[Plugin] Color by Z (Updated August 27th, 2009)
Erro ao carregar o arquivo clf_color_by_z.rb
No such file to load -- progressbar.rb -
No such file to load -- progressbar.rbDownload progressbar.rb free from SMustard...
doesn't work for me.
Error: #<ArgumentError: comparison of Float with nil failed> (eval):44:in `>' (eval):44:in `update'
You need to have progressbar from http://www.smustard.com installed also. Go install the plugin and then see if the plugin works after that,
PS - thanks for posting the error!
I have it...
sorry for uncompleted quoting, this is right error:Error: #<ArgumentError: comparison of Float with nil failed> (eval):44:in `>' (eval):44:in `update' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb:140:in `colorbyz' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb:138:in `each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb:138:in `colorbyz' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb:174 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_color_by_z.rb:174:in `call'
and sorry for my poor enghish
Try removing component spray from you plugins, then try my script. See if that is the problem.
yeeeeeeeeeeeees!
but... if you know that... can you solve it? component spray is very usefull for me...by the way... yours is a good script!
yeeeeeeeeeeeees!
Update to the latest version of Component Spray. The old Component Spray caused problems.
works fine now...EDIT!!!
sorry, doesn't work!
I remove old component spray tool and forgot to put new!
now I try with new compo-spray.rb but error is still there -
That is the second error report in the last 2 days that component spray is not fixed. But it was fixed a while ago, so I'm not sure what happened. Maybe Didier updated it and re-broke it?
hello Chris,
My first post on this great site, and many thanks for this very useful script!
Another great implementation would be to give as well possibility to have a [highlight=#ffffbf:11vlkwjz]gradient of transparency[/highlight:11vlkwjz] (I am thinking now of cloud generation....)
