SketchUcation Premium Membership
V-ray questions
Re: V-ray questions
Postby thomthom » Thu Apr 30, 2009 8:25 pm
Hm... I tried loading the same file twice on the same computer, and I saw no issues. I'll see if I can install the trial on my other computer and try to open on two separate machines.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: V-ray questions
Postby solo » Thu Apr 30, 2009 8:42 pm
Thank you very much, I would not bother but I have a model that took me ages to make before my computer died of a static shock, fortunately I had saved it to my server but now i't's useless as it has over 70 textures yet in Vray it only shows one.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Re: V-ray questions
Postby thomthom » Thu Apr 30, 2009 8:51 pm
Hm.. Sounds like a bug. You could send the model to ASGVis and have them take a look at it.
What you could do, if most the materials where plain material with only a diffuse layer, is delete the V-Ray attributes in the model and then reload the model. That might force V-Ray to reread the materials.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby solo » Thu Apr 30, 2009 9:03 pm
I doubt it's a model bug as all my models that I have previously modelled and rendered with Vray have the same issue.
The model in question had more than diffuse I had bumps, reflections, etc.
I think it may be a texture mapping issue, a mydamhihad it's texture folder in a different location to my new one.
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: V-ray questions
Postby kalu » Thu Sep 03, 2009 8:09 pm
solo wrote:Damien, thank you for taking the time out to explain some of the technicalities of Vray and welcome to SCF.
It's always a good thing when developers are able to consult and advise on open forum, I know you are very active at ASGvis and glad you have also 'broken the seal' here too.
My next question is regarding displacement (I'm sure that this is a well covered subject on the vray site, but for those who are new or in a deciding capacity as far as render engines goes I will ask my questions here)
I have been trying to master displacement on simple objects before using it on any real projects, I have noticed that it totally kills render times which is expected and in line with most other render apps. I have found a few strange behaviors however, below is a simple SU model with a grass displacement on it, it rendered perfectly the first time but when iI decided to add the white band the render was flat without any displacement, I then made the band a group and rendered and it worked again giving me the result below. My question is... does the grouping of two material adjacent to another where one is displaced and the other not have any significance?
There is anyway that you put for all the settings for this excellent way to make grass in your worm. Kind to step by step to make displacement. I look in the web and asgvis and is not very clear how I can get this awesome results, Please need help ASAP with this I have a presentation in my college.
thanks.
THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
User avatar
kalu
Operating system: Mac
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby solo » Thu Sep 03, 2009 8:12 pm
Kalu
I'd love to but I unfortunately was using a trial version which has expired a long time ago, I'm sure that one of the many Vray guys here will be able to help.
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: V-ray questions
Postby kalu » Thu Sep 03, 2009 8:52 pm
solo wrote:Kalu
Hi SOLO,
Thank you for your quick response, I've try and try for 6 hours with many options and I not close to this results. I post the help in ASGVIS forum and I hope someone come out with the exact help.
Also are you the same guy in the PODIUM forum? I am there since they started the soft.
Kalu.
PS. PLEASE any help ASAP I appreciate!!!!!!!
User avatar
kalu
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby solo » Thu Sep 03, 2009 9:32 pm
Kalu, I'm sure someone there will be around soon enough to give more help.
Yes, that's me.
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: V-ray questions
Postby steelers05 » Tue Sep 08, 2009 7:05 pm
just got a chance to read through this thread...Solo, have you solved your recent problem? I am not sure if i am understanding this completely but it sounds like you took a model to a new computer correct? Vray is very similar to the way autocad handles xreferences (if that sounds familiar?) and you need to have the root files in the original location that they were when you first applied them. I hope that helps?
steelers05
Re: V-ray questions
Postby solo » Tue Sep 08, 2009 7:12 pm
Steelers, I did actually solve it, but that's in the past as I was running the trial version, maybe when the economy picks up or I will look into spending the money to buy Vray 2.
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: V-ray questions
Postby 21D » Sun Jan 03, 2010 10:10 pm
solo wrote:Last one for the displacement tests, using a single face (no thickness) with a texture and displacement.
I believe displacement is under the belt, now the next thing I need to get a grip of is D.O.F, anyone got any good tips that can help?
Hi there SOLO, first off, really great results there,
second would you mind sharing the SKP of the rug also so i can dissect the vray settings and the disp image??
"I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
Le Corbusier
21D
Name: Rachid de Wind
Re: V-ray questions
Postby solo » Sun Jan 03, 2010 10:20 pm
Rachid, I will take a look for it tommorrow (it's on an old machine)
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: V-ray questions
Postby 21D » Sun Jan 03, 2010 11:02 pm
solo wrote:Rachid, I will take a look for it tommorrow (it's on an old machine)
hey thnx mate, don't worry i don't mind the wait,
they say "great things come to those who wait" :P so i do qualify for that hahaha
thnx again mate
Le Corbusier
21D
Re: V-ray questions
Postby edu1987 » Sat Jan 09, 2010 4:58 am
how can i get rid of that white spots? im using irradiance as primary and light cache as secondary engine everything else as default settings.
always be psycho about perfection
edu1987
Re: V-ray questions
Postby thomthom » Mon Jan 11, 2010 11:40 am
A quick-fix is to Clamp Colors under Color Mapping.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby solo » Mon Jan 11, 2010 11:47 am
Rachid, I cannot seem to find that carpet scene any more, I can give you the maps however, in the zip file is a normal, diffuse, specular and displacement map.
My site
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: V-ray questions
Postby 21D » Tue Jan 12, 2010 4:20 am
solo wrote:Rachid, I cannot seem to find that carpet scene any more, I can give you the maps however, in the zip file is a normal, diffuse, specular and displacement map.
Just now noticed that you posted Pete,
thnx for the help,
having the maps i can play around with them to find as close as result as you mate, so don't worry about the scene ;)
thank you again for the help mate
Le Corbusier
21D
Re: V-ray questions
Postby edu1987 » Tue Jan 12, 2010 9:11 pm
solo wrote: I can give you the maps however, in the zip file is a normal, diffuse, specular and displacement map.
I downloaded the carpet too thks Solo, but what is the carpet773_NORMAL image for? and also were do u put the specular image? In the fresnel color or in the highlight and reflection glossiness there is kind of a debate in that.
edu1987
Re: V-ray questions
Postby edu1987 » Tue Jan 12, 2010 9:14 pm
thomthom wrote:A quick-fix is to Clamp Colors under Color Mapping.
Hmm...thought that only worked with colors :D will try then thks
edu1987
Re: V-ray questions
Postby wahoowetzel » Fri Feb 12, 2010 10:57 pm
edu1987 wrote:how can i get rid of that white spots? im using irradiance as primary and light cache as secondary engine everything else as default settings.
I'm using the same primary and secondary engines and I seem to get these white spots whenever I have the reflection glossiness set to anything less than 1 (lower gets worse I think). What is the cause/solution to this?? I basically just want a material that that is reflective but not like a mirror, is that so hard? :cry:
wahoowetzel
Re: V-ray questions
Postby wahoowetzel » Thu Feb 18, 2010 1:57 am
I've been using vray for 3DS max for about 4 years now, I've been using VfSU for about 2 months and I'm having some issues with graininess. I haven't had this issue with max, so I'm wondering if you guys can help me.
I'm looking to get a metal material like a aluminum or steel with a powder coat finish. So something that is reflective, but not like a mirror. I'm modeling mullions and garage doors using this material. Here are some pics of the material in context:
I know there are a lot of settings that effect the materials and how they render out. I've done a bunch of tests using different environment settings and I've tried several material adjustments. But if any body out there would so kind or interested in helping me out, I set up a test file using the same materials I'm using in my scene.
I want to say it's either a shadow related setting in the environment rollouts, or I'm just plain screwing up the material for some reason, either way I could use some help. Thanks!
wahoowetzel
Re: V-ray questions
Postby vidy » Mon Mar 01, 2010 5:10 am
perhaps something like this (using vray 1.5)
It's a bit strange coz, SU can't update the material as seen on my render image, anyway here's the file.
still so much to learn..
vidy
SketchUp version: 8
License type: Pro
Level of SketchUp: Beginner
Re: V-ray questions
Postby wahoowetzel » Wed Mar 03, 2010 7:09 pm
Hey thanks for the test. Did you adjust the lighting/shadow settings?
The client was happy with the images that I got out. It was not the most design rich project I've worked on, but a great exercise to try out the new vray. There were definitely ALOT of growing pains with the new release, but I have to admit, I'm addicted to the ease of alpha transparency support.
Take a look, feedback is more than welcome. I could not have done it without the help of you guys in the forum.
wahoowetzel
Re: V-ray questions
Postby vidy » Fri Mar 05, 2010 8:53 am
you're welcome wahoo, yes i thought i was change a bit about physical camera option, hopefully it recorded on my file, coz sometimes vray for su forgot about the setting when we move the file to other computer :roll:
bytw, is the image you posted originally from the vray su render? well, i think, it will be better if you play a bit on PS (or image editing software) to tweak for brightness and contrast of the image.
nice project bro..
regards,
vidy
vidy
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby BigTom » Thu Nov 11, 2010 4:33 pm
thomthom wrote:A slight variation:
Bumpmap: Blend
- Texture A: Noise - Size: 50
- Texture B: Bulge
Blend Ratio: 0.25 (75% Texture A)
This just add the slight bulging which you often see in windows.
What layer are you placing this bumpmap to? I've looked through this thread and I haven't been able to find it exactly. If there is another thread which explains it I'll gladly go there.
BigTom
Re: V-ray questions
Postby thomthom » Thu Nov 11, 2010 4:54 pm
Bump map isn't a layer of its own - but a map applied to the material. Look at the bottom of the material properties in the VfSU editor. You have a bunch of checkboxes and map slots.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby BigTom » Thu Nov 11, 2010 6:00 pm
I need to set the UVW Type to UVWGenPlanarWorld for both Texture A and Texture B?
For Texture A use the default Noise settings? There are so many I'm a little perplexed by them.
Use the default Bulge settings in Texture B?
BigTom
Re: V-ray questions
Postby BigTom » Fri Nov 12, 2010 7:42 pm
I got it to work! Thanks THomThom - your posts have been a big help and I've gotten closer to mastering this skill.
I'm still left trying to understand all the many parameters available in the materials panels. The TexNoise, TexBlend etc have so many posible variables and the operator manuals I've read don't address them all. (things like amplitude, frequency, persistence, inflection, bias, etc)
Can anyone recommend resources that help to explain the vray materials and texture panels parameters fully?
BigTom
Re: V-ray questions
Postby thomthom » Fri Nov 12, 2010 7:50 pm
I'm a wee bit confused to all them myself to be honest... :? Essentially with the latest release where we have all these new procedural maps.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: V-ray questions
Postby BigTom » Fri Nov 12, 2010 8:01 pm
UhOh - if you don't know these things it seems that much more daunting!
BigTom
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to V-Ray
Who is online
Users browsing this forum: No registered users and 2 guests
