[Plugin] Toggle UnitsRe: [Plugin] Toggle UnitsIncredible... That's incredible! Cheer up! We will success...
Frenglish at its best !
My scripts Re: [Plugin] Toggle UnitsMatt
Installed and works as advertised. Also, like the additional button. Thank you. Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Toggle UnitsAhhhh ... changed already. I added a red dot to the original set to show the association between related buttons.
CAD father's, as always, are nice icons. John John | Illustrator | Beaverton, Oregon
Re: [Plugin] Toggle UnitsSorry JClements... ![]() ![]() ![]() Frenglish at its best !
My scripts Re: [Plugin] Toggle UnitsHey Matt:
Could the new values created when the accuracy buttons are clicked, be displayed somewhere such as in the Task Bar or better yet when the mouse is put over the top of button? John John | Illustrator | Beaverton, Oregon
Re: [Plugin] Toggle UnitsSame happens on my Mac . Just the last three buttons worked as expected.
Re: [Plugin] Toggle UnitsAmigo!!! se que no vas a entender esto... pero si lo traduces quizas si...
TU ERES MI IDOLO!!!!!! es la herramienta mas util que necesitaba par trabajar... te lo agradezco toda la vida... Matias desde Corrientes, Argentina ![]() ![]() ![]() ![]() ![]() Re: [Plugin] Toggle UnitsMuch better - thanks Matt ...
With JSON machines we can analyse what is to be achieved so that IT can help with automation to achieve it.
Re: [Plugin] Toggle UnitsOnly the 10th and 11th icon work on my Mac version. Also, as mentioned previously, the buttons stay depressed even when you press a different one.
Also, there is not much difference in the gray color between pressed and not pressed for the "Dec" button (when it is in its "not-pressed" condition it is already grayed out, but not quite as much as when it is pressed). See Attachment. When I get it working it will be of significant value since I often work with both decimal inches and feet/inches. i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
Re: [Plugin] Toggle UnitsIs there anyone else that is having trouble with this plugin with Sketchup 7.1.6860. It will change the precision but not the units.
Thanks in advance. Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Toggle Unitstry with these:
Re: [Plugin] Toggle Unitsmax, what problems is this new version supposed to solve? the copy I have installed works fine but for one thing: the buttons stay depressed even when you press a different one. by the way, I am on mac running the latest snow leopard.
Re: [Plugin] Toggle Unitsunfortunately i have no knowledge of macs so i'm not able to test - on my pc once the 'dec' is enabled the icons stray pressed when selected..
CadFather Somehow I missed this post. So today I tried this post. I now have a toolbar with no icons showing. It seems the icon should now be in another directory. I haven't moved the icons until I know this is what is at fault. Also, after selecting Fract in the plugin menu, the plugin stop working until I select to top selection. So was the attachment you had posted, was that for my problem or a MAC issue. And what happen to Matt666? Would like some help, I find this a very valuable plugin. Thanks in advance. Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Toggle UnitsHi all.
Sorry for the problems, and I don't have any time to search a solution... My work takes me a lot of time. I will try to see what does not work with this new SU update. Be patient please... Frenglish at its best !
Here's the working version. ![]() SketchUp Pro 7.1.6860 OS Windows 7 PC Re: [Plugin] Toggle Units
Matt I know work. Was busy until recently. So now I was presented with some down time and in the process of trying to take care of some problems I had let slip. Food and shelter is always first on my list. So Matt666, let me thanks you for the script again. blajnov, thank you for the updated. Not sure why I couldn't find this update on the site, but I couldn't. The scrip now works just like it did before. Not my plugin or my site, but maybe this update should go to the front of the topic. Anyway, again, thanks to all that helped. Now lets hope the new cap works and work can start again. Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Toggle UnitsPlease make your original post clearer (if editing is allowed on this forum).
2 files, same file name, no version control = confusion Re: [Plugin] Toggle Units
Hi -- I may not be understanding what this tool does, or how units work in Sketchup; I am frustrated because I can't do what seems to me a simple thing. Here is the deal. I am working on a model in non-metric units (feet and inches). But I have paper sketches from a colleague in Norway who has annotated his drawings in decimal meters. I'd like to reproduce his hand drawing directly into my model by copying it exactly, so I'd like to work on a set of components in meters or mm. To my surprise I could find nothing in Preferences for toggling from metric to inch and back. So I thought that Toggle Units plugin might enable me to switch the whole model from inch to mm or cm. I installed it. But it seems to toggle units only between different representations of inches (the first 4 buttons); the other buttons (mm, cm, mt) are grayed out and inactive. I really want to toggle between metric and inch -- is there no way to do this? it seems such an obvious thing to want to do ![]() btw I am aware that I can draw in any units I like, i.e. enter dimensions in notation like "3.0m". what I cannot do is use the Ruler tool to verify those dimensions after drawing, because the ruler is apparently hard-wired to inch units. if I could just toggle the Ruler between inch and metric that would be great! any ideas would be gratefully received as this has got me bogged down right at the start of the project. Nothing is 'mere'. -- Richard Feynman
I read backwards in this thread and found that others have had some trouble with Leopard (OSX) and this plugin. I grabbed a more recent version edited by Jim Foltz Oct 2009 and installed that. The Foltz version works except that the icons do not display: this I thought was because the icon paths were all set to CD_ICONS/TWEAK, but I substituted the correct path "toggle_units_icons" and I still get no icons in the toolbar. So I have to memorise the button sequence or wait for the balloon help to pop up ![]() If anyone can tell me why these lines of code
do not correctly association the png files with the button, I'd like to know (I don't speak Ruby obviously). meanwhile I'll happily use the version with anonymous blank buttons -- project no longer stalled! Nothing is 'mere'. -- Richard Feynman
Re: [Plugin] Toggle Unitsthe lines make sense if you have the corresponding folder (toggle_units_icons) in the plugins menu..
plugins menu? or plugins directory (folder)? that subdir does exist in the plugins directory (as do other subdirs of small images used successfully by other Ruby extensions). can't figure out why the images are not getting associated with the buttons. but hey, the unit switching function works and that's what I needed. I can fool around with the icons later. Nothing is 'mere'. -- Richard Feynman
Re: [Plugin] Toggle Unitssorry..
![]() if the path is right the icons should show up
as I say I do not speak Ruby, but I used to be extremely literate in Tcl/Tk and the syntax is not completely alien. I have tried various things, even using the full pathname. other .rb scripts are correctly finding their icons w/rel pathname starting at 'plugins', but this one for some reason is not. mysterious! I've looked for some initialisation that might set the default path, etc -- no luck so far. must be a very silly coding error that I can't see because I'm so unfamiliar with Ruby apps. checked the obvious like protection bits on subdir and images, checked that they really are .pngs, checked that they are not empty files, etc. baffled. oh well. something to fool with when I've nothing more urgent to do ![]() Nothing is 'mere'. -- Richard Feynman
Re: [Plugin] Toggle UnitsHave the same problem here also, the function was working perfectly, but the icon are invisible.. need some advice, please...
thanks, still so much to learn..
Re: [Plugin] Toggle UnitsWhat versions of Mac OSX are you running? I have Snow Leopard and the icons do show up for me. You might need to check View>Tool Palettes>Toggle Units to see them.
Re: [Plugin] Toggle Unitsim using xp sp2, and su 7.1, the tool actually already perfectly functional, just the icon not showed up..
already try to change the address on the script, but it still not working. ![]() still so much to learn..
Re: [Plugin] Toggle UnitsJust tried installing Toggle Units into my SU8 plugin folder, and found that the icons won't show up. Is this a known problem for SU8? If so, does anyone have a fix?
Kind regards, Bob |
Who is online
Users browsing this forum: anis07 and 18 guests
