The "Duh!" thread (aka the Doh! thread)
Triangulate a simple rectangle surface with the Sand box?
Just draw a diagonal first!
Then apply the Sand box "Add détails"
A cool one!
The Duhduh of the day! Never used!
Thx Jeff -
Thing was, the people who I looked up to as pro's...
Are the ones that had the most "duh!"s
That's because only those who thinkhave genuine doh moments...
OK, I'll share a duh moment.
THE COMPONENT DIALOG BOX IS JUST A MINI 3-D WAREHOUSE WINDOW!
I found out by trying to search for a component and ended up with the same search results as the first page in the 3-D warehouse.WARNING, THE FOLLOWING DUH MOMENT IS PROVEN TO DECREASE PRODUCTION BY 1000%!
OK, first I found one of the antics figures off the warehouse (not through the component dialog window). Now all antic models have a link to the same youtube video, so I clicked on it and next thing you know I have youtube fully working inside sketchup! I got nothing done that day...
Just learned the physical size of the SU window matters when trying to print to scale.
No matter what I did I could not get my unscaled print on a single page, even though it would have easily fit on a single page. After making the SU window narrower than the height, SketchUp decided it would fit a a single sheet after all.
Found that out the hard way, 100 prints to just get close...
@ecuadorian said:
I changed the thread title in order to collect more "Duh!" moments here.
A couple of minutes ago, I just realized that the "Move" tool has a rotate function incorporated when you select a component. Just hover your mouse over any of the six faces of the bounding box and you'll see four red crosses. Select any of them to rotate your component around its center.
Another "Duh!" moment brought to you by a SketchUp newbie. I guess it's time to read the 887-page long manual from start to end.
Keep in mind the [move] tool rotate is a bit different from the [rotate] tool.
With move/rotate the 4 selection grab points (red +) are inset at mid point of the sides of the bounding box, BUT the actual axis of rotation is only perpendicular to the centroid of the bounding box selection face, regardless of the objects actual shape and mass center. The [move] tool can ONLY rotate groups and components, no other objects.
The rotate tools selection point is anywhere on any selected object(s) (anywhere in the drawing) and the rotation axis is perpendicular to the face at the selection point. If you need to rotate the object on an axis not perpendicular to the selection face, you need to place the protractor on a parallel face then [shift] move and then [click] the protractor to the selection point and complete the rotation. Otherwise you will need a temporary face to force the axis alignment for the rotate. The temp face need not be on any actual face of the object, but as a safeguard, group it first to avoid merging. To aid in placing the protractor center correctly, place a guide line in the desired axis of rotation, passing through the temp face. Place the protractor center on the intersection of the guide line through the temp face and complete the rotation.
My Spacebar doesn't deselect - disappointed.
You right : I was no precise!
That deselect "tools" !Deselect selected is of course clicked an empty space
[ctrl]T deselects all. Sometimes you cannot see empty space to click on.
That was my "Duh" moment after more than a year of using SU and frustration with deselections from inside my models.
Another "Duh" was using the [extrude] tool to quickly "select" (highlight actually) faces to reverse or delete. Just hover the tool over the face (NO clicking) and using shortcut keys "D" = delete, "R" = reverse face to either delete them or reverse them. Very fast that way for multiple faces. Gaieus gave me that one. There are other tools and functions you can use as well.
@paulside said:
Come on, Own up, how many of us have tried to orbit a jpg !
i try to orbit everything on my computer after a long SU session.. web pages etc...
it's like jumping on a trampoline for a while.. once you get back on solid ground, it takes a few minutes to readjust..
Like the famous Indian explorer, Binder Dundat, I have a 2D graphics app for GIF animation creation. [Orbit] does not work in that. Pity......
@gaieus said:
@thomthom said:
Ever tried to undo a wrong stroke with the pen..?Or with a girlfriend?
English teacher remarks to young Johnny that his spelling and punctuation has improved considerably.
Johnny say "I had too. My older sister caught a major screaming session with Mom & Dad when she missed a period." -
My Duh! of today...
I just noticed you can use 'paste in place' for moving ungrouped geometry inside an already grouped geometry. It helps a lot when you are outlining something in a blueprint and then paste in place in a group, like a plane's wing for intersection.
ultimatez
This and the Offset tool keep their last measures even you use some other tools between them!
So the "Double Click" is some efficient! -
This and the Offset tool keep their last measures even you use some other tools between them! So the "Double Click" is some efficient!
Please clarify for the snail within. Double click to edit group/component with the preset distances?
Several tools remember the last used value [during that session] - Offset and PushPull are the main ones.
Make an Offset on a Face - enter 100.
Later Choose the Offset Tool again and double-click on a Face - it will Offset 100...
Do a PushPull on a Face - enter 10.
Later Choose the PushPull Ttool again and double-click on a Face - it will PushPull 10...Type in new values if you desire...
SUp tries to be helpful in your working methods...
OK, thanks. I am not used to the command first -> selection second mode, which I should practice.
Might it be nice if the VCB window showed the remembered value at first when the command is picked?
Thx I can't say better or I c'ant better say!
I would guess that most people when using the pushpull tool would select the push pull tool first, and then hover over the desired face to push pull it. Offset I often go either way. I generally use it without selecting anything first, unless I specfically need to make a selection. Move tool I find I make my selection forst almost always. Same thing with the scale tool. Just do whichever is faster for you.
