SketchUcation Plugin Store
[observer issue] onEraseEntities not working?
Postby dereeei » Wed Nov 24, 2010 2:30 am
I made some tests with EntityObserver and EntitiesObserver classes and it looks like onEraseEntities method doesn't work, or I don't know how to use it?
I tried the same thing with onEraseEntity and it works.
This didn't worked. Nothing happens
Code: Select all
class MyEntitiesObserver < Sketchup::EntitiesObserver
   def onEraseEntities(entities)
      puts "Erased: " + entities.to_s
begin
x = 0
   Sketchup.active_model.entities.each do |e|
         e.add_observer(MyEntitiesObserver.new)
         x += 1
   puts 'Observer was added to ' + x.to_s + ' elements.'
This told me what I wanted to see:
Code: Select all
class MyEntityObserver < Sketchup::EntityObserver
   def onEraseEntity(ent)
      puts "Erased: " + ent.to_s
begin
x = 0
      e.add_observer(MyEntityObserver.new)
      x += 1
dereeei
Re: [observer issue] onEraseEntities not working?
Postby thomthom » Wed Nov 24, 2010 9:20 am
I've not had that event working either. The EntitiesObserver has been trouble since the beginning.
What SketchUp version are you testing on? There has been some changes in SU8.
See this chart where I've tried to map the functionality of each event in the various SU versions: http://www.thomthom.net/software/sketch ... esObserver
(Note that the chart is probably not 100% accurate so if you have more info I'd be very interested in this.)
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby morph » Wed Mar 14, 2012 6:54 pm
to thomthom
I interest to use EntitiesObserver.onElementModified or EntityObserver.onChangeEntity to check face entity has modified or not?
But after I read the illustrate under both method from https://developers.google.com/sketchup/docs/ourdoc/entitiesobserver ("The onElementModified method is invoked whenever one or more elements in the collection are modified.") and https://developers.google.com/sketchup/docs/ourdoc/entityobserver ("The onChangeEntity method is invoked when your entity is modified.")
I can not understand the scope of meaning of modified state of face entity. The word "modified" mean scaling, moving, reverse, split or more. I am new in programming, please suggestion.
Hope you will understand my question?
morph
Postby Dan Rathbun » Thu Mar 15, 2012 12:10 am
That's interesting.. I did not realize we could make code blocks have smaller text.
User avatar
Dan Rathbun
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: education
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: No registered users and 3 guests
