SketchUcation Plugin Store
[Plugin] Component Stringer UPDATED May 23, 2013
Re: [Plugin] Component Stringer UPDATED Nov. 16, 2009
Postby utiler » Thu Feb 11, 2010 10:58 am
Pilou wrote:Suggestion
A rotation (s) of object on it own axis?
A scale of object?
What I wished for a while now.... viewtopic.php?f=180&t=19204&hilit=+copy+rotate+scale
I wish I could explain!!!
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby KXI System » Wed Mar 10, 2010 11:27 pm
Chris, I love your tools but just one thing...
This plugin I can't get to work for some reason, I even reinstalled it. Nothing happens when I even activate it, here is what I get in the Ruby console:
Error: #<NoMethodError: undefined method `definition' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:103:in `main'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in `call'
See Chris? a little help here?
Getting the perfect sig is hard...
Google it!
KXI System
Postby Chris Fullmer » Thu Mar 11, 2010 12:21 am
Thank you for reporting the error with the error codes from the console, helps spped things up a bit!
It looks like you do not have a component selected when you start the script. So make sure that you select a component first, then start the script.
If that does not fix it, please upload a test model that you are having problems with and I'll test it.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby KXI System » Thu Mar 11, 2010 1:47 am
Chris,
After a few moments of struggle I found out that the script works after a few failures...
But what I have found is that sometimes the selected component changes during action, see attachments:
Bug1.skp
Ruby Console:
No reversing needed
Error: #<NoMethodError: undefined method `position' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:137:in `main'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in `each_with_index'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in `each'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in `main'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in `call'.
Note: 1 try only
Bug2.skp
Ruby Console:
Error: #<NoMethodError: undefined method `edges' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:59:in `curve_ordering'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:56:in `times'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:56:in `curve_ordering'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:105:in `main'
Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:79:in `add_text'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:79:in `curve_labeler'
C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:70:in `curve_ordering'
Note 10+ tries, no result
Bug3.skp
Ruby Console:
No reversing needed
Note 1 try, "big" problem
Google it!
KXI System
Postby simon le bon » Mon Mar 15, 2010 9:25 pm
Hello Chris, Hello everybody,
I'm back for a little addition in using Component Stringer.
I have had the idea to use a progressive segmented curve in conjunction with Component Stringer for various interesting effects.
It exists a Fredo's tool :Fredo_BZ__Animation which can do the goal. But it is build for animation matters and I had found it not enough flexible for my purpose.
So I have made a small tut to make our Own BZ_animation Curve
I have made some exemples, not very subtle I guess but I think the idea is shown ;)
*s
User avatar
simon le bon
Postby brookefox » Sun May 02, 2010 11:48 pm
Well, I'm happy to post this homely little picture: my first entry into the well-worn spiral stair saga. Contents: the usual suspects: one set of edges, one component (soon to be tuned and embellished with stringers, railings etc.). Why bother this thread? I just thought maybe a point or two needed clarification: In this case the length of each edge determines the displacement of the component, and the component cannot touch the edges or the routine will not work (for me).
Thanks, Chris!!
(For me, it would be nice if the settings were sticky across uses.)
~ Brooke
User avatar
brookefox
SketchUp version: 8
License type: Free/Make
Level of SketchUp: Intermediate
Postby jackalvn » Sun May 16, 2010 5:16 am
Hi Chris, Hi All.
I used the plugin to make an array of component along a path, but it only create one component at the start of the path and nothing else.
I don't know what i do wrong. Any help?
One more thing: The plugin don't give me a choice of inputting distance between components (like Copy to spacing in Copy along path plugin). Or I miss something?
Thanks for your attention!
jackalvn
Postby Chris Fullmer » Sun May 16, 2010 5:23 am
Hi Hu. There is no option for spacing. It always inserts a component at each line segment. There is no way to skip line segments, or evenly space components over uneven lengthed lines.
It should not stop after a single component though. Could you upload the test model where this happened? Thanks,
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby tomislavm » Tue Jun 08, 2010 11:21 am
Thank You Chris!
tomislavm
SketchUp version: 8
SketchUp use: historical reconstruction
Postby maybach67 » Fri Jun 11, 2010 6:16 pm
great plugin, thanks alots
maybach67
Postby pep75 » Sun Jun 20, 2010 11:54 am
:berserk:
unbelievable! Well this is an essential plugin! What can they still do at Google?
SU has become a full functional modeller at the moment...
Thanks Chris!
pep75
Postby grim » Sat Jun 26, 2010 4:31 am
chris
the video shows a great tool and i have put it to the test, i build a chain link and made it a component, however when i apply the plug in it spaces the component far apart and rotates it in odd positions a can not seem to imitate the steps you show in the tutorial video :twisted: is there a problem with this script?
grim
Postby Pilou » Sat Jun 26, 2010 2:08 pm
no :)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Chris Fullmer » Sun Jun 27, 2010 3:02 am
Hi Grim, it is important to pay attention to the x-component axis. This plugin uses the component axis to place the component. So you are going to have to make sure that the axis is placed very strategically. You can post you test model if you are still unable to get it to work,
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby EscapeArtist » Sun Sep 05, 2010 3:21 am
Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
User avatar
EscapeArtist
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby thomthom » Sun Sep 05, 2010 9:43 am
EscapeArtist wrote:Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
Screenshots? Would help with more specific information.
User avatar
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
Postby Chris Fullmer » Mon Sep 06, 2010 7:51 am
Yeah, screenshot please :) I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby sklu » Mon Sep 06, 2010 10:05 am
Component Stringer Loading Problem
I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
Ruby Console showing:
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in `add_text'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in `curve_labeler'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in `curve_ordering'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in `main'
C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
Any help, Chris?
sklu
Postby Chris Fullmer » Mon Sep 06, 2010 10:42 am
Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby sklu » Mon Sep 06, 2010 11:10 am
SU 7 Pro...tried a few different windows..same error occurs..many thanks
sklu
Postby olishea » Tue Sep 07, 2010 10:49 am
Great plugin :thumb:
oli
User avatar
olishea
Premium Member
Premium Member
Postby EscapeArtist » Mon Sep 13, 2010 10:32 pm
I found the bug, it was on this side of my computer screen.
User avatar
EscapeArtist
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby voxdei_999 » Tue Sep 14, 2010 4:48 pm
thanks Chris very useful to me
voxdei_999
Postby Chris Fullmer » Tue Sep 14, 2010 9:44 pm
Great Beto, glad you like it!
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby fabiorossi » Thu Jan 13, 2011 3:22 pm
sklu wrote:Component Stringer Loading Problem
Any help, Chris?
This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
fabiorossi
Postby Chris Fullmer » Thu Jan 13, 2011 8:47 pm
Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
Upload a test model, I'll start by looking at that.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby bentleykfrog » Sat Jan 29, 2011 1:41 pm
Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
bentleykfrog
Postby raffy » Wed Mar 30, 2011 3:30 pm
thank you so much for your help....
raffy
Name: rafael sison jr
Postby solo » Fri May 13, 2011 2:38 pm
I'm getting this:
Code: Select all
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:103:in `main'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:103:in `call'
Nothing happens, no dialogue box.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
License type: Pro
SketchUp use: other
Postby TIG » Fri May 13, 2011 8:58 pm
solo wrote:I'm getting this:
Code: Select all
The relevant code is this [ending line #103
Code: Select all
        sel = model.selection
      comp = []
      $arc_labels = []
      comp_height = []
      sel.each do |e|
        comp << e if e.is_a? Sketchup::ComponentInstance
        edges << e if e.is_a? Sketchup::Edge
      comp_height = comp[0].definition.bounds.depth
So the error is saying that the selection [sel] doesn't contain a component-instance ?
Since 'nil' has no 'definition'...
It could be better trapped to stop if the selection contains no instances but...
SO - question: does the selection contain a component-instance when you run the tool ??
User avatar
Global Moderator
License type: Pro
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: AchilleIT, Bing [Bot], chrisn, Frederik, GaryGB, Glenn jones, jamms, tcarlsondesign and 9 guests
