for the curve origin. SU will not accept a ~ in any coordinate in a point - each value needs to be exact. The plugin could be friendlier in this regard.
max-cx
PluginStore Author
PluginStore Author
Postby derei » Fri Apr 08, 2011 5:21 am
max-cx wrote:The most likely reason the dialog box keeps reappearing is that you have not entered a valid point for the curve origin. SU will not accept a ~ in any coordinate in a point - each value needs to be exact. The plugin could be friendlier in this regard.
Indeed I selected a guidepoint and its coordinate was with ~ . And the worse part was that if unselected it, hoping that the spiral to appear on origin, the previous value was retained in the inputbox, so I was triked again by the plugin. Maybe some fixes on that?
And yes, that is what I wanted to draw... after some trials and errors I got it (about one hour of playing). But I did it in a different manner, I don't know if that was the correct approach, or yours... I just changed the values until I noticed a pattern :mrgreen:.
I still don't fully understand what are all that fields in inputbox. So many radii, turns, first turns, second turns... i'm dizzy :shock: . I tried to find the answer in the manual, but I couldn't.
User avatar
derei
Postby max-cx » Fri Apr 08, 2011 3:47 pm
By design, the plugin remembers the previous inputs - including erroneous ones.
Perhaps the interactive versions of these tools will be more to your liking. Have you tried the Curve Maker sub-menu on the Draw menu? They might also help you understand what the dialog boxes are prompting for and the additional degrees of control that the dialogs offer.
max-cx
PluginStore Author
PluginStore Author
Postby max-cx » Fri Apr 08, 2011 11:55 pm
The Curve Maker plugin has been updated. It can be downloaded from http://www.drawmetal.com/download
Given the current Length Units Format, if a guide point coordinate's value can only be approximated (i.e. it displays with ~), then Curve Maker will now display the coordinate value as a decimal length. This should mitigate the problem that dereeei experienced with the curve origin field in the input dialog.
max-cx
PluginStore Author
PluginStore Author
Postby robertWan » Sun Mar 19, 2017 11:47 pm
Does anybody have a version for SU 8?
The author doesn't.
Robert
User avatar
robertWan
Re: [Plugin] Curve Maker, copy for SU8
Postby JClements » Mon Mar 20, 2017 4:02 pm
Try the attached. Hopefully it contains all the required files.
User avatar
JClements
Premium Member
Premium Member
Postby robertWan » Sat Mar 25, 2017 2:04 pm
Thank you. :D
Robert
User avatar
robertWan
Postby swpuagui » Wed Aug 02, 2017 4:26 am
Thank you so much!
swpuagui
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: anerpet87, gunerarici, jeraldinejimenez, oleg201185, phuong1984, sozuneri116, sta2f and 14 guests
Visit our sponsors:
