SketchUcation Plugin Store
[Tutorial > Modeling] Slant Ramp Tut
Postby Gaieus » Thu Nov 15, 2007 4:55 pm
Hi Folks,
This is a simple tut I made for a guy who wanted something like this for his model railways at home.
Major tools
to use:
- Push/pull
- Rotate
- Scale
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Re: Slant Ramp Tut
Postby Edson » Thu Nov 15, 2007 4:55 pm
gai,
useful tut, thanks. my teacher experience asks me to question a few things, though. for ease of understanding's sake, that is. steps 4 and 5 are the crucial ones but they are not easy to grasp. perhaps my own limitation but i may as well tell you.
would you explain step 4 better? what exactly goes on there? you drew an arc joining 2 points at different heights, right? and then, what? i do not understant what you mean by snap and rotate.
step 5: i could not quite get what the text implies.
cheers.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
User avatar
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Re: Slant Ramp Tut
Postby Gaieus » Thu Nov 15, 2007 4:56 pm
Edson, thanks for pointing out the "weak" parts of the tut.
What I mean is that you start rotating the arc this way (step 4):
1) put the procractor to the left end of the arc
2) make sure to lock the rotation axis (in this particular case) along the green axis (click first on the beginning of the arc, then before releasing, pull it along the straight line which is in this case aligned to the green axis - when you see the procractor turn green, release the button)
3) grab the other end of the arc and start rotating downwards
4) rotate until you can snap it to the end of the lower, straight line.
Now we have the arc pointing from the end of upper straight line to the end of lower straight line - except the arc is shorter than it should be to actually reach this latter one.
Thus comes step 5
1) select the arc again,
2) select the scale tool
3) scale the arc to reach the end of the lower, straight line.
This point three needs a diagonal scaling (from the upper left to the lower right). So when you hover over the middle, green button of the scale box on the lower right edge, it will say "red blue scale about opposite point". Now grab it and pull your cursor to the point marked with the text tool.
You can snap the scale tool just as any other tool.
I hope, this helps. Maybe I'll take a couple of screenshots (and/or flash movies) to make it more clear.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Re: Slant Ramp Tut
Postby Edson » Thu Nov 15, 2007 4:56 pm
gai,
now you are talking! as clear as crystal. very clear explanation.
perhaps instead of additional shots you could just add the written explanation to the ones you already have (and then replace the file).
congratulations.
edson
User avatar
Edson
Global Moderator
SketchUp version: 8
License type: Pro
Re: Slant Ramp Tut
Postby Gaieus » Thu Nov 15, 2007 4:57 pm
Thanks, Edson.
But I'm afraid no such long text could fit into that small space in the SU text field.
I1ll see though.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Re: Slant Ramp Tut
Postby eugenesr » Sun Jan 13, 2008 3:20 pm
Gaieus wrote:Thanks, Edson.
I1ll see though.
Since I had no idea that there was any character limit in SU, I just cut and pasted the additional comments instructions into this tutorial, updated the scenes and, viola!
Thanks for all your great tutorials,
Eugene
RampTut-annotated.skp
/Fire Fighter! Funny job for an artist, no?/
HP laptop running XP
eugenesr
Location: Natick Massachusetts, USA (15mi west of Boston)
Re: Slant Ramp Tut
Postby Gaieus » Sun Jan 13, 2008 5:36 pm
Oh, Eugene, thanks for all this. I just totally forgot about this whole trhing... :oops:
as for the text length, it was partly a joke and also I just meant that the text is so long that it won't really fit on screen (I guess) :roll:
User avatar
Administrator
SketchUp version: 8
License type: Pro
Re: [Tutorial > Modeling] Slant Ramp Tut
Postby majid » Mon Jan 17, 2011 5:33 pm
recently I saw this..... verrry useful and simple, but not accurate enough ( as the arc must be helix-ed shape when see from side, but it remains arc again)
thanx again Gai
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Level of SketchUp: Intermediate
Postby simon le bon » Mon Jan 17, 2011 8:43 pm
Hi guys,
Dear Gaieus,
It is always a pleasure to follow your tuts. (thank you to give a SU6 skp )
As an exercise I had tried to find another solution:
Here is my alternate way:
Gaieus_RampTut_alternat.skp
Using:
Fredo's Curviloft and Joint PushPull
++simon
User avatar
simon le bon
Postby Gaieus » Mon Jan 17, 2011 9:08 pm
Thanks guys...
Majid; maybe not accurate but back in 2007, there were not so many excellent plugins to skin a helix very easily...
Simon: this is also the reason why it is still v. 6 - version 7 came out later (I think).
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby simon le bon » Mon Jan 17, 2011 9:30 pm
"by Gaieus on Thu Nov 15, 2007 5:55 pm"
:o I hadn't noticed the date :?
:lol: simon
User avatar
simon le bon
Postby Gaieus » Mon Jan 17, 2011 9:32 pm
by the way, Simon, why don't you upgrade to 8?
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby simon le bon » Mon Jan 17, 2011 10:04 pm
I have SU6 free and SU7 Pro on my big PC and SU8 free on my laptop...
SU6 Is ok for everything I do; have never used dynamic component and I prefer the behavior of SU6 PushPull tool.
I have bought for long Whaat's BoolTools, and actually nothing in SU8 free grab me more: I'm very sorry for that.
:oops: simon
User avatar
simon le bon
Postby Gaieus » Mon Jan 17, 2011 11:00 pm
Okay but now as the shadow bug is gone in SU 8, image export is possible at a much higher resolution etc., maybe it would still be useful.
Not to speak about some new generation plugins that may not work in earlier versions.
Sure I still have both version 6 and 7 installed, too.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby simon le bon » Tue Jan 18, 2011 12:13 am
And Ho!
I was forgetting the ability to record our toolbars position in 8: what had always put a lot of people and also me very out of serenity with the previous versions.
;) simon
User avatar
simon le bon
Postby majid » Tue Jan 18, 2011 12:15 am
Gaieus wrote:Thanks guys...
for sure your tut is veeeerrry handy and easy to follow :thumb:
@ simon : thanx , but the non-accuracy exists here again
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby simon le bon » Tue Jan 18, 2011 8:16 pm
Hi Majid,
Can you explain a bit more I'm not sure to understand completely what is the problem. :shock:
++simon
User avatar
simon le bon
Postby majid » Fri Jan 21, 2011 9:14 am
dear Simon
I've attached a file that shows a real pont to point modeled rapm, and a tricky fast way ramp on(Gai trick) that clearly shows the difference.
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby simon le bon » Fri Jan 21, 2011 12:38 pm
Dear Majid,
Your "point to point modeling" is perfect to draw a real helix!
But in our specific case, as we need the curves to be tangent to the horizontal planes this pure helix doesn't work very well. Am I once again missing something?
Cheers,
Simon.
User avatar
simon le bon
Postby charly2008 » Fri Jan 21, 2011 5:15 pm
Hi Simon,
simon le bon wrote:But in our specific case, as we need the curves to be tangent to the horizontal planes this pure helix doesn't work very well. Am I once again missing something?
The best result I achieved with the Arc tool and followme and keep. The arc was divided to 48 sectors. The end of the ramp is then still not tangential but the transition to the horizontal is optimized.
Charly
More dangerous than ignorance is the illusion of knowledge
User avatar
charly2008
SketchUp version: 7
License type: Pro
Postby majid » Fri Jan 21, 2011 6:22 pm
thanks charly.it's ok.
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby mitcorb » Fri Jan 21, 2011 8:41 pm
"Slant Ramp Tut" that's bound to offend somebody somewhere, sometime. Perhaps on Tralfamadore?
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby simon le bon » Fri Jan 21, 2011 8:48 pm
Thank you Charly!
->applying your solution with FollowMeAndKeep .
How have you made the path?
Here I have applied my first solution:the 48s arc and two edges drawn on the ground, then the left edge selected and moved up!
This seems to me to be good but! may be Majid will object something. There is something in the problem I don't understand. :oops:
Simon.
User avatar
simon le bon
Postby majid » Sat Jan 22, 2011 3:56 am
my only objection is : by moving up/dn and scaling an arc, we will not reach a helix, while mimicing it, BTW if we need a ramp that is tangented to horizon start, it is a fast way.
(also I am aware of draw helix, and FaK plug) .apart from them and using native SU, there are only 2 ways in my sight, point to point , and tricky Gai way.
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Gaieus » Sat Jan 22, 2011 11:08 am
Yeah, back then there was no Follow me and keep so one would either use helix.rb (which existed) and painstakingly connect the endpoints or do some trick to mimic something in a faster way.
I ma glad though that I started to learn SU back when there were not so many, excellent plugins as nowadays. It forced me to find out workarounds and if nothing helped, there was always "had stitching". I think this approach would still be useful for many newbies before they rely themselves to the easiest methods with plugins.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby majid » Sat Jan 22, 2011 12:24 pm
yea Gai, agree with you... as somewhere Solo called plugins as "drugs"... relying on them is not always fair, specially for noobs. I've experienced that using plugs is even confusing for noobs in some cases (using "tab" ,"F3", "F4",...in different plugs is really confusing. hope we had saome "standards".)
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby majid » Thu Dec 06, 2012 6:26 pm
I have prepared another "Smart" solution. as nowadays I have a trend to avoid using Plugins.
hope you like it
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Return to SketchUp Tutorials
Who is online
