[Plugin] Edge Tools
[Plugin] Edge Tools
Postby thomthom » Sun Dec 20, 2009 7:40 pm
Overview
Collection of some small edge tools I needed for my work.
Access
Tools > Edge Tools
View > Toolbars > Edge Tools
Features
 Divide Face (v1.1.0)
 Close Gaps (v2.0.0)
Co-linear Edges
Select any sets of connected edges. (Other entities and edges that form loops are ignored.) For each set, the points between the first and last point will be made co-linear to the first and last point. You can also choose to restrict the adjustments of the points to a given direction.
Curve Simplification
"Curve" does here not mean a Curve entity. You don't have to weld anything together. It's just a series of connected edges selected. You can select multiple curves to run this command on. Good for after importing CAD plans of contours.
Algorithm used is the http://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
When you are prompted for an epsilon value it refers to the distance b in the above illustration. It's max distance any point is allowed to deviate from the simplified polyline.
The curves must not connect to anything else and not fork. The resulting simplified curve is created as a Curve entity.
Note: The plugin does not check for forking curves. If you see unexpected behaviour - check that your selected curves doesn't fork.
Requirements
  • SketchUp 7 or newer - ( Other versions untested )
  • TT_Lib2 (v2.5.4)
Download
 Footprint
<Sketchup>/Plugins/
tt_edgetools.rb
TT_EdgeTools
Images
close_gaps.rb
core.rb
divider.rb
make_colinear.rb
simplify.rb
10
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Edge Tools (1.0.1) — 20 Desember 2009
Postby thomthom » Sun Dec 20, 2009 8:22 pm
Small bug-fix.
User avatar
PluginStore Author
PluginStore Author
Postby Gaieus » Sun Dec 20, 2009 8:29 pm
This looks very useful, thanks Thom. I remember cases when I had to move vertices one by one manually to end up with something this plugin is capable of. :thumb:
User avatar
Postby wind-borne » Sun Dec 20, 2009 9:01 pm
Thanks, this will be extremely useful in my work :!: and outside of work :D
"To read between the lines was easier than to follow the text."OSX 10.11.6 _ _ _ _ _ SU 8 pro
User avatar
wind-borne
Premium Member
Premium Member
Postby Khai » Sun Dec 20, 2009 9:39 pm
so just so I'm sure, this aligns vertices to one straight line?
if so this is a great import clean up tool...
Khai
Postby thomthom » Sun Dec 20, 2009 9:48 pm
Khai wrote:so just so I'm sure, this aligns vertices to one straight line?
yes.
User avatar
PluginStore Author
PluginStore Author
Postby Khai » Sun Dec 20, 2009 9:56 pm
oh you just made my day...
I'm getting a lot of faces divided on import bringing my work over from trueSpace - in tS, they are quads and there's no issue.. but in SU, they are tri'd.. the vertices are ever so slightly out of alignment.. tS does not care... SU does... this should then fix those faces :)
Khai
Postby pilou » Mon Dec 21, 2009 12:20 am
cool tools sets! :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby EarthMover » Mon Dec 21, 2009 1:00 am
Thanks Thomthom. Very useful. Max has something similar to straighten edges in the edit poly modifier called Make Planar. Adding the Make Colinear also is a nice touch.
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby a4chitect » Mon Jan 04, 2010 3:26 pm
perfect tool - thanks!!!
a4chitect
PluginStore Author
PluginStore Author
Postby simon le bon » Mon Jan 04, 2010 7:38 pm
Hi Thomas,
You are incredibly productive and innovative.
One more time, this one promise to be strongly useful (I'm reminding the number of times this tools was missing to me)..
my thanks and my respect,
simon.
User avatar
simon le bon
Postby thomthom » Mon Jan 04, 2010 7:41 pm
simon le bon wrote:Hi Thomas,
simon.
Thanks for your kind words.
simon le bon wrote:(I'm reminding the number of times this tools was missing to me)
Co-linear Edges, or Curve Simplification?
User avatar
PluginStore Author
PluginStore Author
Postby Panga » Mon Jan 04, 2010 11:19 pm
Thanks for this new tool !! I'm sure i'll find cases in which it'll be usefull.
Panga
Premium Member
Premium Member
Postby simon le bon » Tue Jan 05, 2010 1:20 am
Co-linear :thumb: ;)
User avatar
simon le bon
Postby Pixero » Thu Jan 07, 2010 8:17 am
Wow, I've totally missed this. Great plugin.
User avatar
Pixero
Postby mknorr » Wed Apr 14, 2010 3:14 pm
I am sure this is a stupid question but where does one get this plugin? None of the links here take me anywhere.
User avatar
mknorr
Postby thomthom » Wed Apr 14, 2010 3:20 pm
mknorr wrote:I am sure this is a stupid question but where does one get this plugin? None of the links here take me anywhere.
At the end of the first post in the thread. Look for the cookie. ;)
User avatar
PluginStore Author
PluginStore Author
Postby mknorr » Wed Apr 14, 2010 3:24 pm
See, it was a stupid question :oops:
Thank you Sir
User avatar
mknorr
Re: [Plugin] Edge Tools (1.1.0) — 05 May 2010
Postby thomthom » Sun May 09, 2010 2:50 pm
Update v1.1.0
New:
  • Divide Face (See video in main post.)
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Sun May 09, 2010 2:57 pm
That is very good! :thumb: :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby autarchos » Mon May 10, 2010 9:38 pm
ThomThom - the divide face plugin is amazing. i'm redrawing thousands of parcels from the 1960s in a city and this has really just made tedious work about 10 times faster. you're a god!
autarchos
Postby thomthom » Mon May 10, 2010 9:56 pm
:D Glad you liked it. It came about because I realised I was repeatedly drawing guidelines offset from and edge, draw an edge, erase guideline. Wanted to merge this into one operation. I often do this while working on façades.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Mon May 10, 2010 10:13 pm
Very practical for have your own grid! :fro:
Here with Protrude by Jim Foltz and Random Painter by Chris Fullmer
@ Thomthom : have you in your Selection Toys or other plugs something that select only oriented faces external? (with any orientation ("White faces")
for this object for example :?:
external.skp
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Mon May 10, 2010 10:28 pm
hm... no...
this one is a thinker...
User avatar
PluginStore Author
PluginStore Author
Postby gavvy » Tue May 11, 2010 5:47 am
:( oh no .....
what a XX tool :thumb:
gavvy
PluginStore Author
PluginStore Author
Postby gavvy » Tue May 11, 2010 5:49 am
:shock:
Tomtom ,can i have your msn-account-name??
gavvy
PluginStore Author
PluginStore Author
Postby pilou » Tue May 11, 2010 8:22 am
hm... no...
Because after this will easy to have a uniform object well oriented! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Tue May 11, 2010 8:38 am
Pilou wrote:
hm... no...
If the purpose is to orient all faces, then right click a face and choose Orient Faces.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Tue May 11, 2010 8:49 am
No, it's not so simple ;)
Try with the object linked above!
You must select by hand all different aeras and make different Reverse before Orient :o
Easy with this object but for a more complex, it's a mess! :roll:
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Tue May 11, 2010 9:00 am
Ah, yea, I see now that there are a couple of problem areas. The problem here is knowing programmatically what is "outside".
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: daisuke12, Felipe88, Google Bot, gsusgil and 15 guests
Visit our sponsors:
