[Plugin] Architect Tools
• Page 2 of 4 • 1, 2, 3, 4
Re: [Plugin] Plan Tools (1.2.1) — 07 February 2011whoops!
![]() the latest. always the latest. ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Plan Tools (1.2.1) — 07 February 2011I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
when you fail at something....you haven't really failed...you've found one way the thing will not work out
That's because you're using a flat plan tool. If you look at my demo video, I use 3D plan data to generate the buildings. The faces are extruded up to the lines above it. The tolerance is not the extrude height - but the tolerance for closing open gaps in the lines. Thomas Thomassen — SketchUp Monkey & Coding addict
I'm also having the same problem as arjun ..how can one create a 3d plan data??...Isn't there any way to automatically generated extruded faces out of such plans??
We get such data from surveyors.
From 2d plans? No - how would you expect it to work? What are you trying to do? Make a set of generic boxes at various heights? In which case you want to look at the Random Push-Pull plugin. Plan Tools is intended to be used to help generate volumes based on accurate real world 3d data. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Plan Tools (1.2.1) — 07 February 2011amazing...i wonder what more surprises are in store from you (the great ruby wizards
![]() Re: [Plugin] Plan Tools (1.2.1) — 07 February 2011Sr thomthom.
Thanks for this plugin. Would it be possible to cut smooth lines? Please see this post viewtopic.php?f=323&t=37716&p=333319#p333319 Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Version 1.2.2
Minor Bugfixes Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011This is such a great plug-in, it should be on the must have visual index, it´s fantastic!
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Anyone got a better suggestion for a name that might describe the plugin better?
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Urban Importer? Urban Planner?
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Here are a few words: 3d Site Plan Context Modeler Surround(s) Neighborhood Zone Focus Local. Feel free to Slice and Dice as you please.
EDIT: I forgot Lifter Extruder AutoExtruder I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011How about 'Urban Morph tools'...?
purpose/expression/purpose/....
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Whoa, that just might be sinister enough
![]() I take the slow, deliberate approach in my aimless wandering.
Only for those with a twisted mind, Tim..... ![]() purpose/expression/purpose/....
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Maybe I'm looking at it the wrong way. Maybe this plugin needs to be split into different plugins.
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011I think you right, Thom. Your plan tools are a little different from the urban forms tool..... Maybe expand city gen and incorporate the morph thingy....?
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Yea, I was thinking that parts of City Gen could be merged. And some parts of this plugin could go into other, or new plugin. Just to make the plugin more defined. Because it's clear that it has an identity crisis.
It's been a collection of tools I've built to just get the job done - so it's not as polished as the rest. And I think many don't realize what it does - where in fact it is one of the most time-saving plugins I got. Working on new tools for it, making layered terrain. Started to clean up the plugin as I go along.
Whatismajiggy? ![]() ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011That sound logical, Thom.
I've been working on urban renewal project of late where I cam provided with all types of GIS data from property boundaries, roads, contours, even elevation data points on buildings... here's a few screenshots.... I import all aerial photo's, CAD lines into SU and set particular layers to I can manipulate scenes in LO efficiently.... Particular to note I find it best to layer scenes with linework in Vector mode over scenes of aerial photography in Raster mode as Hybrid just doesn't cut it yet. Morph: Cheers, ![]() purpose/expression/purpose/....
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011I dont know how the remaining time is computed, but when the Generate Buildings sequence started it was 20 minute ; finally the works take 2 hours and 30 minutes !
Fortunately, it made what I was waiting ![]() Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011The estimated remaining time is based on how much time it has taken to process the current set of entities vs the remaining. The problem is that adding geometry to SketchUp gets slower the more geometry there is - which is problematic to estimate. I haven't even tried to account for that.
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Why not use a '% complete' report ?
It changes to show it's working and the user then knows how much is left to do... If THEY assume the second 50% will take as long as the first 50%, then that's their issue not yours. All you will have done is told them how much has been processed so far, and that it is actively continuing... TIG
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011I was reusing some generic code - which for linear time code works well.
I am working on a version 2 where I am cleaning up lots of stuff. Everything has so far just been quickly assembled to automate tasks I've been working on. Thomas Thomassen — SketchUp Monkey & Coding addict
I dont know if it's many or not, the process made 7,000 groups. My computer is a i5 @2.4 GHz with 3 Gb RAM. It's not a race computer but is not a Minitel... For this job, the problem was'nt the time but just my wife asking me "when you will be back home ?"... "SU says in fifty minutes..." and half an hour later "SU says in one hour...". SU is a liar !! ![]() Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011Many or not many - doesn't matter. The time it takes to add geometry in SU slows down every time more geometry is added.
Re: [Plugin] Plan Tools (1.2.2) — 17 June 2011That's strange - can't quite pin-point where the error is. "eval" error..
Exactly what SketchUp version do you have? And what TT_Lib2 version? Did you just install Plan Tools and got the error on first run? Or did it suddenly appear? Can you open the Ruby Console and type: load 'tt_plan_tools.rb' post back any error-messages. Thomas Thomassen — SketchUp Monkey & Coding addict
Starts running, and later has been an error sketchup8M2 Latest Last edited by thomthom on Mon Feb 27, 2012 9:28 am, edited 1 time in total.
Reason: Fixed the quote tag I come from China, is to learn
Can you explain more. It's very hard to debug with so little info. And did you try the Ruby Console command? Thomas Thomassen — SketchUp Monkey & Coding addict
