[Plugin] Select Lines by Length (Updated March 9th, 2009)
If I want all lines of a selection? (not the faces ! )
Can you add something for that? -
Can you add something for that?http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14975
Thx I had another one by Matt666
Selection manager
I will try yours also!Yours seems more cozy!
Even it's a toy!
Adopted!But if Chris can make something like ">length wished" that will be terrific!
Like >0
or
>0 & < 12 -
I might not get to it right away, but adding a selection length range would be easy enoug to do. Thanks for the suggestion.
Cool!
Heyhey! Chris,
Clever idea, wonderfull tool. Many thanks, just continue this way, cause we need such tools simon
Chris,
Would it be possible to also have a script that would select faces all of the same surface area?
Yeah, thats a good idea. I'll see if I can get that implemented. I have 2 others also in progress right now. Hopefully I'll get a chance to finish some of these up today. Thanks for the suggestion,
chris,
another very interesting plugin from you! nice job. thank you so much.
/paolo -
Very good plugin. Is possible to make plugin work only in selection?
I suppose I could. The idea would be to select geometry first, then run the plugin and then when you click, lines only get added if you have cliked on something that is selected? Is that what you mean?
Yes!!!
