[Plugin] CADup
[Plugin] CADup
Postby TIG » Tue Feb 15, 2011 5:12 pm
TIG (c) 2011 - 2013
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
Script: CADup.rb
Usage:
This makes lines drawings of views of a Group or Component-Instance ready
for use in a CAD program.
It is best to use this tool in an uncluttered SKP so that the intersections
of entities needed to do the complex geometry calculations are not
compromised by other unrelated entities [even if they might be 'hidden'].
Also place your Component-Instance OR Group with its insert-point at the
ORIGIN. If it is not located there then a copy of it is placed there,
however, ensure there is nothing else in the vicinity of the ORIGIN,
including any 'misplaced' Component/Group itself.
It's recommended that you select your component and right-click save_as to
process it as an external isolated component if possible.
Do NOT try and process a whole building with furnishings and fittings - the
amount of data in that collection of things will just 'kill' Sketchup!
So, select your Component-Instance OR Group [and nothing else].
Pick 'CADup' off the 'Tools' menu [or type 'cadup' or 'skad' in the
Ruby Console]
If there is not one Component-Instance OR Group selected there is an error-
message.
'CompoName' is the Component-Instance-Definition's name, OR if a Group is
selected then the Group's name [or 'Group' if the Group is 'un-named'].
It runs with information displayed in the Status Bar and the view refreshed
after each step [v7+ only].
It creates a new Component called 'CompoName[SKAD]' on layer 'SKAD'.
If that name is already used it's incremented with a #1, #2... suffix...
Within that it makes a temporary grouped and exploded version of the
selected Component/Group located on the ORIGIN. At the end this temporary
group is erased and the selected Component/Group is replaced where it was.
It has a flat 3d-text label which reads '3D' on layer 'SKAD.TEXT'
[it's name is 'TEXT'].
It then creates the 6 flat 2D orthogonal views of the Component/Group
within the 'CompoName[SKAD]', in turn: they are named:-
TOP
BOTTOM
FRONT
BACK
RIGHT
LEFT
[Equivalent to the Plan and Reflected-Plan, and the South, North, East and
West Elevations respectively]
These are each grouped and named 'SKAD-TOP', 'SKAD-BOTTOM' etc [each is on
Layer0].
Within each view's group there are sub-groups:-
a) 'TEXT' on layer 'SKAD.TEXT' which is a flat 3d-text label which reads
'TOP', 'BOTTOM' etc.
b) 'TOP-CONT', 'BOTTOM-CONT' etc [each on layer 'SKAD.CONT'] which contains
all of the CONTinuous solid edges that would be seen in each view.
c) 'TOP-HIDN', 'BOTTOM-HIDN' etc [each on layer 'SKAD.HIDN'] which contains
all of the HIDdeN edges that would be obscured in each view, also has any
hidden/soft/smooth edges in it - e.g. the curved surface of a cylinder.
d) 'TOP-CIRC', 'BOTTOM-CIRC' etc [each on layer 'SKAD.CIRC'] which contains
all of the CIRCles [and arcs] that are perpendicular to each view with a
small + at their centers - the + is on a layer called 'SKAD.CPTS'.
Note that the segments of the circles/arcs are also shown in the 'CONT'
version as individual lines - however, exporting a 3D DXF/DWG will export
the separate layer's entities as Circles/Arcs and these will be identified
as those types of object in the CAD program - useful for 'drilling' etc.
A collection of 6 SECTions is added - similar to the 'view' but with it
cutting the selected object at its center and having an additional grouped
set of lines 'SECT'. The are name after the direction of the section-view
not like the views them selves - so the view 'TOP' shows the top looking
down but the 'SECT-TOP' shows the underside of the top looking up.
The SECTions are named:-
SECT-BOTTOM
SECT-TOP
SECT-FRONT
SECT-BACK
SECT-RIGHT
SECT-LEFT
[Equivalent to the Internal-Plan and True-Ceiling-Plan, and the
Sections looking South, North, East and West respectively]
These are grouped/layered etc in a similar way to the 'views'
A collection of the 4 flattened AXOnometric views is added.
They do not show hidden lines or separate circles, but are otherwise
similar to the 'views'.
Each is dimensionally correct in the Y and lines that are at 45 degrees to
the main axes. The AXOnometrics are named:-
AXO-NW
AXO-SW
AXO-SE
AXO-NE
These flat 2D view-groups are arranged on the z=0 plane.
They are arranged logically around the 3D version, oriented consistently.
They are spaced equally using the variable 'gap' which is set to 100mm at
the start of the code - it can be adjusted - note that it must be > 0...
The 3d-text labels' height is always gap/2 - i.e. default is 50mm.
The Circles' '+' cpt-marker is always gap/4 - i.e. default is 25mm.
The CADup default _name_="SKAD" is also set at the start of the code, and
this can be changed if desired...
It's a good idea to have your current Style set to use 'Material by Layer'
and color the various layers to mimic CAD colors etc - see below...***
Be patient - there are lots of operations to complete...
You can of course edit the separate view-group parts - e.g. erasing some
lines etc that you think are not needed.
Once the set is complete to your satisfaction you can export the new
collection to a separate SKP [right-click 'Save-AS...'] and thence as a
DWG or DXF to use in a CAD program.
***The layering of the parts is specifically tailored to suit this CAD use.
If your CAD template file has the plotting pens set be 'by layer', then
you can set the layer 'SKAD.CONT' to be a medium/thin solid pen-style, the
layer 'SKAD.HIDN' to be a fine dash/dot/hidden pen-style. The 'SKAD-CIRC'
layer can also be used for hole-drilling etc or merged with an edited CONT
layer as desired. The 'SKAD-SECT' layer should be set to a thick solid
pen-style to display the section-cut appropriately.
Once you have a set of layers set up for this you can save a CAD DWG as a
template [DWT] and reuse that to make new DWGs of this type, inserting the
individual SKP>DWG files as Blocks and arranging and editing then as
desired...
Donations: By PayPal.com to info @ revitrev.org
Version:
1.0 20110215 First Beta Release.
1.1 20110218 A Group OR an Instance now processed.
Edges within any Groups/Instances within the Selected Object
are now reproduced on appropriate layers.
Edges that are hidden/smooth/soft in the Selected Object are
now reproduced on the HIDN layer.
Spacing of Views etc improved.
Has a trial version of SECT-BOTTOM only - for feed-back...
Has a trial version of AXO-SW only - for feed-back...
1.2 20110221 Container now made into a Component for easier export to SKP.
All SECTion and AXOnonmetric views added.
Arrangement of parts adjusted and the use of the original
selected object has be modified to minimize 'clashes'.
Default name 2CAD becomes SKAD.
1.2a 20130830 Now has ArcCurveTests.rb within its RBZ for backwards compatibility etc...
Please download the latest version from the SCF PluginStore http://sketchucation.com/resources/plug ... ?pln=CADup or from within SketchUp itself using the SketchUcation Plugin Store toolset...
CADupExample.skp
3
User avatar
Global Moderator
Re: [Plugin] CADup v1.0 20110215
Postby pilou » Tue Feb 15, 2011 5:24 pm
Strange that was not yet existing! :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby dedmin » Tue Feb 15, 2011 6:22 pm
dedmin
Postby jsteacy » Tue Feb 15, 2011 11:05 pm
Great idea for a plugin! :thumb:
I tested it with a cube and a cylinder as one component but it add the lines of the object behind the object in front for the elevations. See image and the red circles. I also tested a more complex components with a lot of nested component and it did not like that...
Hope this helps what I think will be a very useful plugin, cheers!
jsteacy
Premium Member
Premium Member
Postby TIG » Tue Feb 15, 2011 11:19 pm
jsteacy wrote:Great idea for a plugin! :thumb:
It shows ALL lines but puts 'hidden' ones on a special layer...
Change you Style display to 'Color by Layer'.
Make the HIDN layer 'pale-gray' to mimic CAD's dash-lines and then the CONT layer 'red', and the CIRC/CPTS layer 'green/dark-green'...
You'll see the result better.
It's intended for CAD use later, so in the SKP it won't look so good unless you have this type of material-setting...
User avatar
Global Moderator
Postby jsteacy » Wed Feb 16, 2011 3:48 am
ahhh, helps if I read, thanks
jsteacy
Premium Member
Premium Member
Postby srx » Wed Feb 16, 2011 8:37 am
Thank you. I just needed it :)
www.saurus.rs
User avatar
srx
Postby tomislavm » Wed Feb 16, 2011 9:10 am
Thank You!
tomislavm
Postby TIG » Thu Feb 17, 2011 8:54 am
Good news:
I am going to extend CADup to include the 6 centralized sections.
I am looking at adjusting the way it handles 'surfaces' with hidden/smoothed lines, e.g. splitting the geometry onto new layers for these and the other outermost edges etc.
I shall be adding an example CAD template [dwg/dwt] with its layers set appropriately for heavy/medium/thin/dashed lines etc pstyles, plan view etc, that you can use to set up new sheets and import the CADup output as dwg/dxf blocks...
I'll be writing a tutorial.
Bad news:
Won't have time to do it for a few days...
User avatar
Global Moderator
Postby dedmin » Thu Feb 17, 2011 9:31 am
Good news! What about handling groups also?
dedmin
Postby TIG » Thu Feb 17, 2011 10:48 am
dedmin wrote:Good news! What about handling groups also?
Yes I will also be adding support for using CADup on a selected group [as well as its current component-instance] AND for finding all edges within groups and component-instances that are nested within the selected object's entities...
User avatar
Global Moderator
Postby dedmin » Thu Feb 17, 2011 11:43 am
dedmin
Postby tfdesign » Thu Feb 17, 2011 12:40 pm
Great looking plugin TIG!
Thanks very much for this, you're going to make a lot of people, especially product designers and engineers very happy!
Tom
tfdesign
Top SketchUcator
Postby TIG » Thu Feb 17, 2011 12:59 pm
dedmin wrote::thumb: :thumb: :thumb:
This is in BricsCAD:
http://www.screencast.com/users/dedmin/ ... 24b73e1cb5
I see it makes iso/axo views... I was also thinking about how I might incorporate that in CADup...
User avatar
Global Moderator
Postby dedmin » Thu Feb 17, 2011 2:28 pm
Maybe based on the component/group axes or world axes - as two options. Because You can't be sure what are the front/back/right and etc. for a given component.
dedmin
Postby kmead » Fri Feb 18, 2011 3:38 pm
This is a very nice addition.
I have tried a couple of files, the first quite simple worked well.
The second caused the program to get into a loop where I had to force quit SU. I am on a Mac.
The file I had trouble with is proprietary so I cannot post it but would be willing to send it to you.
Karl
I created Dilbertville, sorry about that...
User avatar
kmead
Postby TIG » Fri Feb 18, 2011 3:43 pm
kmead wrote:This is a very nice addition.
Karl
OK... I'm about to issue an update... so wait till after that - but if there's still a problem attached it [zipped ?] to a PM to me...
User avatar
Global Moderator
Re: [Plugin] CADup v1.1 20110218
Postby TIG » Fri Feb 18, 2011 6:46 pm
Here's v1.1 viewtopic.php?p=309485#p309485
A Group OR an Instance can now be processed.
Edges within any Groups/Instances nested within the Selected Object are now reproduced on appropriate layers.
Edges that are hidden/smooth/soft in the Selected Object are now reproduced on the HIDN layer.
Spacing of Views etc has been improved.
Makes a trial version of a SECT-BOTTOM only - for feedback purposes...
Makes a trial version of a AXO-SW only - for feedback purposes...
This is 'flat' example.
Feedback please...
User avatar
Global Moderator
Postby dedmin » Fri Feb 18, 2011 9:50 pm
dedmin
Postby TIG » Fri Feb 18, 2011 10:03 pm
dedmin wrote:http://www.screencast.com/users/dedmin/folders/Jing/media/c3154fc0-6d7c-4d41-803b-345c06131ef2
Please retry... BUT this time move the component/group in question so that it is well out of the same space as the CADup versions... i.e. NOT near the origin... I suspect that there's 'interference' between the original and the copy...
I can perhaps make this a v8 only app and hide the rest of the model...
The idea is you have an instance off to one side and then it makes the 2d parts...
Because it uses raytests and project_to_plane etc it can get confused...
This is still in beta - thanks for the report...
User avatar
Global Moderator
Postby barsaglini » Mon Feb 21, 2011 12:58 am
every time, I tried to use the plugin in houses that had already modeled, the sketchup closed =/
small objects functioned normally
barsaglini
Postby TIG » Mon Feb 21, 2011 9:02 am
barsaglini wrote:every time, I tried to use the plugin in houses that had already modeled, sketchup closed =/
small objects functioned normally.
It is intended to CAD up components. A 'whole house' is going to be veeeery data intensive ???
Perhaps the outer 'shell' will be OK but all of the internals that have to be inspected and discounted ????
Even if 'hidden/off-layer!
Export what you want to CAD up [select, right-click, save_as] and process that.
There will be a new version out later today - see how that does... :geek:
User avatar
Global Moderator
Postby watkins » Mon Feb 21, 2011 9:16 am
Morning TIG!
Sound like you have a busy day!
I am watching this space with interest as it has been suggested that postgrad students use SU for small design jobs rather than AutoCAD Inventor which is way over the top for most of their needs. Also, the free version od SU is, afterall, free. We have to watch our pennies these days, and even a student copy of Inventor is around £300.
Regards,
Bob
watkins
Postby Nick2010 » Mon Feb 21, 2011 6:05 pm
Another Hit from Master Tig! Thank you so much!!! :berserk: :berserk: :berserk:
Nick2010
Postby barsaglini » Mon Feb 21, 2011 7:13 pm
get it!
Great job, hope you can run stably!
Tested on a cube, which made a hole in the left side, right side view of the hole he showed too;)
Thank you.
barsaglini
Re: [Plugin] CADup v1.2 20110221
Postby TIG » Mon Feb 21, 2011 9:18 pm
Here's v1.2 viewtopic.php?p=309485#p309485
Please read the notes with the download link... there have been changes...
All SECTion and AXOnonmetric views have been added.
Arrangement of the 'parts' has been adjusted and the use of the original selected object has be modified to minimize potential 'clashes'.
Default file/layer name of '2CAD' now becomes 'SKAD'.
Feedback please...............
User avatar
Global Moderator
Postby TIG » Tue Feb 22, 2011 10:53 am
Tip:-
The 6 SECTions are always cut at the center of the selected object's bounding-box.
If you want to make the sections in a different location then group the main component with between 1 and 6 guide-points [number depends on how many directions you want to slide the 'center'] - each suitably located to change the then combined bounding-box so that its center is now where you want the SECTion cuts to be placed [if your object us already a group you can add temporary guide-points to that]...
User avatar
Global Moderator
Postby mado » Thu Feb 24, 2011 10:02 am
:berserk: Thanks, Tig
You can not even imagine the plugin is useful for furniture design.
mado
Postby philippequimper » Fri Feb 25, 2011 9:24 am
When exporting to .DWG, all the lines are exported in the "0" layer without any sorting.. So I can't re-use efficiently this file in Autocad. Do I miss something?
philippequimper
Postby TIG » Fri Feb 25, 2011 10:20 am
philippequimper wrote:When exporting to .DWG, all the lines are exported in the "0" layer without any sorting.. So I can't re-use efficiently this file in Autocad. Do I miss something?
Exporting a 2D file makes everything on one layer and ignores arcs etc.
Do it as 3D and it should export properly.
When in your CAD app set up 2D views of it... done :D
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: BenzRay05, ci201, Le Quoc Hung, meikongwumei and 10 guests
Visit our sponsors:
