SketchUcation Plugin Store
[Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Re: [Plugin] Make Fur (Updated - v.1.3k May 29, 2010 9:33 am
Postby d12dozr » Sat May 29, 2010 4:23 am
Thanks for the wonderful plugin...and the continual updates :thumb: :D
...and congratulations on making the Sketchupdate!! :enlight:
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: product design
Level of SketchUp: Advanced
Postby Aidus » Sat May 29, 2010 8:30 am
Thanks tak2hata!
Now it works!
CPU: Intel Core i7 Extreme Edition 965
RAM: OCZ Gold DDR3 1600MHz 12Gb
Video: Asus Radeon HD4870 X2 2Gb
Mobo: Asus P6T Deluxe 1366 Intel X58
Aidus
Postby thomthom » Sat May 29, 2010 9:15 am
tak2hata wrote:On my sketchup(windowsVista,locale Japanese,sketchup v7.1),Ruby written in UTF-8 do not work.loading error.
So I use UTF-8 without BOM.If there is problem,please tell me.
I have also gotten problems when I have tried to save .rb files as UTF-8.
But your HTML files and translation files should be saved as UTF-8.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Gaieus » Sat May 29, 2010 10:09 am
Hm. Updated to the latest (1.3k) version and no fur is made on my system.
Thom, you use comma as a decimal separator, don't you? How does the plugin work on your system; on mine it's loaded with dots and if I leave it like this, no fur is generated but if I change it to comma (as my system would use) there's no fur either.
And yes, tak2hata, congrats to the SkecthUpdate Blog (and of course, thanks again for the plugin)
:thumb:
User avatar
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby bimbachi » Sat May 29, 2010 12:31 pm
1.3 k not working at all. I have a lot of plugins , hard to find conflict if any.
bimbachi
Postby Daniel S » Sat May 29, 2010 12:43 pm
Hi tak2hata
The new version 1.3k is not working for me too.
Here a screenshot of my ruby console:
Daniel S
Daniel S
Postby bimbachi » Sat May 29, 2010 12:46 pm
tak2hata wrote:Webdialog html add "....charset = 'UTF-8'"
Save this plugin in UTF-8(withoutBOM) format.
It don't work on my sketchup when using UTF8(withBOM).
can anyone help and explain for simple person like me what exatly it means (quote)
how to make this "UTF-8(withoutBOM)" on mac ???
thanks
bimbachi
Postby Gaieus » Sat May 29, 2010 12:53 pm
That's an encoding type to make sure different non-English characters "render" correctly. Like áíűőüöúóé for my language.
The file is already encoded in UTF-8 (without BOM) so I guess you should do nothing really. Also, this should not affect the functioning of the plugin - only the appearance of these foreign characters in the webdialog.
User avatar
Administrator
License type: Pro
Postby Didier Bur » Sat May 29, 2010 1:04 pm
V1.3k not working here too. This is a variable type conversion error:
line 1443: Error: #<ArgumentError: Cannot convert "0.2" to Length>
@ tak2hata:
the variable tstr is a string to be converted to a float, and if the decimal separator (in your windows settings I guess) is a dot, it doesn't work.
Try: "0.2".to_l in the console, and you'll get: Error: Cannot convert "0.2" to Length>
Try: "0,2".to_l and you'll get 7.8740157480315 (inches)
Try: "0.2".to_f.to_l and it works, but returns 0.2 (inches) which is false.(0.2m != 0.2inch of course)
Try: "0.2".to_f.m, it works and you'll get 7.8740157480315 (inches)
Hope this helps,
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Postby bimbachi » Sat May 29, 2010 1:07 pm
Gaieus wrote:That's an encoding type to make sure different non-English characters "render" correctly. Like áíűőüöúóé for my language.
thank you
bimbachi
Re: [Plugin] Make Fur (Updated - v.1.3L May 29, 2010 9:52 pm
Postby tak2hata » Sat May 29, 2010 2:00 pm
I update to verison1.3L.
Sorry, in previous version,I change the value converting method.
I want to fix the problem that "-50mm".to_l.to_s turn to "~ -0'" , when sketchup units setting is "Feets",etc.
Problem in previous version caused to that.
I returned it to older version.
I think that it moves perhaps.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Level of SketchUp: Intermediate
Postby Didier Bur » Sat May 29, 2010 5:12 pm
V1.3L not working either: no error message, no fur, nothing happens :shock:
EDIT: it works if I switch the model units to inches. There's definitely something wrong with unit management.
Doesn't work if I set "root width" to "0,5" but works with "1,1", same goes with "length" parameter, so I think that
is not fixed yet.
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Re: [Plugin] Make Fur (Updated - v.1.3j May 24, 2010 11:22 p
Postby Fletch » Sat May 29, 2010 6:01 pm
massimo wrote:
Fletch, your leaves are not overlaping! how did you achieve that?
Perhaps he deleted some overlapping components later? ;)
Glad you like it... I do too! :)
No. I deleted nothing.
There are 12 new leaves we made (free) for licensed users of Twilight... available here.... along with a video tutorial and the practice scene.
Twilight Render also has no problems exporting these 2400 leaf instances in this image (took about 1sec. to process the file) and they render perfectly.
The "secret" to not overlapping is that the leaf component is made to be at approx. 15 degree angle away from the face, the way they grow.
But yes, the sizes and angle should perhaps be "jittered" or "changed" a bit more... it was just a quick test. ;)
Fletch
Twilight Render
Re: [Plugin] Make Fur (Updated - v.1.3m May 30, 2010 11:53 a
Postby tak2hata » Sun May 30, 2010 3:59 am
Hi,all.
I update to verison1.3m.
It changes LengthPrecision temporary.
So using units "m" has no problem , now.(perhaps).
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby Gaieus » Sun May 30, 2010 10:06 am
Yes, this is working, thank tak2hata!
I can make fur again
:ecstatic:
(now just exploring all the settings...)
User avatar
Administrator
License type: Pro
Postby JClements » Sun May 30, 2010 3:24 pm
Gaieus: That's Shaga-delic.
John
Illustrator
Beaverton, Oregon
User avatar
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby saturne45 » Sun May 30, 2010 3:56 pm
Hello, very great job... make fur is very nice. thank you.
saturne45
Postby tald311 » Sun May 30, 2010 4:24 pm
Thank you. This is great.
tald311
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby Click Draw » Sun May 30, 2010 6:51 pm
Been playin'....this is very cool! I hope PETA doesn't get wind of this :roflmao:
Thanks very much for this!!!
Jeff
Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Click Draw
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby realist » Mon May 31, 2010 10:34 am
Hi, I'm new to Sketchup and about to climb the learning curve.
I saw the Fur plugin and thought it would be a cool additon to Sketchup. I clicked on the link to download it but all that does is refresh the page. It doesn't download anything. Am I missing something here? Thanks.Gary
realist
Postby JollyFather » Mon May 31, 2010 11:22 am
Thanks a lot!!!
Best regards,
JF
JollyFather
Postby paulower » Mon May 31, 2010 3:33 pm
Hello Tak2hata.
I have spoken these days about the plugin, which is one of the best I've seen so far for our dear SketchUp.
Is there a way the dialog can remember it's position on the screen? I always expect it to reopen where I put it the previous time. :)
Any chance this feature soon?
Hi,all.
I updated this plugin to version1.3i.
Webdialog sees easier.(Thanks Diego.)
Parameter name translates by langage text file.
Thanks.
If you wish, I can provide the translation from Portuguese languaje from Make Fur
_______________________________
My Blog
Baú SketchUp
paulower
Postby thiloo » Mon May 31, 2010 3:37 pm
thank you so much, I already love this Plugin!
some question:
- what´s the "Valid Distance" for?
if I choose "make by Component: no"
and enter something different than 0,000m it´s not working.
if I choose "make by Component: yes"
it´s working, but seems to have no effect.
- Also, if I select "make by Component: yes" the results are looking quite different from when I select no". for example: the force values seem to have stronger impact on component:yes.
thiloo
Postby tak2hata » Tue Jun 01, 2010 1:22 am
Hi, thiloo.
thiloo wrote:some question:
The Valid Distance is validate fur about distance from camera.
So This value is large.like 20m.
But 0 make all valid.it do not omits fur.
Example.Use valid distance = 8000mm.
Hi,paulower.
Sorry ,Now I examines the method to remember dialog position.
That demands the javascript knowledge from me.
I will update few day later.
Thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby autarchos » Tue Jun 01, 2010 6:35 am
Dear Mr. Paulo Wer:
That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
Besten Grüßen,
Drazen Petrovic
autarchos
Postby thiloo » Tue Jun 01, 2010 11:29 am
thanks tak2hata for the quick explanation,
wow, that´s also an powerful feature.
sadly it´s not working if I choose "make by component - yes"!
also, with component activated, the reaction to the force settings are quite unexpected?
I need the components for instancing -> rendering.
again, Thank You for your time and effort
thiloo
Postby thomthom » Tue Jun 01, 2010 11:30 am
I see the same issue that thiloo describes.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Jun 01, 2010 12:09 pm
Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/0 ... dling.html
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby bryan_gibson79 » Tue Jun 01, 2010 5:38 pm
As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
BG
bryan_gibson79
Postby autarchos » Tue Jun 01, 2010 6:44 pm
Didier's Hide Faces/Edges plug-in is one method:
http://rhin.crai.archi.fr/RubyLibraryDe ... s_edges.rb
bryan_gibson79 wrote:As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
BG
autarchos
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: asep3suryana, dcbCreative, Google Feedfetcher, ireneadler, jarmy, Majestic-12 Bot, mark151, mirceastef, onkravets, parkmancarter, Raffao222 and 11 guests
