SketchUcation Premium Membership
[Plugin] Superglue (1.1.0) — 07 July 2010
Postby thomthom » Wed Jul 07, 2010 9:44 am
Overview
Quickly stick GlueTo components back to the faces they lie flush with, or use solvent to release them. Simply click and sweep across the faces and components.
The components will stick to the last face touched and will only stick if the components is lying correctly on the face.
Version 1.1.0
Merged into one tool. Use Ctrl to toggle between Superglue and Solvent.
Access
Tools -> Superglue
(Supports ThomThom's Menu)
Credits
Icons by Paul Davey aka Mattahan. All rights reserved.
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Superglue (1.0.0) — 07 July 2010
Postby snowflake » Wed Jul 07, 2010 9:53 am
Nice, watch your fingers boys and girls.
Thank you.
Deserves another cookie, of an Oreo quality.
snowflake
Postby thomthom » Wed Jul 07, 2010 10:15 am
Coming update:
* Merge Superglue and Solvent into one tool - use Ctrl or Shift to toggle
* Different colour for the Solvent.
Any other ideas?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby CodyV1 » Wed Jul 07, 2010 10:37 am
A rotatable line of glue, where you can glue things and ajust their position on a fixed base.
CodyV1
Postby Gaieus » Wed Jul 07, 2010 10:56 am
Hm. I did not notice this so far (not even downloaded it yet) but have used Daiku's "reglue" plugin so far.
I can see the difference in quick usefulness (sweeping through) so will try out immediately but before I fully explore it, what is the difference between superglue and solvent? (Or should I not ask but try? I know...)
And of course goes without saying; thanks again for a cool and useful tool (my components always seem to get unglued somewhere in my workflow)
:roll:
User avatar
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby Gaieus » Wed Jul 07, 2010 11:11 am
Also, I was planning this little "tutorial" on how to install zipped plugins (as many Windows users will just press the button to unzip the files/folders and Windows tends to put them into a separate folder) so now I finally made it using your plugin thus making it "immortal" :D
The image is in my Picasa Albums so copying the img url will always enable everyone to add the image into a thread when someone has this issue with installing the plugins.
I know my XP is Hungarian but I hope I annotated the image enough for all language users who understand English.
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Jul 07, 2010 11:26 am
Yes problem in general is the "Unzip" make a double level Folder with the same name! ;)
it's more speedy for unpack :)
Then you must carreful for move the good folder ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Wed Jul 07, 2010 11:35 am
I always download the zip to the ../Desktop/, and extract into the folder it wants to make for the extracted files/sub-folders. Then I open the newly made folder, select-all and drag/drop everything into ../Plugins/ folder. Finally I erase the original folder and zip...
Putting zips directly into the ../Plugins/ folder just clutters it up... If you want to use a ../Download/ folder to keep your ../Desktop/ more tidy - then you can leave the zip behind in it for later reference ??
:geek:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Jul 07, 2010 11:40 am
If you have some place on your desktop :mrgreen:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Pilou » Wed Jul 07, 2010 11:43 am
About the glue :mrgreen:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Wed Jul 07, 2010 11:56 am
CodyV1 wrote:A rotatable line of glue, where you can glue things and ajust their position on a fixed base.
Can you explain/illustrate this?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 11:57 am
Gaieus wrote:I can see the difference in quick usefulness (sweeping through) so will try out immediately but before I fully explore it, what is the difference between superglue and solvent? (Or should I not ask but try? I know...)
Solvent unglues.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
TIG wrote:I always download the zip to the ../Desktop/,
Ditto.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 11:58 am
Gaieus wrote:Also, I was planning this little "tutorial" on how to install zipped plugins (as many Windows users will just press the button to unzip the files/folders and Windows tends to put them into a separate folder) so now I finally made it using your plugin thus making it "immortal" :D
:D :thumb:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 11:59 am
Pilou wrote:About the glue :mrgreen:
I used to be called Tintin at school. :D
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Jul 07, 2010 12:00 pm
Superglue is supposed to work in SU6 ?
Because nothing works! :o
HAve you a little animation of what must the glue's pot must do?
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Gaieus » Wed Jul 07, 2010 12:05 pm
thomthom wrote:...Solvent unglues.
Makes sense...
:oops:
TIG wrote:Putting zips directly into the ../Plugins/ folder just clutters it up... If you want to use a ../Download/ folder to keep your ../Desktop/ more tidy - then you can leave the zip behind in it for later reference ??
I do have a download folder for everything else but have got used to saving plugins (zipped) straight to the Plugins folder. I have this external HD I regularly make backups on and beside my Documents folder, I included some of the folders under Program files (SU materials, components, plugins, KT materials, models, globals etc.) just in case. Much easier and faster to recover should anything go wrong.
But you know, "de gustibus non (est) disputandum" at least as far as one does not screw up his system. :)
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 12:11 pm
Pilou wrote:Superglue is supposed to work in SU6 ?
I have not tested it. Can't remember if there was any SU7 specific code. I'll check.
Pilou wrote:HAve you a little animation of what must the glue's pot must do?
A video of the plugin in use? Yes I'll make one once I make v1.1.0.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed Jul 07, 2010 12:16 pm
Same result in V7, so I must to miss something evident :oops:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby thomthom » Wed Jul 07, 2010 12:28 pm
Do you get menus?
Can you start the tool?
Do you see the glue bottle cursor?
Are there error messages in the Ruby Console?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 12:38 pm
Works like a charm under SU6.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Wed Jul 07, 2010 12:48 pm
Here you go sir (especially, with the annotations it is pretty fast so pause it when needed):
YouTube - Superglue Plugin for SketchUp
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 12:52 pm
:thumb: Cheers Gaieus!
I owe you a cookie.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 12:53 pm
:shock:
I forgot my Cookieware stamp!
I forgot the cookie!!!
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Wed Jul 07, 2010 12:56 pm
thomthom wrote::thumb: Cheers Gaieus!
I realised I could (should) add your name to the Title filed, too, not just into the description filed.
:thumb:
I owe you a cookie.
How about a beer instead?
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 12:57 pm
Beer also works! :D ...but I forgot! I'm worried about my mind now...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby mitcorb » Wed Jul 07, 2010 1:01 pm
Wow!!
This thread just started and already has two pages of replies.
User avatar
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Level of SketchUp: Intermediate
Postby thomthom » Wed Jul 07, 2010 1:03 pm
mitcorb wrote:Wow!!
hehe - inflated by my replies.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Wed Jul 07, 2010 1:05 pm
Added some pauses when reading the annotation text seemed to be a bit fast. Gee, I like these features.
thomthom wrote:
mitcorb wrote: Wow!!
And mine...
:lol:
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jul 07, 2010 1:18 pm
What do you use to make the videos with annotations?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: dejelle2, driven, flashzs, Henz, Humpmetwice, veloso90 and 3 guests
