SketchUcation Premium Membership
[Tutorial > Texturing] Texturing an arch - #2
Postby Gaieus » Sun Jan 09, 2011 8:39 pm
After ThomThom came out with his brilliant UV toolkit plugin, I immediately thought of using it for arches and came out with this little tutorial.
Now as UV Toolkit 2 ("experimental") is out, this opens new horizons in texturing bent faces like arches and such. Here is another little, step-by-step tutorial on how to achieve an arch-like shape with correct texture maps. I finally ended up with a half arch only (as my starting shape was not long enough for a nice, full arch) but then I did not want to restart the whole process.
Texturing an Arch in SketchUp
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Re: [Tutorial > Texturing] Texturing an arch - #2
Postby Rich O Brien » Sun Jan 09, 2011 9:32 pm
Top class :thumb:
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby massimo » Tue Jan 11, 2011 2:07 pm
Nice one Gai. Thanks.(Thanks to ThomThom too obviously) :thumb:
Followed carefully the tut, however I'm only able to get what you see in the picture. What I'm doing wrong?
-apply the texture;
-draw the mortar's lines;
-hidden geometry on;
-ctrl+eraser on the lines;
-hidden geometry off;
-select the surface with the texture with one click;
-UVtoolkit-->remember position;
-bend the pillar;
-UVtoolkit-->restore position.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby Gaieus » Wed Jan 12, 2011 12:16 pm
Hi Massimo,
Can you attach the skp file (preferably before the bend)?
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 12, 2011 12:23 pm
HI Gai, here you have a model before the bend and before the UVtoolkit-->remember position.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby Gaieus » Wed Jan 12, 2011 12:31 pm
Hm. To me, it seems to work correctly. I am on SU 8 however - don't know if that makes a difference (should try on 7 as well).
The bend is a bit funny though as only the front face was subdivided :)
(This should obviously not have any effect on the UV part)
Reason: "Downgraded" file to version 7 - sorry
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby Gaieus » Wed Jan 12, 2011 12:39 pm
I tried in v.7 and it worked correctly, the same way.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 12, 2011 12:40 pm
Have tried also with all faces with subdivisions, but the result is pretty the same. Also the result seems a bit unpredictable: sometimes nothin happens after UVtoolkit-->restore position. Maybe SU 7 is the culprit. Thanks anyway. :)
Edit: Oh you're too fast! So it's not SU7.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby Gaieus » Wed Jan 12, 2011 12:44 pm
Here is the file saved after bending but before restoring the UV's. Try to restore from here so that we see where are the steps that went wrong.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 12, 2011 12:47 pm
Wait...Found it. I'm used to press F4 before bending in order to have subdivisions. If you do that it doesn't work. Thanks for the help. :)
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby massimo » Wed Jan 12, 2011 1:03 pm
And it works also with multiple faces selected. :thumb: Even if you will need some adjustment on the corners in this particular case.
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby Gaieus » Wed Jan 12, 2011 1:10 pm
massimo wrote:Wait...Found it. I'm used to press F4 before bending in order to have subdivisions. If you do that it doesn't work. Thanks for the help. :)
In the release notes it says that once you add new geometry after remembering the UV, the data is lost. This is why we need to subdivide first and remember next.
It would certainly be awesome if it somehow could remember UV's after modifying the mesh (by adding/removing faces). Maybe one day...
massimo wrote:And it works also with multiple faces selected. :thumb: Even if you will need some adjustment on the corners in this particular case.
Yeah. I just select all (of the column) and run the plugin on the whole selection (including all sides).
Did I mention that it's an excellent plugin?
_______
Also, it does not only work on quad faces but on triangles, too. This is very important as some operation may add further subdivision by triangulating (imagine a twist for instance)
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 12, 2011 1:19 pm
Yeah, you did... :lol:
Indeed. ;)
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby Gaieus » Wed Jan 12, 2011 1:23 pm
Now twisted AND bent. :shock:
(This definitely needs pre-triangulation as it would be triangulated by the twist anyway)
Incredible! :sketchstatic:
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 12, 2011 1:29 pm
So Gai now we are waiting for a model of this... :lol:
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby Gaieus » Wed Jan 12, 2011 1:35 pm
Ah, Bernini... I have not always liked that deep Baroque but nowadays I am fine with it...
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 12, 2011 1:43 pm
Yeah, I always preferred Borromini (who also worked a bit at that baldaquin anyway). ;)
User avatar
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby thomthom » Wed Jan 19, 2011 9:24 am
I pitty the brick builder. :D
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby dominion » Thu Jan 20, 2011 9:44 pm
Sorry to be dumb but how do you subdivide? is it a plugin?
dominion
Postby Gaieus » Thu Jan 20, 2011 9:47 pm
I just copied the bottom edges along with a linear array (Ctrl+ :move: )
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby dominion » Thu Jan 20, 2011 10:15 pm
er if i do that it creates faces for each section of the texture, your 2nd image shows it as one face and your first shows dotted lines for the divide my has sild edges?
dominion
Postby Gaieus » Thu Jan 20, 2011 10:25 pm
Yes, I softened those edges so that when I turn off hidden geometry (which you can see in the first image as dotted), I can select the whole surface as one. If you select all after the array operation and right click > soften edges, check the "soften coplanar edges" box at the bottom right of the dialog.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby dominion » Thu Jan 20, 2011 11:03 pm
Ah I get it thanks
dominion
Postby Gaieus » Thu Jan 20, 2011 11:05 pm
So how is it going? Let's see some interesting results (I always make boring vaults only although now there is also a sugar cane I made this way)
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby dominion » Thu Jan 20, 2011 11:15 pm
hohum not working, done it all but when i click restore uv it does nothing at all :(
dominion
Postby Gaieus » Thu Jan 20, 2011 11:16 pm
Have you got the original (not-yet-bent) shape?
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby dominion » Thu Jan 20, 2011 11:37 pm
yea got it fine looks exactly as in your tut
dominion
Postby Gaieus » Thu Jan 20, 2011 11:54 pm
You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby dominion » Fri Jan 21, 2011 10:21 am
i can do the bend its just the uv restore that does not work
dominion
Postby thomthom » Fri Jan 21, 2011 10:26 am
dominion wrote:i can do the bend its just the uv restore that does not work
If you open the Ruby Console - does it give you an error?
If not, any chance you can do a video capture`?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Next
Return to SketchUp Tutorials
Who is online
Users browsing this forum: trannhutarchitect and 3 guests
