[Plugin] Edge Tools (2.0.4) — 11 July 2011Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010"Outside" is not given by face's sign of a normal?
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010Awesome!!! Awesome!!!Awesome!!!Awesome!!!Awesome!!! Thomthom you rock...that's why a rocking cake for you when you fail at something....you haven't really failed...you've found one way the thing will not work out
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010Sketchup would have to decide what is outside, what is inside. What if it would have something to do with faces facing camera? Or, if the model is a closed volume somehow Sketchup would check for this and assumes all outside faces should be white, all inside faces should be grey. But what would it decide on an almost closed volume?
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010That is why with some of my tools - like EEbyRails - it makes the mesh and asks if you want to reverse the faces - it tries to double-guess which is inside and which is out, BUT only you know which way round you'd like it...
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010Problem arise when you have meshes with internal faces.
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010If an edge has more than two faces it is impossible to have all of those faces oriented the same way.
A simple fact of geometry - therefore trying to orient meshes with 'internal' faces is futile... TIG
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010This must be due to Sketchup being a surface modeler?.
I'm not sure what Blender is classified as, but it has ways to deal with face orientation, internals and duplicates. I wonder if some analogous form of these concepts could still be applied to Sketchup?-- that is, short of exporting to Blender and back. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010Update 1.1.1
Important bug fix in my Ramer-Douglas-Peucker implementation of the curve simplification. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010Thom thom, thank you for the great plugin. I don't seem to understand how to get the colinear function. I see the rest but not this one.
Ben
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010Nice!
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010Sorry about replacing the Divide Face video is a poorer quality YouTube video, but I ran out of bandwidth on Screencast and I did not have the original video.
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010Hey thom!
I wonder if the simplify curve bit work with closed curves or even surfaces. I find myself in a position in which i imported geometry from a DWG and it left me with some insanely segmented edges. I'm trying to find a method to simplify this thing which complies with the Human Rights. I've uploaded a small sample to make it clearer. Thanks in advance. EDIT: Found a neat SimplifyCountours.rb script right on the SketchUp repository (http://sketchup.google.com/download/rubyscripts.html). Silly me. I figured i should post it here in order to help whoever has a similar issue, since it's somehow related to the plugin subject. I'll be keeping your plugin though, thom. It's pure juice. Keep it up! Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010I realised last week that it did not work for closed curves. But this I should be able to make work.
However, it will not work with faces attached. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010That wouldn't be much of a problem. There's a pretty good Make Face plugin around (i don't remember who wrote it, though).
I'm having some difficulties in using that Simplify thingy i've found as it uses angles to do the dirty job and not the neat Rammer-Douglas_Peucker algorhithm. :\
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010Yea - it's why I was looking for a different algorithm as I found that Simplify didn't preserve the overall shape as well.
From your screenshot it looks as though you have a lot of criss-crossing curves. That leads to problems with any curve simplification algorithms. In my DP implementation I pre-process the selection to locate curve segments. A curve segment is only valid if it doesn't have faces connected or forks. Anything that doesn't fit the requirements is silently ignored. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010Indeed, i realise the crossing is a bit of a problem. However, i separated them all in groups (which is basically double clic and group, being a fairly easy task) so i guess that wouldn't get much in the way.
Re: [Plugin] Edge Tools (1.1.1) — 28 May 2010hm... I guess it could be made into an option to consider a curve segment to be between forks...
Adding to Experiment list. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.2) — 29 August 2010Version 1.1.2
Important Bug Fix! Fixed incorrect lengths for Divide Face tool. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.2) — 29 August 2010Perfection is not for this world
Re: [Plugin] Edge Tools (1.1.2) — 29 August 2010Hi Thomtom,
First, thanks for your hours spent making all these plugins. its a wonder google dont take some onboard for future su releases. I not very technically inclined when it comes to 3d terminology, just want to ask about importing terrain from google earth (get current view ), If I get a few views all slightly overlapping,then explode and toggle terrain, I get holes and overlaps and mess. Which one of your scripts is best to clean this up? Edge tools or cleanup rb? Also in su 8 get current view is no longer in the google toolbar?
Re: [Plugin] Edge Tools (1.1.2) — 29 August 2010RESPECT ++
u saved my life again...TQ very much ![]()
Re: [Plugin] Edge Tools (1.1.3) — 20 November 2010Version 1.1.3
Important Update! Now handles curves the forms loops. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.3) — 20 November 2010Damn how could I miss it? Excellent! With this set of tools you came very close to the one of the biggest hemorrhoids in my workflow- the acad generated arcs\polylines\curves. They typically overlap, cut each other, have different segment length and stray ends etc. If only you could make something in this direction
Re: [Plugin] Edge Tools (1.1.3) — 20 November 2010Overlapping curves that intersect each other is troublesome. It's something that should be corrected in Autocad before importing as it'd be difficult to separate them afterwars. ("Garbage in garbage out")
As for the curve segments - Fredo's Bezier Curve tool let you convert curves into parametric curves you can adjust - can be used to interpolate I think. Maybe his plugin could be automated to process a set of curves? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (1.1.3) — 20 December 2010Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
thanks thomthom
Good idea. I have an update coming up very shortly. Though it won't make it for that, but I'll be on my todo list. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Edge Tools (2.0.0) — 05 February 2011Version 2.0.0
Re: [Plugin] Edge Tools (2.0.1) — 06 February 2011Version 2.0.1
Re: [Plugin] Edge Tools (2.0.1) — 06 February 2011Please, register (free) to access all the attachments on the forums.
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
