SketchUcation Plugin Store
[Plugin] Boolean--OSCoolean (Oct 2010) for SU 8 free version
Re: Boolean--OSCoolean Beta (18/12/2008)
Postby narongwit12 » Wed Jul 15, 2009 2:59 am
Thank you very much for this brilliant rb. Would you mind to share us the brief idea of the mechanism of this plugin? I want to do a union thing, but find it quite hard to do it without any guide.
Best regards
Narongwit
narongwit12
Postby lorca » Mon Aug 31, 2009 3:55 pm
For those who are saying nothing happens, well, you have to make each object a group/component. I was having the same problems like some of you until i made each object separate from eachother. When you place them together you choose one object then right click to the plugin and choose "cut" and depending of which object you chose you'll get the "negative" or "positive" cut. Although, I think there is a bug when you place an object in a severe angle inside, it tends to cut almost all of the opposite object leaving expose in the air only the hole that the other object traced. I wonder if the creator of this plugin is still working on the new release.
lorca
Postby jca » Thu Dec 03, 2009 11:36 am
looks great !
tried both OSCoolean.rbs and OSCoolean.rb but neither worked...
I'm using SU6 under MacOS X 10.5 OS.
any working version for mac ?
thanks a lot
jca
Re: [Plugin] Boolean--OSCoolean Beta (18/12/2008)
Postby apple85 » Mon Feb 08, 2010 12:48 am
hi,
just out of curiosity how does the OSCoolean differ from the commercial booltools plugin?
apple85
Postby Pilou » Mon Feb 08, 2010 12:52 am
In theory nothing but in practice that is an another story ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free
SketchUp use: hobby
Level of SketchUp: Advanced
Re: [ver Oct] Boolean--OSCoolean(Oct 2010) for SU 8 free ver
Postby Gaieus » Sat Oct 02, 2010 11:54 am
For the information of te "rest of the World", Oscarlok updated the plugin (see the first post as of October 2010) for SU 8.
He just forgot to add a new post or bump the topic otherwise.
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby Ken » Sat Oct 02, 2010 12:12 pm
OSCAR
In your Oct release, only three icons are displayed. And the last two, cut and intersect perform the same function.
Thanks for your work with this plugin.
Ken
Government rushes to help the irresponsible and does little for the responsible.
User avatar
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby oscarlok » Sat Oct 02, 2010 1:14 pm
Ken wrote:OSCAR
Ken
Hello Ken,
I am sorry for that! I have changed it to the New OCT version. The previous one is still Sept version.
Thanks Ken :D
Oscar
oscarlok
Postby shura » Sat Oct 02, 2010 1:32 pm
Does it work in SU 7.1 as well?
User avatar
shura
SketchUp version: 7
License type: Pro
SketchUp use: interior design
Level of SketchUp: Intermediate
Postby oscarlok » Sat Oct 02, 2010 2:03 pm
shura wrote:Does it work in SU 7.1 as well?
This is a SU 8 only。Maybe in the next next version。。。。 ;)
oscarlok
Postby shura » Sat Oct 02, 2010 8:28 pm
thanks oscarlok, just collecting reasons to upgrade, you know ;)
User avatar
shura
SketchUp version: 7
License type: Pro
Postby mitcorb » Sat Oct 02, 2010 9:41 pm
I never could get the version for Sketchup7 to work??
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
SketchUp use: architecture
Postby mitcorb » Sun Oct 03, 2010 11:41 pm
Bumping this just in case someone knows a solution to making the older version work in SU7?
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Pilou » Sun Oct 03, 2010 11:59 pm
Someone said that disable SketchyPhysics permits to use OSCoolean in V7 (?)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby mitcorb » Mon Oct 04, 2010 11:45 am
I do not have Sketchyphysics. Must be some other tool. I will try to run it with the console on, capture and post back.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby mitcorb » Mon Oct 04, 2010 12:43 pm
Here's what I get trying to Intersect a simple cylinder group and a cube group which I set overlapping or coincident in the same location :
Error: #<NoMethodError: undefined method `entities' for #<Sketchup::ComponentInstance:0x6775c40>>
(eval):573:in `get_grocom'
(eval):570:in `each'
(eval):570:in `get_grocom'
(eval):588:in `Preset'
(eval):713:in `Intersect'
(eval):823
(eval):823:in `call'
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby thomthom » Mon Oct 04, 2010 12:47 pm
mitcorb wrote:Here's what I get trying to Intersect a simple cylinder group and a cube group which I set overlapping or coincident in the same location :
(eval):823
ComponentInstance doesn't have an entities method - you need to access the definition.
There are some plugins that adds .entities to ComponentInstance and I've seen some other plugins that also made the assuption taht this method existed.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby mitcorb » Mon Oct 04, 2010 12:52 pm
Hi, ThomThom:
Thanks for your quick response.
Unfortunately, you're talking way over my head :oops:
I mean, I see what you're writing but I don't know what I'm reading :lol:
What means 'grocom' ??
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby thomthom » Mon Oct 04, 2010 12:57 pm
mitcorb wrote:Hi, ThomThom:
Sorry - it was intended for Oscar.
mitcorb wrote:What means 'grocom' ??
Just method name.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby mitcorb » Mon Oct 04, 2010 1:04 pm
You did note that this is for V7? I am not ready for V8 just yet.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Pilou » Mon Oct 04, 2010 1:54 pm
Works fine for me for SU 8 free :)
I click first on the icone then objects ! :fro:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Humpmetwice » Mon Oct 04, 2010 3:15 pm
I love this plugin but wasn't able to get it to work with SU 7.1, I know its for v-8 but was hoping someone had a fix!
User avatar
Humpmetwice
Postby Pilou » Mon Oct 04, 2010 4:47 pm
and what is the problem to not load the V8 in another folder and save as V7.skp ?
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Humpmetwice » Mon Oct 04, 2010 5:06 pm
Nothing I was just wondering if it was a fix for v7.1 is all.
User avatar
Humpmetwice
Postby DoodleDown » Wed Oct 27, 2010 6:47 pm
Thanks for this, very excited. I just upgraded to 8 for this, but the plugin isn't showing up. Are there any dependencies or known conflicts that could be at fault?
My Sketchup 8 plugins folder only has the folders Oscar, Cadspan, JPP_Dir_15, LIBFREDO6_Dir_34, Ocean, TIGtools, TOS_Dir_16 plus Utilities, plus the rb files OSCoolean, deBabelizer, extrubeEdgesby(various things), jointpushpull, LibFredo6, LibTraductor, loop_subdiv, ocean_extension, su2stl, ZLoader_OnSurface and utilities, if that for some reason makes it obvious to anyone. I'm on 7 Pro.
Thank you very much, whether or not you can point out what's wrong!
DoodleDown
Postby oscarlok » Thu Oct 28, 2010 9:49 am
DoodleDown wrote:Thanks for this, very excited. I just upgraded to 8 for this, but the plugin isn't showing up. Are there any dependencies or known conflicts that could be at fault?
My plugins folder only has the folders Cadspan, JPP_Dir_15, LIBFREDO6_Dir_34, Ocean, TIGtools, TOS_Dir_16 plus Utilities, plus the rb files deBabelizer, extrubeEdgesby(various things), jointpushpull, LibFredo6, LibTraductor, loop_subdiv, ocean_extension, su2stl, ZLoader_OnSurface and utilities, if that for some reason makes it obvious to anyone. (Obv there's also OSCoolean.) I'm on 7 Pro.
Do you have the Oscar folder inside your plugins folder in 8?
or try to unzip the OSCoolean again into your plugins folder in 8, please.
Oscar :)
oscarlok
Postby DoodleDown » Thu Oct 28, 2010 6:48 pm
Yeah, I downloaded and unzipped the folder and the file into Plugins several times. Mucho wierd.
DoodleDown
Postby notareal » Wed Nov 03, 2010 2:21 pm
Maybe you need enable OSCoolean toolbar? If I recall right, OSCoolean toolbar is not automatically enabled.
btw great plugin, thanks for update.
notareal
Thea Render
Postby DoodleDown » Fri Nov 05, 2010 12:07 am
notareal wrote:Maybe you need enable OSCoolean toolbar? If I recall right, OSCoolean toolbar is not automatically enabled.
Well that sure should have been obvious. Thanks!
DoodleDown
Re: [Plugin] Boolean--OSCoolean (Oct 2010) for SU 8 free ver
Postby oneturboneeded » Thu Dec 23, 2010 1:32 am
I cant get it to work I see the tool bar, I click both groups, says scoolean is processing and it does nothing else. Thanks,
-shawn
oneturboneeded
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: ALDob, beer_nut, fredo6, jorge2011, Pilou, pudl, takesh h and 10 guests
