[Plugin] Bitmap To Mesh
Re: [Plugin] Bitmap To Mesh (0.2.0b) — 03 October 2010
Postby thomthom » Sun Oct 03, 2010 5:18 pm
Yea - the last texture I tested was 512x512 - heavy mesh. And I'd forgotten that Autosave was on - every 5 mins. x_X
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Sun Oct 03, 2010 5:20 pm
dedmin
Postby dedmin » Sun Oct 03, 2010 5:30 pm
:berserk: :berserk: :berserk: :berserk:
dedmin
Postby shura » Sun Oct 03, 2010 10:30 pm
Why don't I get the Curve Simplification to work?
User avatar
shura
Postby thomthom » Sun Oct 03, 2010 10:41 pm
hm... possibly you have a version where it failed on closed loops. I might not have uploaded a corrected version...
User avatar
PluginStore Author
PluginStore Author
Postby david_h » Mon Oct 04, 2010 4:26 pm
So I notice these wonderful meshes created. How is one controlling the height of the extrusion?
If I make it look easy. . .then it probably is.
User avatar
david_h
Top SketchUcator
Postby pichuneke » Tue Oct 05, 2010 4:30 pm
The pieces on the roof (above the pediment) are made with your plugin :)
Reconstrucción del Templo de Artemis Agrotera 4 by Egocentrico, on Flickr
Click here to see it in bigger size (1024 px):
http://www.flickr.com/photos/28798115@N ... otostream/
Forgive my spanglish...
pichuneke
Postby Ghalko » Wed Oct 06, 2010 5:19 am
So I read the posts and then thought nothing of trying a 2048x2048 heightmap produced by L3DT (terrain generating program.) :shock: Maybe I should try a bit smaller at first. Then I won't just freeze sketchup and make my patience run out... :?
I will try with a smaller (much smaller) one first and post the results.
Bryan
Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
Ghalko
Postby solo » Wed Oct 06, 2010 6:12 am
Color, the darker the black and brighter the white will produce the greatest crests and troughs.
I'm better with polys than words
User avatar
Global Moderator
Postby Ghalko » Wed Oct 06, 2010 6:57 pm
After letting a 384x384 (meters) heightmap simmer:
Ghalko
Postby david_h » Wed Oct 06, 2010 7:13 pm
solo wrote:Color, the darker the black and brighter the white will produce the greatest crests and troughs.
I get that easy enough. its all based on contrast. . .so One must go into PhoShop and manipulate and lessen those contrasts before putting it into the plugin? Because when I down loaded the scrolly motif lintel thing, I got all kinds of mess. I just couldn't get my model to look like others were doing. . .
I'll keep playing with it.
User avatar
david_h
Top SketchUcator
Postby jeff hammond » Wed Oct 06, 2010 7:26 pm
David,
Use the scale tool to compress it vertically.
User avatar
Global Moderator
Postby david_h » Wed Oct 06, 2010 8:14 pm
oh well. . . there's one for the duh thread.
Thx :oops:
User avatar
david_h
Top SketchUcator
Postby thomthom » Thu Oct 07, 2010 6:20 pm
With version 0.2.0 you specify the height your self - either by using the cursor or entering a length in the VCB.
User avatar
PluginStore Author
PluginStore Author
Postby spence » Thu Oct 07, 2010 8:31 pm
thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE! :sketchstatic:
Spence
User avatar
spence
Premium Member
Premium Member
Postby david_h » Tue Oct 12, 2010 10:50 pm
Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. :mrgreen:
User avatar
david_h
Top SketchUcator
Postby thohan » Wed Oct 13, 2010 11:21 pm
Thank you for this great plugin. :D
I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
I think with some more effort, one can achieve much better results.
It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
thohan
Postby jamalito » Sat Oct 23, 2010 10:12 am
wow wow wow
where have you been ? man
I looking for such as plug-in
thank you so so much thomthom :berserk:
you helped me
because I have a lot pictures I want to do it
Albert Einstein:
((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
User avatar
jamalito
Postby thomthom » Sat Oct 23, 2010 10:37 am
thohan wrote:It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
Nice coin by the way. :D
User avatar
PluginStore Author
PluginStore Author
Postby marcomartim » Mon Oct 25, 2010 1:21 am
This plugin is great!
I use Sketchup with Phlatscript plugin to generate code G (2.5 D) to use on my CNC Router, lack a 3D plugin for editing G code on Sketchup.
For 3D and 4D, still use the Artcam,; Now with this plugin can create 3D models from photos, right in Sketchup.
Thank you.
marcomartim
Postby Christmended » Mon Oct 25, 2010 3:59 pm
Thanks for the awesome plugin!
Here is a test result I did.
Christmended
Postby Dave R » Mon Oct 25, 2010 5:16 pm
Shaun, that almost looks like a lithophane. Cool.
User avatar
Global Moderator
Postby Heven7_floor » Tue Oct 26, 2010 3:36 pm
Great Plug-in, thank your gift to make SU plugin to display the thing happen :thumb: :thumb: :thumb:
Heven7_floor
Postby pichuneke » Tue Oct 26, 2010 4:30 pm
The plugin works with bump mapping. I have no idea about what I am saying, but could it work with normal and displacement maps?
I have no idea about programming, except an unfinished Interactive Fiction game 5 years ago in the "popular" inform 6 language :shock: :lol: :lol:
pichuneke
Postby thomthom » Tue Oct 26, 2010 4:35 pm
pichuneke wrote:I have no idea about what I am saying, but could it work with normal and displacement maps?
Displacement maps are the same as bump maps - grayscale heightmaps. As for normal maps, I don't really know how they work...
User avatar
PluginStore Author
PluginStore Author
Postby pichuneke » Tue Oct 26, 2010 5:49 pm
I have found a lot about normal maps here:
http://www.google.com/search?hl=es&q=+s ... CBsQrQIwAA
but it's written in chinese, or C++ ... :lol: I don't know if it may interest you, I was spending my time a bit (as I don't understand a single word :D )
pichuneke
Postby arquitectomaracucho » Tue Oct 26, 2010 6:44 pm
excuse my English, Greetings :knockout:
Thomtom greetings, very good tool for many functions :thumb: . be possible to add option mesh, giving a percentage between simple and complex mesh, thanks :thumb:
User avatar
arquitectomaracucho
Postby thomthom » Tue Oct 26, 2010 6:51 pm
arquitectomaracucho wrote:be possible to add option mesh, giving a percentage between simple and complex mesh, thanks :thumb:
That would be simply resizing the bitmap down - which is much more efficient to do in your favourite image editor than via a Ruby plugin.
User avatar
PluginStore Author
PluginStore Author
Postby Scott M » Sun Oct 31, 2010 5:01 pm
Just downloaded the plugin an gave it a try.I folowed the promp but nothing is showing up it is saying generating mesh but continues to thnink as if unresponsive.Is my system just too slow or am I doing something wrong. Could someone outline the process.The images you guys posted look great.I allso operate a cnc and would lke very much to use this plugin.
Scott M
Postby thomthom » Sun Oct 31, 2010 5:07 pm
What image are you feeding it?
How large?
If you keep the Ruby Console open, do you get error messages?
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Arzaga, Bing [Bot], Dave R, JakobsenChri, jessica ubatuba, reynoldparada, rushimamarde, sumey, thaibuilders and 12 guests
Visit our sponsors:
