by gavvy » Thu Aug 12, 2010 6:42 am
Here is a plugin which can help you to show or hide the toolbars Usage put it to the plugins floder and assign it a hotkey! Double hit the hotkey ,or load the command twice in a second it will show or hide the "LargeToolset" # Thanks for the help by Master Thomthom.
gavvy
by Gaieus » Thu Aug 12, 2010 2:15 pm
Ehm... Where and how can I find/launch the plugin?
There is (now?) an entry under my Plugins menu "Relist toolbars". Is that it?
I get a popup that "Relisted finished" but nothing happens.
- Administrator
- Name: Csaba Pozsárkó
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: historical reconstruction
- Level of SketchUp: Advanced
by gavvy » Fri Aug 13, 2010 3:24 am
Gaieus wrote:Ehm... Where and how can I find/launch the plugin?
I get a popup that "Relisted finished" but nothing happens. There is 2 item "Show Hide Toolbars" :to show or hide your toolbars "Relist Toolbars" :to relist the toolbars (just relist) at the begin ,you just to launch the "Show Hide Toolbars" twice IT WILL BE OK
gavvy
by charly2008 » Fri Aug 13, 2010 11:50 am
it works. Only one click at "Show and Hide toolbar". To reverse it click again "Show and Hide toolbar". The result looks like this! It would be nice if the tool would make sorting a little better. Is that possible in this script?
I have found a way. When you first use "Show and Hide toolbar" sort the toolbars manually as desired. The next time you use it, all the toolbars are in this sort available again.
But I've noticed when I undo "Show and Hide toolbar" my toolbars disappear in the top and upper bar. the have to be refurbished.
Charly
Please, register (free) to access all the attachments on the forums. More dangerous than ignorance is the illusion of knowledge
charly2008
- Name: Karlheinz Hauser
- SketchUp version: 7
- License type: Pro
by Burkhard » Fri Aug 13, 2010 5:21 pm
Any chance to get it for Mac? It does not work here.
Burkhard
- Premium Member
- License type: Pro
- SketchUp use: interior design
by Gaieus » Fri Aug 13, 2010 7:26 pm
OK, I got it to work, thanks for the help.
- Administrator
- License type: Pro
by gavvy » Sat Aug 14, 2010 4:46 am
charly2008 wrote:Hi,
Charly
En....May be Jim will know how to get the position of the toolbars! In the Sketchep Api Webside,i can't find the toolbar's position method. But like the hotkey ,the position of toolbars are restored in the Registry of Windows. If you want to do this ,maybe you have to restart the sketchup .It's that the best way ? By the way ,I have not touch the MAC system  .SO i don't know if it can run on mac or not.
gavvy
by Jim » Sat Aug 14, 2010 1:55 pm
gavvy wrote:May be Jim will know how to get the position of the toolbars!
You would need to use Win32API on Windows, and I don't know for the Mac.
Jim
- Global Moderator
- Name: Jim
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Intermediate
by gavvy » Sun Aug 15, 2010 11:47 am
Jim wrote:gavvy wrote:May be Jim will know how to get the position of the toolbars!
You would need to use Win32API on Windows, and I don't know for the Mac.  OH YEAR ~.I remeber a plugin have the example to sort the toolbar in side .em but i don't remember the name of it . Win32api is a good tool to do this ,but it always get wrong for the string  Why?
gavvy
by gavvy » Sun Aug 15, 2010 11:51 am
here is my toolbars .  and the toolbar plugins (modify on Jim's Customtoolbar)
gavvy
by Gaieus » Sun Aug 15, 2010 12:00 pm
My problem with this plugin is that it shows all the toolbars that I do not even use when I set it. There are a couple of plugins that I do not use regularly and only switch off when I need them. This plugin activates all inactive toolbars, too (on top of all I also use Jim's custom toolbar).
- Administrator
- License type: Pro
by gavvy » Tue Aug 17, 2010 6:33 am
Gaieus wrote:My problem with this plugin is that it shows all the toolbars that I do not even use when I set it. There are a couple of plugins that I do not use regularly and only switch off when I need them. This plugin activates all inactive toolbars, too (on top of all I also use Jim's custom toolbar).
I will upgade it .the pre version ,I had a txt to control which is not show ,and which will show . Next I will add the webDiaglo to control it
gavvy
by Gaieus » Tue Aug 17, 2010 7:52 am
Please, don't get me wrong, the plugin seems to be very useful - and I am probably one of those few who keeps plugins under the hood and only activates toolbars when needed (I sometimes do not use a plugin for months but then a certain projects comes and I use it daily). Now if only we could save toolbar locations as well so they do not get cluttered all the time when activating / deactivating certain ones.
- Administrator
- License type: Pro
by Jim » Wed Sep 01, 2010 1:30 am
There it is!
UI.set_toolbar_visible("FullToolSet", true)
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by xrok1 » Mon Feb 28, 2011 5:48 pm
this plugin is awsome! has anyone figured how to get it to open only active plugs? begreat if you could have it only toggle the ones you want it to or only undocked bars as well. that way you could float the larger ones or the ones you don't use as often.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.” http://www.Twilightrender.com try it!
xrok1
- Name: Rocky
by nikus_knx » Fri May 20, 2011 10:31 am
How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
nikus_knx
- Name: Nicolas
by TIG » Fri May 20, 2011 1:24 pm
nikus_knx wrote:How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
AFAIK the Scene Tabs can't be toggled through the API. If you were on a PC you could assign a shortcut key to that View > Scene Tabs menu item and then call a WinScript command to mimic the key-stroke, but since it's a 'toggle', then knowing whether you will turn the Tabs on or off is problematical...
- Global Moderator
- Name: TIG
- License type: Pro
- SketchUp use: architecture
by nikus_knx » Fri May 20, 2011 4:05 pm
I get it : - Code: Select all
Sketchup.send_action 10534 Do it two times the first time (there 's a bug in Sketchup about the connected checkbox) Enjoy
nikus_knx
- Name: Nicolas
by TIG » Fri May 20, 2011 4:07 pm
nikus_knx wrote:I get it : - Code: Select all
However, that's PC only...  Because it's a toggle there's no way of knowing it the tabs are on before running it, so if they are already off it'll switch them on ?
- Global Moderator
- Name: TIG
- License type: Pro
by driven » Fri May 20, 2011 4:53 pm
TIG wrote:nikus_knx wrote:How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
on a Mac you can use an osascript call to do the same sort of thing, along these lines, but you need to double check all the escapes System "osascript -e 'tell application \"System\ Events\" -e click menu item \"Scene\ Tabs\" -e of menu 1 of menu bar item \"View\" -e of menu bar 1 of application process \"SketchUp\"e- "end tell"'" PM me if you want a working version or have a play. john
driven
- Top SketchUcator
- Name: John
- Operating system: Mac
- License type: Pro
- SketchUp use: engineering and mechanical design
by biiid » Tue Apr 16, 2013 8:40 am
The gadget very practical,I give it a try.
biiid
- Name: biiid
Return to Plugins
