[Plugin][$] Tools On Surface - v2.5a - 22 Apr 21
Hi, Did you find out the answer to your question - I have the same problem and havent figured it out yet.
the first post doesnt make any references to libfredo...
this is a life saver man!!!
you rock Fredo! -
Hey! I'm new member at Sketchucation. Wonder how I can get the plugin "Tools on surface"
regards /Banjo
@hassanykb said:
:ecstatic: this is a life saver man!!!
you rock Fredo! -
Hi Banjo,
Download it from the first post of this topic.
why does it say there's an error???
Error Loading File ZLoader__OnSurface.rb
no such file to load -- LibFredo6.rb -
Hi Potatochips,
Have you also installed the LibFredo library as advised in the first post?
@gaieus said:
Hi Potatochips,
i got it to work now, thanks!
Hello sir,
your new version is working on google-sketchup pro 8 ...... ?
Thank you,
Ruturaj -
yes - it work with SU8
Thank you ,.....
You can assume that most plugins work in SU8 if they worked in earlier versions. Just install and try.
Does Tools on Surface run on SU 8? I've tried to download and install it just as you described, but I can't seem to get it to appear in either the Tools menu or the Plug Ins menu, even after I restart my computer. I have the Dir 35 running on my computer. Any suggestions?
As always, many thanks -
It works on SU8, yes.
Exactly what location did you install it to? can you post a print screen of where you files are? -
Exactly what location did you install it to? can you post a print screen of where you files are?It's in the Macintosh HD/Library/Application Support/SU8/Plug-Ins. Here's a screen shot:
i'm not quite sure how you ended up with a folder called 'ToolsOnSurface 1.6c - 15 May 10(3)' but it's not correct..
the simplest way for you to install would be to download the installer here:
http://web.me.com/jeffhammond/su/TOS.zip(this was made for someone else a little while ago.. su8 osx only)
you'll probably want to trash the ToolsOnSurface 1.6c - 15 May 10(3) folder
It's it the content of 'ToolsOnSurface 1.6c - 15 May 10(3)' that should be in the plugins folder?
that's what i was thinking as well.
though when i unzip the download, i'm left with a folder called ToolsOnSurface%201 which then needs to be opened to find the goodies. -
I trashed the ToolsOnSurface folder and used your installer to reinstall the program. Still no luck. Can't find the plug-in even when I restart SU 8. Does it matter that I'm using SU Pro?
Many thanks for your help.
dh -
you might have to enable the plugin
go sketchup-> preferences-> extensions
and check tools on surfacepro doesn't matter
