[Plugin] Extrude Edges by Loft
Postby TIG » Tue Mar 09, 2010 4:19 pm
    Copyright 2011 (c) TIG
    [Based on some original ideas by Chris Fullmer in his 'Simple Loft']
    All Rights Reserved.
    THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
    WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
    MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
    extrudeEdgesByLoft.rb
    Smoothly connects a series of selected Curves with a bezier mesh.
    Usage:
    Activate the Tool and follow the prompts.
    Select Curves in order [at least 2 are required].
    Each selected Curve is color-coded ROYGBIV as it's picked.
    You may NOT re-select the same Curve again unless it is the first one
    that you selected [Red] and there are at least two curves already
    highlighted.
    If you do re-select this first curve then the mesh might loop into a
    weird convoluted 'doughnut' !
    Double-Click or Press <Enter> to complete the selection of the Curves.
    You are now prompted for the Number of Mesh Segments between each pair
    of Curves - the initial value is based on the maximum number of
    segments found in the Curve set.
    Press OK to accept this value, or enter a new value [>0] and press OK,
    or press Cancel to stop the operation.
    The mesh is made with 'bezier' linking forms, and faces oriented.
    You are then prompted Yes/No to:
    To Reverse the Faces.
    Quad Faces
    Smooth the Mesh.
    Erase the Originally Selected Curves.
    Curves can have unequal number of segments - although keeping their
    segmentation the same or in simple multipes can give 'smoother' forms.
    The Curves in a 'set' can be looped or open-ended as desired.
    All open-ended or all looped sets should give consistent results.
    Mixing looped and open-ended curves in the same 'set' might give
    unexpected effects.
    It's recommended that you split loops in any mixed sets with a short
    piece of line drawn to 'force' a combined start-point/end-point...
    The tool attempts to loft curves end_to_end without twisting -
    however, some combinations of curves might benefit from having one
    curve 'reversed' - if so explode it and then re-weld, or try edit-cut/
    paste_in_place...
    Donations:
    Are welcome [by PayPal], please use 'TIGdonations.htm' in the
    ../Plugins/TIGtools/ folder.
    OR
    Version:
    1.0 20200309 First Release.
    1.1 20100309 FR lingvo updated by Didier Bur.
    1.2 20100310 Glitch with certain curve segment combinations fixed.
    Progress reporting during face orienting improved.
    1.3 20100311 ES lingvo updated by Diego-Rodriguez.
    1.4 20100312 Chinese lingvo file added by Hebeijianke
    1.5 20100330 Rare glitch with self.xxx fixed.
    1.6 20110812 Inputbox code improved.
    1.7 20111003 Quad Faces option added [smoothed diagonals].
    1.8 20111004 Quad face adjusted to hide diagonals too.
    1.9 20111023 Smooth now ignores edges with only one face.
    2.0 20111113 Quad Faces option adjusted to Thomthom's latest specs.
To download the files for this tool go to this thread http://forums.sketchucation.com/viewtop ... 63#p217663
User avatar
Global Moderator
Re: [Plugin] Extrude Edges by Loft
Postby dedmin » Tue Mar 09, 2010 5:08 pm
:berserk: :berserk: :berserk: :berserk: :berserk: :berserk:
dedmin
Postby Didier Bur » Tue Mar 09, 2010 9:12 pm
One more gem ! :fecstatic:
@TIG: Here's the french lingvo file
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Postby solo » Tue Mar 09, 2010 9:25 pm
looks awesome!!!
I loaded the whole bundle but got this error on start:
Code: Select all
No such file to load -- deBabelizer.rbError Loading File
Where would I find this monster?
User avatar
Global Moderator
Postby pilou » Tue Mar 09, 2010 9:55 pm
Another great variation! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby Didier Bur » Tue Mar 09, 2010 10:07 pm
Hi Solo,
the debabelizer is in the Zip.
Just in case, here it is (put it in Plugins folder)
Didier Bur
User avatar
Didier Bur
Postby Rich O Brien » Tue Mar 09, 2010 10:14 pm
Tremendous scripting and very welcome addition to 'must have' toolset :thumb:
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby solo » Tue Mar 09, 2010 10:25 pm
Thanks TIG that solved that, now playtime!!
User avatar
Global Moderator
Postby pilou » Tue Mar 09, 2010 10:26 pm
You make a plug by a day! :o
That is a good average :D ;)
PS An automatic order Selection curves will be fine for exemple in case of use plug like Grow by TIG? ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Tue Mar 09, 2010 11:26 pm
Pilou you are cruel ;)
There's the 3rd update of the day here viewtopic.php?p=231137#p231137 - new FR lingvo by Didier... :enlight:
User avatar
Global Moderator
Postby jason_maranto » Wed Mar 10, 2010 12:54 am
Thank-you so much TIG for the cool new tool and the pictures to go along with it.
Best,
Jason.
User avatar
jason_maranto
Postby teuf » Wed Mar 10, 2010 7:52 am
Wow !!
Really a good plug. Relevant to do 3D.
Thanx thanx thanx :berserk:
User avatar
teuf
Postby rv1974 » Wed Mar 10, 2010 9:48 am
Super! Thank you TIG so much!
Though it skips segments in the very first try.
rv1974
Postby TIG » Wed Mar 10, 2010 10:00 am
rv1974 wrote:Super! Thank you TIG so much!
Without the skp to try I'm unsure what's up...
Are the curves continuous - it would help it they had the same number of segments [although that IS meant to be coped with].
Can you post [or PM me] a skp displaying this glitch ?
User avatar
Global Moderator
Postby notareal » Wed Mar 10, 2010 10:06 am
:sketchstatic: Nice work. Thanks!
notareal
Thea Render Support
Thea Render Support
Postby erikB » Wed Mar 10, 2010 10:24 am
Yet another, but very helpfull, extension of the (extrude) set.
Thanks very much TIG :thumb:
erikB
User avatar
erikB
Postby rv1974 » Wed Mar 10, 2010 10:48 am
rv1974
Postby TIG » Wed Mar 10, 2010 11:13 am
I've tested your skp and I agree that the tool has a glitch - for some reason it's missing out a part of the mesh in the latter/earlier stages - the two versions I first illustrate below are by picking the curves in their reverse order - different bits get missed out...
The original has curves with varying edge counts...
In the 'copy' I edited the curves so each has 12 edges [or 24 for the S one] - to make them readily sub-dividable - now it works fine - so it must be a bug in the re-division of the edges to try and get them to match each other - also used in EEbyRails incidentally
I'll debug and get back to you...
In the meanwhile please use curves with more closely related edge counts - they will work... any number SHOULD work...
:roll:
User avatar
Global Moderator
Postby TIG » Wed Mar 10, 2010 11:23 am
I see that the problem is that the 6-segment zigzag is being divided into pieces of four to match the 24-segment S-curve BUT at one point it's becoming 1 piece short [3] and at another one too many [5] so that the 'apportionment' of the edges goes wrong and it fails - so at least I have the effect... but now to find the cause :roll:
User avatar
Global Moderator
Postby mitcorb » Wed Mar 10, 2010 12:35 pm
And what logically follows in the ExtrudeTools collection?
It was inevitable. Thank you, TIG
User avatar
mitcorb
Top SketchUcator
Postby mitcorb » Wed Mar 10, 2010 1:21 pm
TIG:
What would it take to make the resultant mesh into a Bezier mesh? Or am I talking about another tool?
In other words after generating the mesh, you could modify it by Bezier control points that would allow you to pull and stretch the mesh like a rubber sheet, and even unfold some unwanted contortions.
User avatar
mitcorb
Top SketchUcator
Postby TIG » Wed Mar 10, 2010 1:23 pm
Thomthom is working on a Vertex-Editor. which I think would become the basis of this editing tool ?
User avatar
Global Moderator
Postby Panga » Wed Mar 10, 2010 1:31 pm
Thanks a lot TIG for this one !!
Panga
Premium Member
Premium Member
Postby TIG » Wed Mar 10, 2010 1:50 pm
There's an update of EEbyLoft - see the notes here: viewtopic.php?p=231016#p231016
Get the tool in the zipped set from here viewtopic.php?p=217663#p217663
User avatar
Global Moderator
Postby EarthMover » Wed Mar 10, 2010 3:45 pm
UNREAL!!!!!! You are the man TIG!!!! :thumb: :thumb: :sketchstatic:
I'm starting really wish you would take these algorithms and write a new plugin to handle making terrains similar to "From Contours" but without the rats nest of a mesh the native tool creates. Your meshes are so smooth. Google needs you on staff immediately with a nice fat salary so you can code to your hearts content!
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby chrisjk » Wed Mar 10, 2010 5:15 pm
I don't know if this is another Mac peculiarity but I get very strange results. From three circles (two copies plus an original), when I would expect a cylinder to result, I get this:-
I attach the skp file just in case there is something weird lurking in it.
chrisjk
Premium Member
Premium Member
Postby dedmin » Wed Mar 10, 2010 5:20 pm
:o :o :?:
Erased the copies and made the new ones
dedmin
Postby MALAISE » Wed Mar 10, 2010 5:22 pm
TIG's plugin's , what else ???? :D
MALAISE
User avatar
MALAISE
Postby TIG » Wed Mar 10, 2010 5:28 pm
User avatar
Global Moderator
Postby chrisjk » Wed Mar 10, 2010 5:37 pm
Fantastic! TIG, thank you very much indeed for these great plugins.
chrisjk
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: ani2647834, Google Bot, medeek, NH_119 and 13 guests
Visit our sponsors:
