SketchUcation Plugin Store
[Plugin] FollowMe and keep (v0.04 update 20090210)
Re: [Plugin] FollowMe and keep (v0.04 update 20090210)
Postby rainfrog » Fri Apr 30, 2010 8:56 am
Jeff, thanks for alerting me to the continued discussion here, regarding the problem I had a few months back! And also for demonstrating the different results between the original follow me and the 1001bit tool. It is nice to see that there is indeed a plugin out there that performs the exact function I was looking for. Very helpful! :thumb:
rainfrog
Postby BERNS » Thu Jul 15, 2010 5:54 pm
THIS IS AN EXCELENT PLUGIN FOR TOPOGRAPHY AND MANY OTHER THEMES! I SAVED UP ALMOST 95% OF TIME AND WORK.
BERNS
Postby lightburn » Mon Jul 19, 2010 10:40 am
thanks for this wonderful plugin. this just saved me a hell lot of headaches. :berserk:
lightburn
Postby Blomman » Sat Jul 31, 2010 9:44 am
A really useful plugin. It helped me with creating a highway interchange.
But what if I want to paint the created shape in more than just one color? Since I'm using this plugin to create a road ramp I really want to be able to paint the sides in different colors and textures. As it is now I can't since all the sides of the thing are treated as one. If I click on the left side for example, the right, top and bottom also gets highlighted. Is there anyway to solve this?
By the way, I'm using this plugin together with the bezier curves plugin by Fredo 6 if that matters.
Blomman
Postby mitcorb » Sat Jul 31, 2010 4:19 pm
@Blomman:
I am not sure if this is valid, but is the resulting model a group or component? If so, could you right click on this, Edit Group, or Edit Component, and then apply colors, materials, textures to the various faces?
Save first, then try the above. Undo(Control Z)if this does not get the desired results.
Keep watching this thread for other replies.
User avatar
mitcorb
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Intermediate
Postby Blomman » Sat Jul 31, 2010 10:34 pm
Yes, the model is automatically turned into a group which, as far as I know, can not have multiple textures or colors applied to. I forgot to mention that I've already done what you suggested (edit group) which is were I noticed the problem I described in my previous post. I've also tried "explode" but with the same result. :|
Blomman
Postby Rich O Brien » Sun Aug 01, 2010 1:32 am
Has the model, during the FMAK process, had it's edges smoothened?
Have you hidden geometry on or off?
If it's off, just turn it on and paint the faces. Or right click the entity and choose soften/smooth and lower the slider bar until the lines appear. You can use Ctrl+E to soften any lines that you don't want to see.
I could be way off the mark :?
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Postby Blomman » Mon Aug 02, 2010 10:33 pm
The hidden geometry was indeed off, now it works perfectly. Thanks! :)
Blomman
Postby Sir » Tue Aug 03, 2010 3:34 pm
this plugin has just saved me hours. i love you.
image attached. each side of the stairs is a different curve... pain in the ass.
Sir
Postby marvins_dad » Mon Apr 04, 2011 10:25 pm
Just wanted to say Thanks again!
I had lost the ruby and someone helped me find this one again...it is amazing for stairs! :thumb:
User avatar
marvins_dad
SketchUp version: 8
License type: Pro
Postby dmonahan96 » Mon May 16, 2011 2:43 pm
So I installed the followme and keep plugin and it worked great on the first railing that I used it for but now it keeps crashing my SU every time i try it with this other section. Any suggestions?
dmonahan96
Postby shoeb_cars » Mon May 30, 2011 4:55 am
google should really learn some good stuff like this...thanks man :thumb:
shoeb_cars
Postby Dave R » Fri Jul 22, 2011 11:31 pm
So what am I missing? I've read through as much of this thread as I could. I can get FAK to work on simple arcs but not on this longer path. Even though it's not supposed to require it, I added a C-point to the start end of the path. Surely I've done something that isn't right. Can anyone tell me what it is?
Inspecting mirrors is a job I could easily see myself doing.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby mitcorb » Sat Jul 23, 2011 1:18 am
Weld- Don't Weld? Group- Don't Group? This is a test, right?
Plugin "deprecation" due to Sketchup version?
I mean, when you're stumped, we're in hell.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
Postby Dave R » Sat Jul 23, 2011 2:00 am
Tim,
I'm flattered by your comments. It wasn't a test. Well, it was a test for me.
I finally figured it out. The path needs to be basically horizontal. I didn't see anything in the thread that indicates this, though every example I saw was thus. Even so, it doesn't really do what I need anyway so I'm off on the hunt for another approach.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby mitcorb » Sat Jul 23, 2011 2:46 am
Well, Dave:
When you say basically horizontal do you mean mostly horizontal or dead flat path, or profile horizontal? I vaguely remember the demos and I may be getting it confused with Chris Fullmer's perpendicular faces tool.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
Postby Dave R » Sat Jul 23, 2011 3:05 am
Sorry for being vague. I turned the helix on its side so its axis was along the green axis. This turned the square profile up on edge as well. I initially use Chris Fullmer's Perpendicular Face Tools to put the square on the end of the helix while the helix was standing up. that worked just fine.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Sir.Swaffel » Mon Sep 26, 2011 2:16 pm
I like this tool, but it is lacking a basic feature that 1001bit's version does have: a reference point.
FollowMeAndKeep automatically uses the center of the face that it wants to extrude as the reference point for the path. When using a more complex face that needs to be extruded along a path relative to let's say the bottom left corner, you're out of luck :?
Sir.Swaffel
Postby Dave R » Mon Sep 26, 2011 2:57 pm
Sir.Swaffel wrote:I like this tool, but it is lacking a basic feature that 1001bit's version does have: a reference point.
It's good to have the option of using 1001bit, isn't it?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Sir.Swaffel » Mon Sep 26, 2011 3:01 pm
haha, yes, unfortunately 1001bit lacks a feature that FollowMeAndKeep does have, it doesn't lock the z orientation. So basically both of them lacks an essential feature of the other... and I don't know a way to combine them :).
Sir.Swaffel
Postby Dave R » Mon Sep 26, 2011 4:04 pm
I suppose for FaK you could add some temporary geometry to get the bottom left corner to be the center. Not idea but it could work.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby wikii » Tue Sep 27, 2011 4:22 pm
Reference point?
select a cpoint ,curve and face,then run fak.
the cpoint will be treat as reference poing.
try it.
wikii
wikii
Postby Sir.Swaffel » Tue Sep 27, 2011 7:58 pm
ah thanks, it never worked when I tried it, so I thought it was broken. But apparently my SU has some trouble making correct faces with FAK and complex curves and precise helixes. Got it working now though, so thx :).
Sir.Swaffel
Postby dereeei » Mon Oct 10, 2011 6:54 am
I'm trying to run FAK on a face + path but it doesn't o anything.
Can anyone point me where I'm wrong? I tried with a simpler shape (arc + rectangle) and it worked. Is it something wrong with this particular model?
Model attached. Thank you.
dereeei
Postby Pilou » Mon Oct 10, 2011 9:19 am
The extrude edges familly by Tig must make the trick ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby gilles » Wed Oct 12, 2011 5:52 pm
@ dereei, rotate the whole model so the face isn't horizontal and it works.
I suggest to separate your path in two parts to avoid strange results.
User avatar
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
SketchUp use: other
Re: [Plugin]FollowMe and keep (Fixed)
Postby destroyer1095 » Fri Nov 11, 2011 7:06 am
ITS NOT WORKING FOR SKETCH UP 8!!!!! :evil: :thumbd:
destroyer1095
Postby Gaieus » Fri Nov 11, 2011 7:23 am
Yes it is - and please, do not use ALL CAPS on the forums.
A "not working" remark will never help trouble shooting what you are doing wrong. First of all, did you install it correctly?
User avatar
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby dereeei » Fri Nov 11, 2011 7:25 am
destroyer1095 wrote:ITS NOT WORKING FOR SKETCH UP 8!!!!! :evil: :thumbd:
is working ! read the previous post! I'm sure you used a path that was vertically aligned.
dereeei
Postby thomthom » Fri Nov 11, 2011 8:18 am
How ironic is his nickname...? :roll:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: CadFather, gelbuilding, solo, topcon, vantin, yard and 7 guests
