[Plugin] Smoothstep Animation
I made a small change to Whaat's code so it pads the filenumbers with leading zeroes, I hope you don't mind.
Just change this line (line 107):
@image_path=File.join(@export_path,@filename+"#{@frame}"+".#{@format.downcase}")
to this:
@image_path=File.join(@export_path,@filename+"#{@frame.to_s.rjust(10, '0')}"+".#{@format.downcase}")
Thanks for the plugin Whaat! Best regards.
I've been trying this out and had two very different results re: output quality (they're both up on youtube, link to one here...
Youtube Videothe first was made was made manually from 12 layers containing 12 instances (re-named) at 15ΒΊ of rotation, made using xformclone.rb (fantastic...)
I tranfered this at (640x480 12 fps jpg >1) into iStopmotion so I could remove the 6-8 dead frames between each layer swop, I also batch cropped, and did a half speed test by dropping more frames, I'm very happy with the results...
the 2nd was a linear motion test with a single incident component (but much hire poly-count), on only one layer. Steps were achieved using mover.rb and tying the object to and the green axis with the rotate tool, scroll wheel clicks were used for spacing... the movement look acceptable on screen but SU frose when transferring at the previous settings... I turned the frame rate up... and then down... crashed SU... I removed xformclone and standard views just in case, sill frose during transfer, I then stripped out the clip, used your default settings and finally got a set out..
Each try did output jpgs, all of equally bad quality, any thoughts?
I tend to think that more organised layering(with sub folders) will always give a better quality result, if you take out the lag or play to it.
I haven't tried out putting with proper_animation.rb yet as I needed to get my head around the basic functionality of using scenes first.Anyway I was very impressed with output quality on the first one and for any mac user iStopMotion and iMovie make post-production and posting to YouTube a breeze..
cheers
Hey guyz
I know this is an old thread, but just for you to know...
Was looking for a plugin to animate objects, and I found Properanimation.rb by morisdov
This is a very cool plugin but did not have any way to export, native SU export engine did not support it. There are hughe threads about this issue, other people was considering to make screencapture videos, or get fancy external render engines.But guess what...?
Smoothstep Animation not only exports smooth camera scenes, it also recognizes all Properanimation.rb animations.....!!!!
So if you are looking for a cool tool to animate objects, try both plugins
Properanimation.rb + SmoothstepAnim.rbUploading utube
http://www.youtube.com/watch?v=UL6tnTvphAE
Done -
@rickymon said:
Hey guyz
Donebut how did you get to export all geometry, cause i thought he said i could only export images???
@rombout said:
@rickymon said:
Hey guyz
U can make a video out of a sequence of images, twhat I didnt knew is that both plugins were compatibles. So u dont need any fancy external engine to export smooth transitions and object animation. Unless u wanna go photorealistic. }
I made as well some small change to the script, I hope you don't mind.
Added support of saving the Export Property's to the Model.
If you cancel the export dialog or the save dialog the script stops instantly.
And reduced the filenumber padding to 6 numbers.
And my first Animation with Properanimation + SmoothstepAnim http://www.youtube.com/watch?v=agCUtjEJssM
Is it a similar plugin to this one http://forums.sketchucation.com/viewtopic.php?f=323&t=33417 ?
thanks jackson
@jakson said:
Thanks Jackson, I wish I can learn to do those scripts too
uploaded another test...take care
GREAT!!!
Best plugin ever!!
Solved all my problems.Congratulations!!!
Quicktime all the way. It works fast and does a very good job.
Thank you very much : )
i think it very work
Wow, great!!!
Whaat, many many thanks for this and the person who replied to my post solving my little artifact problem that the programmers appeared not to be interested in fixing. Great script!
how to install on mac..?
same as any .rb files & theres lots of info on this forum.
download from the first post in this thread, move to 'plugins' folder
if it's hidden you can paste this into 'Ruby Console' under 'Window' menu in Sketchup`open "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins"`
, then hit return/enter
drag the ruby in and restart SU.
john -
thanks for the brilliant plugin!!
using Proper Animation, Smoothstep & Adobe Lightroom and getting an excellent video
is there any chance of adding support for exporting TIFF files?thanks
@pixero said:
Thanks for a great script.
Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
I believe this would make it work with external renderers.
What do you think, is it doable?dear sir ,
i m pritish from india , trying to render animation with vray can you make tutorial or may be some image/video format to explain your thoughts,it will be helpful .
waiting for your replay.
thanks in advance.regards,
pritish
