SketchUcation Premium Membership
[plugin] realSection v0.6 Béta (Updated 31/12/10)
Postby GWD » Mon Dec 20, 2010 4:17 pm
Do you want to create real sections with different materials through your SketchUp models like this?
Use the new realSection plugin!
For installation:
unzip the files in your plugin directory
In the UserGuide you can find a brief explanation how to use realSection, you also can find a little movie that shows how realSection works http://www.youtube.com/watch?v=Z31yMxiYzdM
In the the realSectionDemo.skp you find good architectural sectionmaterials that you can use for making your realSections
GWD
Re: [plugin] realSection v0.3 Béta
Postby Didier Bur » Mon Dec 20, 2010 5:14 pm
Can't wait to try it out, looks amazing (and useful !) :bounce:
Only works with SU8, right ? (because it applies to solids only)
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby GWD » Mon Dec 20, 2010 5:20 pm
Didier Bur wrote:Hi,
It's very useful. We use it already for about 6 months at our office.
GWD
Postby Chris Fullmer » Tue Dec 21, 2010 1:46 am
Looks great, I just came across a big project where I need this starting at the beginning of the year. I'll be checking this one out soon, thanks!
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby GWD » Tue Dec 21, 2010 1:47 am
Didier, it should work also on v7. I don't use any of the solid functions. But i didn't test it on v7.
GWD
Postby GWD » Tue Dec 21, 2010 2:17 am
GWydouw wrote:But i didn't test it on v7.
I just did a test on v7 and it give some errors. I try to fix this errors.
GWD
Postby Ken » Tue Dec 21, 2010 3:28 am
OK, history first. I have just installed Windows 7 professional from Vista Home Premium. I had to do a complete install as one can not go from Vista Home Premium to Windows 7 Professional by the upgrade route.
Now to today. I installed the plugin realSectionV0.3, just to see what it would do. I decided to remove the program. And here where I have the problem. I have removed all the files that were in the zip file, however, when I open Sketchup, and do a context menu selection, I still have, although greyed out, the menu option of define RealSection material. I cannot find where this program is being installed from. I have restarted the computer, searched the plugin directory and no luck.
So what is happening? I am new to Windows 7. So any help would be appreciated. Another question, has anyone else trying uninstalling this plugin.
Thank you in advance for any help or direction.
Ken
Government rushes to help the irresponsible and does little for the responsible.
User avatar
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby unclex » Tue Dec 21, 2010 4:13 am
Can't Choose Materials...
unclex
Postby GWD » Tue Dec 21, 2010 4:19 am
unclex wrote:Can't Choose Materials...
Did you use the demo file?
The name of the materials that you will use for the section need to start with '_' like '_concrete'
The materials are the standard SketchUp materials that are active in the model.
I see you work with SU 7, at this moment realSection won't work with v7. I hope I can fix the problem with SU 7 very soon.
GWD
Postby Didier Bur » Tue Dec 21, 2010 9:54 am
A registry key left by the script ? GWydouw, any hint ?
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Dec 21, 2010 10:27 am
Ken wrote:Now to today. I installed the plugin realSectionV0.3, just to see what it would do. I decided to remove the program. And here where I have the problem. I have removed all the files that were in the zip file, however, when I open Sketchup, and do a context menu selection, I still have, although greyed out, the menu option of define RealSection material. I cannot find where this program is being installed from. I have restarted the computer, searched the plugin directory and no luck.
Do you have the Windows UAC enabled, or run as a User?
When you have the plugins folder open in Explorer, do you see a Compatibility Files button in your toolbar? It's possible some files have ended up there.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Ken » Tue Dec 21, 2010 11:42 am
Well, thomthom, that was it. The compatibility folder had the files stored there. When I removed these files, the plugin is gone. And of course the compatibility folder does not show up in the regular Windows Explorer view.
It was my understanding that the "compatibility" of Windows 7 was for program installation. It never dream on me it would hide extracted zip files.
However, that explains to me why extracting the files did not seem to work. I couldn't find the files after the first extraction, but the during the second extraction, the process ask if it could write over the files. To get the files showing up in the plugin folder, I had to copy the files. So Windows 7 was giving me a hint, but I just didn't understand what was happening.
Hope, this helps other.
thomthom, again thank you.
Ken
User avatar
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Dec 21, 2010 12:10 pm
Good to hear it worked out. :thumb:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby unclex » Tue Dec 21, 2010 2:37 pm
thank u replied
i use SU8Pro
i can see the demo's section, but can't use it
and ur plugin can't work with thearender4su plugin
unclex
Postby GWD » Tue Dec 21, 2010 5:15 pm
thank u replied
i use SU8Pro
What do you mean with 'can't use it'?
What do you mean with 'can't work with thearender4su plugin'?
GWD
Postby unclex » Wed Dec 22, 2010 4:53 am
thank u replied
i use SU8Pro
Perhaps thearender4su plugin is not the reason
sometimes " Define real.... ", it's grey, "can't work", i mean it
sometimes " define real..." is grey, sometimes isn't, it's joking me?
but i don't know, how to make section plug worked , i mean show the materials on the section.
unclex
Postby GWD » Wed Dec 22, 2010 11:31 am
Can you send me the model and some screenshots of the problem?
GWD
Postby Humpmetwice » Wed Dec 22, 2010 4:53 pm
I can't seem to get it to work right myself with the materials. Do you have to type in the name of the material that you want to use? A demo video would help to enjoy this plugin a whole lot more since I have been needing such a plugin for a while now! Thanks anyway, I guess I will figure it out one day?
User avatar
Humpmetwice
Postby errror404 » Wed Dec 22, 2010 8:06 pm
hello,
I'm trying to test this great plugin, but I'm having some dificulties:
1- I created a group (a simple solid object)
2- Then I created a texture that started with "_"
3- I assigned the material to the object using "Define realSection material"
4- I created a section plane
5- pressed "Make realSection" and gave it a name
but nothing happens... and no new layers are created?!
I'm using SketchUp 8 (free) on a windows machine (XP)
errror404
Postby GWD » Wed Dec 22, 2010 8:15 pm
errror404 wrote:hello,
Can you send me the model?
GWD
Postby GWD » Thu Dec 23, 2010 9:27 am
I made a little movie to show how realSection works:
GWD
Postby ladcwei » Thu Dec 23, 2010 1:47 pm
I really like this plugs,however,it can't work at 7or8,waiting for its rebirth... :bounce:
ladcwei
Postby GWD » Thu Dec 23, 2010 2:21 pm
ladcwei wrote:I really like this plugs,however,it can't work at 7or8,waiting for its rebirth... :bounce:
please give me some feedback why it's not working? It should work a SketchUp 8 english.
GWD
Postby errror404 » Thu Dec 23, 2010 2:48 pm
It was just a box...
It didn't work on your example model either (if I tried to make a new section)
I would try later at my home computer (SketchUp Pro)
Now, after looking at the video I did notice something diferent... when I make a section my model shows up hallow inside (before and after I pressed "Make realSection" )
do I need to change some type of option in sketchup?
thanks!
errror404
Postby Dave R » Thu Dec 23, 2010 2:59 pm
Any chance you could actually tell us what you are doing in the video. It's difficult to read the menu items and so on due to the compression of the video.
I'm trying to follow your PDF instructions. When I choose Make realSection, I can give the section a name but there's no new layer created as stated in the instructions. I think there are enough folks having difficulty getting this to work that there must be a defect that needs to be fixed.
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby GWD » Thu Dec 23, 2010 3:20 pm
Dave R wrote:Any chance you could actually tell us what you are doing in the video. It's difficult to read the menu items and so on due to the compression of the video.
what's in the video:
make a solid
right click at select 'Define realSection material'
cancel the define realSection material
create a new SU material named '_newmaterial'
right click at select 'define realSection material'
select the new created material 'newmaterial'
define a sectionplane
right click selectionplane and select 'Make realSection'
realSection is created
select solid again and define an other material
show sectionplanes
select sectionplane
right click and select 'Update realSection'
realSection is updated
edit solid
show sectionplanes
select sectionplane
GWD
Postby GWD » Thu Dec 23, 2010 3:26 pm
If I know what's going wrong then I can fix it. Can you open your ruby console when you are trying to run realSection and give me the errors that show up.
regards,
Guy
GWD
Postby errror404 » Thu Dec 23, 2010 3:38 pm
regards,
Guy
Code: Select all
748115
748123
Error: #<NoMethodError: undefined method `hide_Outliner_MI' for RealSections:Module>
(eval):614:in `updaterealSection'
(eval):774
errror404
Postby Dave R » Thu Dec 23, 2010 3:42 pm
At Define Material
Code: Select all
748115
748123
At Make realSection
Code: Select all
(eval):1722:in `updaterealSection'
(eval):1882
(eval):1722:in `call'
(eval):1722
At Show realSection
Code: Select all
748115
748123
At Update realSection
Code: Select all
748115
748123
(eval):1894
(eval):1722
FWIW, the Outliner wasn't open to begin with.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby GWD » Thu Dec 23, 2010 3:44 pm
Dave R wrote:At Define Material
Code: Select all
748115
748123
At Make realSection
Code: Select all
(eval):1882
(eval):1722
At Show realSection
Code: Select all
748115
748123
Code: Select all
748115
748123
(eval):1894
(eval):1722
Thanks I try to fix it asap
GWD
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], flashzs, inasia777, RW and 8 guests
