SketchUcation Premium Membership
[Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Re: [Plugin] Make Fur (Updated - v.1.4b Sun Jun 06, 2010 12:
Postby Gaieus » Sun Jun 06, 2010 9:29 am
Mauhaus wrote:Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it...
Frederik wrote:I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
That would only be the free version Kim. The pro still has the "native" import option.
As you are not supposed to be able to install the free version on top of the pro, there can indeed be some problem.
However we are going off-topic here so Thomas, after you see my post here, I will split these posts and move the new topic created this way to the SketchUp Discussions > Bug reports subforum.
However you could try to reinstall your SU but really make sure to download the Pro version (again) to install it. Also, for the Mac version there was also a maintenance release after the main release of 7.1. A couple of fixes were made there so best is to go for sure...
User avatar
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Level of SketchUp: Advanced
Postby frv » Mon Jun 07, 2010 12:30 pm
TX for the great plugin, I love the idea of the crowedmaker.
But under OSX it does not work, the dialog panel is empty for the crowed option.
Francois
frv
Postby mariocha » Mon Jun 07, 2010 1:31 pm
frv wrote:....., I love the idea of the crowedmaker.
Francois
Yep, same here. No dialog under MacOX (10.6.3) :?
Mario C.
Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
User avatar
mariocha
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Masoncrowell » Mon Jun 07, 2010 8:43 pm
can someone tell me how i do this on a mac?
i downloaded the file and updated my version of sketchup. the file only shows up in my downloads and i can't open it with sketchup. i also enabled my plugins menu on sketchup and the only option that shows up is a "cost" option. How do i do this? :/
Masoncrowell
Postby tak2hata » Tue Jun 08, 2010 1:03 am
Francois
Hi,Francois and Mario.
It is very regrettable.
I will examine way for working on mac.
Masoncrowell wrote:can someone tell me how i do this on a mac?
This file is compressed by zip.
First, You should extract this file with folder.
It includes
--fur_en.rb
--fur_en(folder include icon images)
and copy created files to plugins folder.
Read here.
http://sketchup.google.com/intl/en/download/rubyscripts.html
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Level of SketchUp: Intermediate
Postby ktslambieng » Tue Jun 08, 2010 3:44 am
this is this is a new : vietnam translation for fur1.4b
Thanks you for all ! :berserk:
ktslambieng
Postby frv » Tue Jun 08, 2010 2:53 pm
TX Tak,
hope you find the time to look into the blanc dialog for crowds.
I love your idea to specialise the furmaker for crowds
Francois
frv
Postby thomthom » Thu Jun 10, 2010 12:57 pm
That is due to some oddness in Geom::Transformation.scaling which I mentioned earlier.
viewtopic.php?f=323&t=28092&p=248300#p248300
But tak2hata said later he's swapped to use .scaling(a,a,a) isntead of .scaling(a) - so that should have taken care of it. Unless there is something else that also creates this scenario.
Oli: are you using the latest version?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jun 10, 2010 12:58 pm
:?: what happened to Oli's post..?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby drunkengiraffe » Thu Jun 10, 2010 10:13 pm
amazing, thanks.
drunkengiraffe
Postby wanchoke » Sat Jun 12, 2010 12:36 am
I use this plugin to my model, It's help to improve atmosphere a lot.
Thank you very much. :thumb: :thumb:
<model link>
http://sketchup.google.com/3dwarehouse/details?mid=5e3202cae2da28223fc4dc5809e00c5c&prevstart=0
wanchoke
Postby Ninjamaster1470 » Sun Jun 13, 2010 4:48 am
I know this will sound really dumb, but it appears that i set the plugin RB (whatever) file to google sketchup program so that when ever i click it, it opens on sketchup instead on.........um.....what it's supposed to open on--btw, what is the program its on?
Help! do u know how to fix?
Update: I moved it but its still a SU app instead of the supposed text doc.
Last edited by Ninjamaster1470 on Sat Jun 19, 2010 3:09 am, edited 1 time in total.
Ninjamaster1470
Postby Gaieus » Sun Jun 13, 2010 5:02 am
You do not really need to open it just drop into the plugins folder in your SU application.
Otherwise rb files are text files and should be opened with some simple text editor (never with some word processor!).
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby McGyver » Fri Jun 18, 2010 5:52 pm
I just tried this out on my G5(Power PC) Mac using SU 6 free version... it works like a charm! I look forward to experimenting with this! Awesome job! Thank you!!!
McGyver
Postby angor2005 » Sun Jun 20, 2010 9:35 am
Please Russian translation.
Many Thanks to you all !
angor2005
Postby aiwkha » Mon Jun 21, 2010 8:57 am
So nice plugins. :berserk:
aiwkha
Postby blajnov » Mon Jun 21, 2010 5:54 pm
angor2005 wrote:Please Russian translation.
blajnov
Postby Gaieus » Mon Jun 21, 2010 8:17 pm
:thumb:
User avatar
Administrator
SketchUp version: 8
License type: Pro
Postby McGyver » Mon Jun 21, 2010 10:13 pm
Hi. I've been playing around with this and have found some good uses for this plugin. The one thing I'm not getting is, which setting (if any) controls the number of (leafs, blades of grass, etc.) that are generated... I've been trying to get smaller number of "blades per inch" but I'm not really noticing much of a difference. I figured it would be Density(Num/m2) and or MaxNumber(/face)... I went as low as 10 on a 4 ft x 4 ft square and I really can't tell the difference between these set at 200... :?
Any suggestions or help in this matter is greatly appreciated.
EDIT- Never mind, I figured it out... I was using sandbox and the faces(grids) were too small... works fine otherwise.
McGyver
Re: [Plugin] Make Fur (Updated - v.1.4c Jun 24, 2010 12:46 p
Postby tak2hata » Thu Jun 24, 2010 4:59 am
Hi all.
I update makefur to version1.4c(webdialog test for mac)
    fixing webdialog problem on mac os.
    (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
I wish this working on mac!
McGyver wrote:Hi. I've been playing around with this and have found some good uses for this plugin. The one thing I'm not getting is, which setting (if any) controls the number of (leafs, blades of grass, etc.) that are generated... I've been trying to get smaller number of "blades per inch" but I'm not really noticing much of a difference. I figured it would be Density(Num/m2) and or MaxNumber(/face)... I went as low as 10 on a 4 ft x 4 ft square and I really can't tell the difference between these set at 200... :?
4 ft x 4ft = 16 ft.sq
16 * 10(num/m2) = 160.
16 * 200(num/m2) = 3200.
If you keeping MaxNumber(/face) as 200,then It makes 200 fur on each faces.
16 x200 = 3200 changes to 200.
So you should glow MaxNumber(/face) like 4000.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby mariocha » Thu Jun 24, 2010 3:34 pm
I'm so sorry to have to report the web dialogs still do not work on Mac here. Empty.
I have other plugins that use them, and they work just fine.
Mario C.
User avatar
mariocha
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby jeabdc » Thu Jun 24, 2010 6:07 pm
I don't understand about "assign_material"&"get_from_material".
Thank Jeab from Thailand :D
jeabdc
Postby Oxer » Fri Jun 25, 2010 12:35 am
mariocha wrote:I'm so sorry to have to report the web dialogs still do not work on Mac here. Empty.
Hello mariocha,
I work on Mac too, and the web dialogs don't appear but i find a solution for resolve this problem, edit "fur_en.rb" (with TextWrangler for example) and delete this sign "#" in the lines 638 and 1609, now the web dialogs will work.
There is a problem yet, all performances of Crowd work but when you select a component for crowd the plugin create a noname group on surface but isn't a group with your component selected, it's a group of triangles, i don't know why.
I hope that tak2hata help us for resolve this problem.
Bye!
User avatar
Oxer
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Re: [Plugin] Make Fur (Updated - v.1.4d Jun 25, 2010 12:34
Postby tak2hata » Fri Jun 25, 2010 4:40 am
Thanks Mario and Oxer. :lol:
I change "#" in line(638 and 1309).
now, version is 1.4d.
I wish this work on mac very well.
Oxer wrote:There is a problem yet, all performances of Crowd work but when you select a component for crowd the plugin create a noname group on surface but isn't a group with your component selected, it's a group of triangles, i don't know why.
Bye!
I will examine the part again.
Please wait.(few days)
Thanks a lot.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby tak2hata » Fri Jun 25, 2010 4:47 am
jeabdc wrote:I don't understand about "assign_material"&"get_from_material".
Hi jeabdc.
Now, "assign_material"&"get_from_material" do not work.
It assign the parameters of fur to current material.
If exporter plugin include the function of make fur,It will perform.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby pyroluna » Fri Jun 25, 2010 10:46 am
is there any difference between 1.4b and 1.4d(c?) if I'm on a windows machine?
User avatar
pyroluna
SketchUp version: 8
License type: Pro
SketchUp use: education
Postby mariocha » Fri Jun 25, 2010 2:06 pm
Feedback on 1.4d.
Yes! the web dialogs show properly now.
But ...
Make crowd stops short at "Calc __ polygons".
And for Fur, units have only one choice, Imperial, Input box and web dialog. normal ?
Mario C.
User avatar
mariocha
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Re: [Plugin] Make Fur (Updated - v.1.4e Jun 25, 2010 10:43
Postby tak2hata » Fri Jun 25, 2010 2:53 pm
I update version1.4e.
Change is only one thing.
remove from context menu.
Pyroluna wrote:is there any difference between 1.4b and 1.4d(c?) if I'm on a windows machine?
Hi ,Pyroluna.
Recently changes do not effect windows machine.
When I will change big thing ,I will increase version number to 1.5 higher.
mariocha wrote:Feedback on 1.4d.
But ...
Hi ,Mario.
I will examin that problem.
Please wait.
"Units" is only seeing units working with sketchup.
so it can not change.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby rombout » Fri Jun 25, 2010 10:26 pm
finally had a project to test.
this is my first and only test yet, i did need to manually adjust everything to my desire though.
But im gonna 'play' with it a lot more!!!!!
:fro:
User avatar
rombout
Postby Burkhard » Tue Jun 29, 2010 12:03 pm
Here is the German file
User avatar
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: interior design
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: chmaka, Dave R, mbouchard, radiacor and 5 guests
