[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur
Postby rickgraham » Wed May 05, 2010 7:24 pm
rickgraham wrote:
tak2hata wrote:Hi, Jeff and rick.
I update Fur_en.rb
The WebDialog has problem in Mac OSX.
So I put another menu for the correspondence of this problem.
The menu named "fur!(MAC)".
Using InputBox Dialog.
How in this?
I cannot tell what the intended difference between the 1 - Linear and 2- Arch are. By the way, the Mac only shows 1,2,3,4 - I saw another persons screen shot which showed me what they were for.
Rick
rickgraham
Postby jeff hammond » Wed May 05, 2010 7:37 pm
I update Fur_en.rb
How in this?
yep, we're growing some fur now :D
thanks!
User avatar
Global Moderator
Postby solo » Wed May 05, 2010 7:44 pm
Was just a matter of time until someone posted hairy balls. :mrgreen:
www.solos-art.com
I'm a social vegan, I avoid meet.
User avatar
Global Moderator
Postby xrok1 » Wed May 05, 2010 7:48 pm
i can hear all the script writers now
"Why the fook didn't i think of that? :? , its so fookin simple too! :shock: "
:roflmao:
awsome, simply awsome! :D
xrok1
Postby rickgraham » Wed May 05, 2010 8:01 pm
xrok1 wrote:i can hear all the script writers now
:roflmao:
This is a banner day for me and SU. :berserk:
Rick
rickgraham
Postby ken28875 » Wed May 05, 2010 8:26 pm
Wow...I am speechless...fur for Sketchup! :o :shock:
:thumb: :thumb:
_KN
Follow Your Dreams.
User avatar
ken28875
Postby thomthom » Wed May 05, 2010 8:30 pm
Mandatory:
User avatar
PluginStore Author
PluginStore Author
Postby ark » Wed May 05, 2010 8:58 pm
Absolute fantastic :berserk:
Somehow I can't seem to generate short hair?
I set the "Lenght" to 0.0001 but the hair doesn't seem to get shorter then approx. 50 mm!
It would be nice to be able to save presets!!!
Great job 8-)
ark
Premium Member
Premium Member
Postby solo » Wed May 05, 2010 9:23 pm
Teddy fur.
Which all but choked SU to death.
www.solos-art.com
User avatar
Global Moderator
Postby minguinhirigue » Wed May 05, 2010 9:34 pm
Really nice one I missed from a long time... :berserk: Thanks.
minguinhirigue
Postby Mike Lucey » Wed May 05, 2010 9:59 pm
Thanks tak2hata,
I can see this plugin becoming a great favorite :thumb:
Mike
User avatar
Mike Lucey
Mayor
Postby utiler » Wed May 05, 2010 11:31 pm
No way!!
Now I can see what a woman looks like with a beard. :berserk:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby Whaat » Thu May 06, 2010 3:25 am
Great plugin! Thanks for sharing!
Whaat
PluginStore Author
PluginStore Author
Postby CadFather » Thu May 06, 2010 8:36 am
Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! :enlight:
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby tomasz » Thu May 06, 2010 8:55 am
Hi, Thanks a lot for such an interesting plugin!
tak2hata wrote:Creating Too Much Polygon is very slow.
And to use code "entities.fill_from_mesh" must need blank Group.
This Plugin executes each selected faces.
Creating Group each new 800 polygons.
so it parts.
I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
Would it be possible?
Cheers
Tomasz
tomasz
SU2TH & SU2KT Developer
Postby CadFather » Thu May 06, 2010 8:59 am
yes please.. :thumb:
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 06, 2010 9:18 am
Tomasz wrote:I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
User avatar
PluginStore Author
PluginStore Author
Postby notareal » Thu May 06, 2010 9:36 am
Cheers
Tomasz
That would be great!
notareal
Thea Render Support
Thea Render Support
Postby olishea » Thu May 06, 2010 10:03 am
one of the best plugins around!!
i'm making everything furry! :fro:
render cooking :D
oli
User avatar
olishea
Premium Member
Premium Member
Postby tomasz » Thu May 06, 2010 10:05 am
I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. :)
tomasz
Postby thomthom » Thu May 06, 2010 10:18 am
That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
User avatar
PluginStore Author
PluginStore Author
Postby olishea » Thu May 06, 2010 10:34 am
so much fun!!
would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking.
would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present.
Sketchup view of an old model of mine:
oli
User avatar
olishea
Premium Member
Premium Member
Postby tridem » Thu May 06, 2010 11:05 am
one more THANK YOU :sketchstatic:
...and one more request :lol: in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
User avatar
tridem
Postby thomthom » Thu May 06, 2010 11:11 am
tridem wrote:...and one more request :lol: in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
User avatar
PluginStore Author
PluginStore Author
Postby massimo » Thu May 06, 2010 11:34 am
Really funny thank you tak2hata! :thumb:
User avatar
massimo
Postby KarinaGM » Thu May 06, 2010 11:38 am
Wow!
Amazing tool.
I've just downloaded it and can't wait to start (playing) experimenting
THANKS!
"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
-Benjamín Franklin.
KarinaGM
Postby tridem » Thu May 06, 2010 12:48 pm
thomthom wrote:..
I believe so... eg 'round corner' can do it
User avatar
tridem
Postby tak2hata » Thu May 06, 2010 1:58 pm
I updated the plugin. it's version 1.0.
I saw some requests now.
It seems to be difficult in my skill.
Hereafter, I will study Ruby more.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 06, 2010 2:25 pm
tak2hata wrote:I updated the plugin. it's version 1.0.
:D Yea, you've started something. :)
If you need help with anything just ask at this forum, people are happy to help.
User avatar
PluginStore Author
PluginStore Author
Postby olishea » Thu May 06, 2010 2:26 pm
beautiful plugin.
I placed the grass on hidden layer and replaced the component with a single line. Then rendered in twilight using "render all hidden layers" option.
so each line represents blade of grass.
close up of components
twilight render
oli
User avatar
olishea
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: matrejohn and 14 guests
Visit our sponsors:
