The "Duh!" thread (aka the Doh! thread)
General discussion related to SketchUp Pro and Make
Re: The "Duh!" thread
Postby SketchUpNoobie » Wed Jun 30, 2010 3:38 pm
arklandesign wrote:hehe .....This is a funny and informative thread at the same time...
I have one... discovered by mistake yesterday.
If one is in a complicated model and want to focus attention to a particular part of the model, one can double click on the scroll wheel at the point one is interested in and that will centre that point in the middle of the screen....making orbiting even easier.
Haha! Thanks! Funny how stupid some people are. Surely not me though! :oops:
Last edited by SketchUpNoobie on Thu Jul 01, 2010 2:39 am, edited 1 time in total.
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Re: The "Duh!" thread (aka the Doh! thread)
Postby SketchUpNoobie » Wed Jun 30, 2010 4:02 pm
Ecuadorian wrote:Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. :shock:
Wow! Just tried it with your avatar and it works!!! :D
SketchUpNoobie
Postby thomthom » Wed Jun 30, 2010 4:07 pm
I had and odd duh moment for that - because I just did it one time, and I surprised myself afterwards when I realised it worked. I assumed it didn't - so I have no idea why I even tried.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Wed Jun 30, 2010 6:21 pm
But the inverse don't work :( ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby KXI System » Wed Jun 30, 2010 6:48 pm
just figured out how to adjust a textured face.
Right click :arrow: texture
on textured face. Actually I knew about it but just forgot.
Getting the perfect sig is hard...
Google it!
KXI System
Postby danbig » Tue Jul 06, 2010 9:43 pm
here's one:
what's the difference between the "soften" and "hide" commands for lines?
danbig
Postby Rich O Brien » Tue Jul 06, 2010 9:49 pm
Left is Hidden, right is softened...
and SHIFT+ :eraser: = Hide
and CTRL+ :eraser: = Soften
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby danbig » Tue Jul 06, 2010 10:16 pm
Other than appearance, is there a difference in how the two behave?
(I'm slow to Doh! on this one :?)
danbig
Postby Rich O Brien » Tue Jul 06, 2010 10:32 pm
In this example the cylinder with the HIDDEN lines, it's faces are still individually manipulated. Where as SOFTENED results one continuous face. SU playing games with the mind
To create the cylinder without softened edges, just draw a circle, then right click it and Explode Curve followed by :pushpull:. Now you can hide edges and see for yourself!
User avatar
Rich O Brien
Administrator
Postby danbig » Tue Jul 06, 2010 10:40 pm
Hmm. Strange. I'm able to create hidden and soft lines (I use hidden lines regularly).
But if I create two cylinders, just as you have, the hidden line version behaves exactly the same as the soft lines version (sketchup displays the sides as one big face, unless I display "hidden lines" then I can select each face individually).
Also, my hidden line cylinder looks identical to the soft line cylinder.
Can anyone comment on the intent behind creating these two different line styles? What is the "suggested" or intended use for each?
danbig
Postby Rich O Brien » Tue Jul 06, 2010 11:10 pm
Hi DanBIG,
Draw two circles and the right click as mentioned above to 'Explode Curve'
Now :pushpull: both circles, because we have returned the circle to individual segments, instead of one polyline, SU creates a cylinder with individual faces...
Hiding these faces do not merge the faces into one another again, it just hides the Edges(Vertices). Thus still enabling you to manipulate each face...
SU, when it creates CURVES(POLYLINES), allows you to simulate smoothness. As SU natively uses only straight lines to create any curve, having the ability to simulate smoothness/roundness is necessary. When you select View>Hidden Geometry you are effectively asking SU to show both HIDDEN and SOFTENED lines.
To answer your question, which looks nicer?
User avatar
Rich O Brien
Administrator
Postby mitcorb » Wed Jul 07, 2010 3:39 am
following up
doesn't it also affect how textures or materials are applied?
User avatar
mitcorb
Top SketchUcator
Postby Gaieus » Wed Jul 07, 2010 9:27 am
Regarding textures; it does not really control how they are applied but how you can apply them. I.e. you cannot manipulate texture mapping (positioning, projection etc) on curved surfaces only on singular face(t)s. In order to access these on curved surfaces and be able to do anything, you need to show hidden geometry first.
User avatar
Postby Gaieus » Fri Jul 09, 2010 3:04 pm
I have never noticed this...
:shock:
And we have a "search this topic" box as well!
:o
And I am an admin here for about three years now?
:roll: :oops: :?
User avatar
Postby mitcorb » Fri Jul 09, 2010 3:11 pm
@Gaieus:
No one is immune. ;)
I will probably be next.
User avatar
mitcorb
Top SketchUcator
Postby thomthom » Fri Jul 09, 2010 3:26 pm
:lol:
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Fri Jul 09, 2010 6:17 pm
Administrator is at first level
Moderators second level
Surfers users are in the hold :D
Mine Doh of the day :roll:
One research realised then the second one ... :oops:
Speedy Galerie
User avatar
Top SketchUcator
Postby genma saotome » Thu Jul 15, 2010 6:22 pm
danbig wrote:
xrok1 wrote:i think the biggest duh moment of all that everbody (hopfully) goes through is realizing that it matters which way the faces are oriented.
90% of the 3dwarehouse posters still havn't had that duh moment. :lol:
...ok, I'd better ask, because my mind is blank after reading this.
What do you mean, "it matters which way the faces are oriented"?
This is either something I know, in different terms, or something I don't know at all.
If you export SU models to other software that undestands cad models the "light colored" face is regarded as the surface normal -- an odd phase in itself -- but what that means is that face will change it's appearance per the intensity of the light plus angle of the surface normal relative to the light source whereas the reverse face -- the "dark one" -- does nothing. IOW, any kind of add'l rendering depends upon setting face orientation correctly.
User avatar
genma saotome
Postby arklandesign » Sat Jul 17, 2010 5:43 pm
I hardly ever mess with the axes settings, but have finally had a need to start using this and often found I would inadvertently set the blue axes downwards rather than up.
Was watching a tutorial this morning, and found that if one triple clicks (after setting the red axis) it is automatically done correctly for you..... It was a Duhh !!! moment for me.
arklandesign
Premium Member
Premium Member
Postby thomthom » Thu Sep 16, 2010 12:09 pm
When you use the Rectangle tool and make the first click on an edge that is connected to a face, the rectangle tool will align to the edge. :shock: :o :oops:
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Thu Sep 16, 2010 12:52 pm
When you have a very long list of Plugins under Menu Plugins :roll:
Just press a letter on the keyboard and you can see every plugs begining by this letter :o :shock: :oops: :mrgreen:
Damned how many time I have losted with this :oops:
Of course you must know the name of the plugin that you want use :mrgreen:
@Thomthom
Yes but...Inference don't works or maybe you have a trick? :)
Of course I can move the segment atfer drawn the rectangle
(maybe the best) but with only the rectangle tool? :)
Speedy Galerie
User avatar
Top SketchUcator
Postby penumbradesign » Sat Sep 18, 2010 9:41 pm
my duh! moment, toggling control while erasing to hide edges rather than erasing them!
penumbradesign
Postby TIG » Sat Sep 18, 2010 10:27 pm
penumbradesign wrote:my duh! moment, toggling control while erasing to hide edges rather than erasing them!
Eraser+Ctrl 'softens' edges.
Eraser+Shift 'hides' edges.
Eraser+Ctrl+Shift unsoftens edges.
To 'unhide' edges you have to use Entity Info or right-click context-menu 'unhide'... :geek:
User avatar
Global Moderator
Postby Tobobo » Mon Sep 20, 2010 9:17 am
Eraser+Ctrl+Shift also unhides edges (I think)
Toby
Philippians 4:13
User avatar
Tobobo
Postby thomthom » Mon Sep 20, 2010 9:31 am
Tobobo wrote:Eraser+Ctrl+Shift also unhides edges (I think)
It un-smooths - but doesn't unhide.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Sun Sep 26, 2010 4:39 pm
Mine of the day :)
When you create a component with glue property you must reload it from the menu Component :o
The first one created on the screen don't want glue! :o
(and I don't know why :?: :?: :?:
Speedy Galerie
User avatar
Top SketchUcator
Postby Wo3Dan » Sun Sep 26, 2010 6:34 pm
Pilou wrote:.....The first one created on the screen don't want glue! :o
But it does glue to, when created on a face!!!
(If just on its own at time of creation, then the first one doesn't glue to. For there is nothing for it to glue to. Like copies of unglued instances, they don't glue to any face either.)
User avatar
Wo3Dan
Top SketchUcator
Postby pilou » Sun Sep 26, 2010 6:49 pm
Yes instance are gluing
but create a component on a face is some annoying ;)
Component will have not face (background)! :o
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Sun Sep 26, 2010 7:02 pm
It glues to a face IF it's on a face when it's created.
If it's made NOT on a face it's just the same as placing a cutting-component in empty space and then you wouldn't expect that to cut a face when you moved it onto it.
A cutting-component sets its 'face' to what it's placed onto - if that's 'nil' then it's 'nil' !!!
User avatar
Global Moderator
Postby plot-paris » Sun Sep 26, 2010 9:04 pm
a fairly new one:
before thomthom's Solid Inspector came along, I never knew, whether an object was solid or not.
I just discovered, that in the Entity Info window SketchUp puts a "solid" in front of the group's name to indicate, when an object is indeed solid... thats cool, isn't it?
User avatar
plot-paris
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: Bing [Bot], dbtjswo98, Google Bot and 4 guests
Visit our sponsors:
