[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Postby fredo6 » Thu May 27, 2010 12:00 am
From now on, the information on Curviloft is maintained on the Plugin Home Page of Curviloft. This is also where you can download the RBZ file.
Requirement: LibFredo6 v8.6j or above
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
Requirement: LibFredo6 8.1c or above
Curviloft is a script dedicated to Loft and Skinning, that is, generation of surfaces from contours.
  • Loft by Spline joins separate contours, open or closed, by smooth splines
  • Loft along Path joins contours, along a given rail curve.
  • Skinning create surfaces bounded by 4 or 3 contiguous contours
Because there are many solutions to calculate Loft and Skinning geometries, the script offers various options to adjust parameters depending on the configuration of contours.
92
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Postby Rich O Brien » Thu May 27, 2010 12:06 am
Hi Fredo,
Great to hear it's getting close to release! The video is amazing :shock:
Will post back with examples for testing
Thanks for sharing
Rich
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Daniel S » Thu May 27, 2010 12:18 am
:sketchstatic: :sketchstatic: :sketchstatic:
Fredo!!!
you are a genius!!!
I don´t know if something like this one will work...
but here I attach a panton chair.
I have to see this video again and again :bounce: :bounce:
Daniel S
Daniel S
Postby fredo6 » Thu May 27, 2010 12:39 am
Daniel S wrote:I don´t know if something like this one will work...
Daniel S
Daniel,
I had to put some splitter (i.e. line) to get contours with 4 parts.
Here is the file and a short video.
User avatar
PluginStore Author
PluginStore Author
Postby Daniel S » Thu May 27, 2010 12:55 am
Looks like it is the most powerful plugin ever made. :sketchstatic: :sketchstatic: :sketchstatic:
Daniel S
Daniel S
Postby utiler » Thu May 27, 2010 1:04 am
I feel like a kid at christmas time who knows what he's getting but can't open his present yet!!!!
You never seem to amaze, Fredo!
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby JClements » Thu May 27, 2010 3:33 am
WOW! Way to go!
Any chance, once a skin is made, that could be some axial controls that could be dragged to do stretching such that the skin would react like what is done in Soapskin and Bubbles where the forming edges are anchored and the skin stretches relative to the forming edges? Perhaps have a tightness parameter to control how close the skin conforms to a path or to the defining edges? Could the path be altered interactively to reshape the skin?
Tapering. Really would like to create Reduced Elbows for Piping or Ducting systems. Draw a "welded" curve for a path, place circle or "donut" tangential at each end of the path with specific radii/diameter and then form the skin of pipe (inner diameter as well as outer diameter too?). Have a means to minimize the amount a faces formed. Transitions of the ribbing of pipe would be linear versus what looks like an averaging method used in your video for "freeform" skins. It would be fantastic if the end diameters were parametric so user could change their values.
John
User avatar
JClements
Premium Member
Premium Member
Postby EscapeArtist » Thu May 27, 2010 3:38 am
Looks fantastic, really looking forward to seeing the finished product in operation.
User avatar
EscapeArtist
Top SketchUcator
Postby EarthMover » Thu May 27, 2010 3:51 am
Holy crap!!! Is that speed realtime? Looks amazing! Do the number of segments in the rails matter? Could this possibly be used to replace the standard from contours in the sandbox tools to create graded terrains?
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby xrok1 » Thu May 27, 2010 5:18 am
WOW! i love how you ruby greats are dragging SU kicking and screaming into the realm of a "real" 3d modeling program! :ecstatic:
screw you google. if you won't give us proper tools someone will. :twisted:
thanks Fredo, and everyone; TIG, ThomThom, Chris, Jim, Dedier, Whaat... just to name a few. you guys ARE the real SU team. all we really need from google is poly support. you guys cover the rest.
xrok1
Postby vidy » Thu May 27, 2010 7:19 am
BRAVO FREDO :bounce:
still so much to learn..
vidy
Postby Panga » Thu May 27, 2010 7:46 am
Really big thanks for investing so much time to give us so niceeeee plugins !! I'll try to post a file to test it on terrain modelling, which is my main occupation in SU.
Panga
Premium Member
Premium Member
Postby thomthom » Thu May 27, 2010 7:47 am
Looking very nice. Can one edit the control splines afterwards?
1:24 - Float Pal window: is that done using view.draw* method?
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Thu May 27, 2010 8:14 am
The Fredo return! :fro:
What a teaser! :ugeek:
What about make a thickness to a surface?
Speedy Galerie
User avatar
Top SketchUcator
Postby fredo6 » Thu May 27, 2010 8:26 am
Pilou wrote:The Fredo return! :fro:
I guess this is a job for JPP. Curviloft only generates the thin surface.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Thu May 27, 2010 8:40 am
JPP : the "Jean Pierre Papin des surfaces" ;)
( a famous French footballer ;)
-1
Speedy Galerie
User avatar
Top SketchUcator
Postby fredo6 » Thu May 27, 2010 8:43 am
thomthom wrote:Looking very nice. Can one edit the control splines afterwards?
Tom,
Yes the button palettes are all based on view.draw methods. And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Thu May 27, 2010 9:12 am
As ever, a "tour de force".
Can't wait to try your new tools...
Very impressive interface and speed.
:bounce:
User avatar
Global Moderator
Postby CadFather » Thu May 27, 2010 9:57 am
sugar.. everytime Fredo starts these things, it's like another copernican revolution! :lol:
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 10:00 am
Fredo6 wrote:And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
Is that adjustments one makes before you end the tool? Or can you take a shape you created earlier and readjust it? On other words, is it parametric?
User avatar
PluginStore Author
PluginStore Author
Postby fredo6 » Thu May 27, 2010 11:30 am
It's difficult to make things parametric in Sketchup, because all you have at the end is faces and edges.
My plan to help a little bit would be to attach some information to the Component created so that you can reedit later on.
also, and already working is the possibility to generate the juctions as curves so that when you move the profiles, then the shape deforms accordingly (something that is shown in Kirill's scripts).
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 27, 2010 11:34 am
Yea - it was something like that I was wondering if it would do. Very promising!
Once I get Vertex Edit out of the way I want to make Bezier Path modelling tools. The control points stored as attributes for later edit-ability. Of course, if the user was to edit the geometry with other tools that would be ignored.
If the observers behave better in the next SU I want to make modifiers that one can apply to groups/components. Stack them up and apply the modifications after the user edit the base shape.
User avatar
PluginStore Author
PluginStore Author
Postby notareal » Thu May 27, 2010 11:45 am
Stunning! What a return.
notareal
Thea Render Support
Thea Render Support
Postby Mike Lucey » Thu May 27, 2010 12:39 pm
I think I've figured out how Fredo is doing all this fantastic work ...... if you listen carefully to the video you will hear a lot of squeeking going on in the background ....... well these can only be Creative Gremlins! :thumb:
User avatar
Mike Lucey
Mayor
Postby olishea » Thu May 27, 2010 2:25 pm
wow :shock:
oli
User avatar
olishea
Premium Member
Premium Member
Postby jim smith » Thu May 27, 2010 4:26 pm
Big thanks in advance for creating this plugin. :ecstatic: Frank Gehry will probably be switching to GSU pretty soon if Fredo keep this up :roll:
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
User avatar
jim smith
Premium Member
Premium Member
Postby shura » Thu May 27, 2010 4:29 pm
Omg, we are drowning in pleasant anticipation!
User avatar
shura
Postby Rainie » Thu May 27, 2010 4:53 pm
Hi all,
where we can download this very helpful plugin!!! Thanks!!!
Rainie
Postby thomthom » Thu May 27, 2010 5:10 pm
Rainie wrote:Hi all,
When it is released. This was just a teaser. ;)
User avatar
PluginStore Author
PluginStore Author
Postby solo » Thu May 27, 2010 5:35 pm
Fredo strikes again!!
Looking forward to another true Gem.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: Ashesh maharjan, ntxdave and 14 guests
Visit our sponsors:
