by TIG » Sun Jan 31, 2010 4:59 pm
Here's v1.9 viewtopic.php?p=218691#p218691It now traps for 'No Geometry' inside the Group...
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2013
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by driven » Sun Jan 31, 2010 5:28 pm
NO Zapping with 1.9... is it possible for the health check to report 'NO geometry to Check because the selection contains sub-groups'?
I'll try some other breakers I've been working on...
cheers john
driven
- Top SketchUcator
- Name: John
- Operating system: Mac
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Intermediate
by driven » Sun Jan 31, 2010 5:48 pm
TIG, I've got a couple of test on the go, I'll report on them when they're cooked.
some additional ?'s
which should be faster for manifold, simply continuing after fail or a manual repair than re-test continue
would it be possible to choose bothquad's and tri's as two separate groups, if you have two different post destinations for the object?
or would EraseCoplanar on a copy of a Tri'd group give identical mesh results?
driven
- Top SketchUcator
- Name: John
- License type: Pro
by TIG » Sun Jan 31, 2010 6:52 pm
driven wrote:TIG, I've got a couple of test on the go, I'll report on them when they're cooked. some additional ?'s which should be faster for manifold, simply continuing after fail or a manual repair than re-test continue would it be possible to choose bothquad's and tri's as two separate groups, if you have two different post destinations for the object? or would EraseCoplanar on a copy of a Tri'd group give identical mesh results?
Manual fix versus Auto-fix depends on what needs fixing - making it right in the first place is the best bet  If you choose NOT to triangulate but then want a triangulated version then copy it and simply select all faces and run my [+tt's] tool triangulate_faces and you'll have the same result - uses the same code...
- Global Moderator
- Name: TIG
- License type: Pro
by driven » Sun Jan 31, 2010 7:12 pm
TIG- found the problem with the Bool'd group s -BT can create a group inside a group when bool-ing more than two groups, which I should have spotted in Outliner. When manifold highlighted RED and said 'NO' I simply exploded the extra group and answered my earlier ?, it was much faster on the bool'd group and I assume would be the similar on a manually repaired group. Note for users: The manual option also gives more control over the mesh shape at the torus/box intersection. Basically TIG you've done a fantastic job on this, thank you I'm convinced you, Chuck, and I won't be the only end-user's for this, it has soo many uses. for now I'll keep putting up images that help or hinder, and get back to some bent text testing.... do you think it's ready for a wider audience yet, I'm planing on trying to do a tutorial when your happy? aa-success_1.jpg aaa_success on bool'd GROUP.jpg ADD: it's what I thought re: tri/quads, just thought I'd ask
driven
- Top SketchUcator
- Name: John
- License type: Pro
by driven » Sun Jan 31, 2010 7:21 pm
driven
- Top SketchUcator
- Name: John
- License type: Pro
by TIG » Mon Feb 01, 2010 7:37 pm
Here's v2.0 viewtopic.php?p=218691#p218691Glitch in health-check if very small edges in faces fixed...
- Global Moderator
- Name: TIG
- License type: Pro
by thomthom » Tue Feb 02, 2010 12:23 pm
v2 ? is this a major or minor update?
- Global Moderator
- Name: Thomas Thomassen
- License type: Pro
by TIG » Tue Feb 02, 2010 12:25 pm
thomthom wrote:v2 ? is this a major or minor update?
The tweaks were relatively minor - BUT as I am unlikely to make many more changes in the short-term I thought I'd mark it with '2.0'...
- Global Moderator
- Name: TIG
- License type: Pro
by Pilou » Tue Feb 09, 2010 9:16 am
I have missed this new true gem!
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free/Make
- SketchUp use: hobby
by Pilou » Tue Feb 09, 2010 11:40 am
When I use Manifold I obtain that ok But When I kill or move the group red repair I have the original copy with killed internal faces Yes ok  , but always segments on the faces! Does it normal? A simple box with 6 faces must be result ? No clean selection? bug.png
Pilou
- Top SketchUcator
by TIG » Tue Feb 09, 2010 1:03 pm
Pilou wrote:When I use Manifold I obtain that ok But When I kill or move the group red repair I have the original copy with killed internal faces Yes ok  , but always segments on the faces! Does it normal? A simple box with 6 faces must be result ? No clean selection? bug.png
This is correct. The internal faces are removed by any edges they has forming part of the external envelope are kept. If you want rid of then use one of the tools that removes coplanar edges... It could seek to remove coplanar edges too ?
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Tue Feb 09, 2010 1:25 pm
Here's v2.1 viewtopic.php?p=218691#p218691It now has the option to remove coplanar edges before triangulation, this will minimize the number of faces -useful if for example internal faces have been removed and their old edges are not needed to keep the external 'manifold' skin intact...
- Global Moderator
- Name: TIG
- License type: Pro
by Pilou » Tue Feb 09, 2010 1:39 pm
Cool now we have possibility or not to "clean" the model in the same time
Pilou
- Top SketchUcator
by Pilou » Wed Feb 10, 2010 2:35 am
2 volumes copy move for each selected (2 volumes) Intersect Selected Group for each "group" apply Manifold with same answers : Yes for the first question (of course) and No for the others questions Curious result is not the same! Is that normal? test.png
Pilou
- Top SketchUcator
by driven » Wed Feb 10, 2010 3:51 am
@Pilou, tested your .skp on mac and got two different results? first time I opened SU from your download file, 2nd time I opened it from inside SU, but that was the only thing I changed, something odd?? double check manifold.jpeg
driven
- Top SketchUcator
- Name: John
- License type: Pro
by TIG » Wed Feb 10, 2010 11:26 am
Manifold has to start somewhere in its checking - the first entity it encounters might not always be the same so you get differing results if there's a big mess... Manifold was written to do specific job - check that a group is 'manifold' and if not try to fix it - it is so that when you export your model - e.g. to 3D-printer software - it will work. As it says at the start 'give us break' and try and at least offer it a set of geometry you hope might be manifold - it is NOT a boolean tool to merge volumes - it tries to decide which is the face to keep but sometimes removing or healing something changes the form - hence the colored 'report' group. Before using 'manifold' try manually to get rid of at least a few known internal faces etc [x-ray mode + hide is good for this] - then the processing is quicker and more consistent...
- Global Moderator
- Name: TIG
- License type: Pro
by Pilou » Wed Feb 10, 2010 3:55 pm
I well understand  The only curious thing is that it not the same result for 2 similar groups inspected
Pilou
- Top SketchUcator
by TIG » Mon Feb 22, 2010 11:34 am
Here's v2.2 - updated FR lingvo file [thanks to Didier Bur] and glitches with Tooltips and other strings deBabelizing now sorted... viewtopic.php?p=218691#p218691
- Global Moderator
- Name: TIG
- License type: Pro
by pdwyer » Sun Dec 12, 2010 11:54 am
Does/should this work with SU 8?
I'm not seeing any colours or new models created, even with the downloaded example but the example skp file is v7.
I suspect v8 needs a plugin like this too. If there is some other way to find doubles/duplicates/manifolds etc I'd love to know
Cheers
pdwyer
by TIG » Sun Dec 12, 2010 2:01 pm
pdwyer wrote:Does/should this work with SU 8?
Cheers
In v8 there are 'manifold' functions built in...
- Global Moderator
- Name: TIG
- License type: Pro
by pdwyer » Sun Dec 12, 2010 3:25 pm
Really? What are they called?
pdwyer
by Jim » Sun Dec 12, 2010 3:36 pm
Solid Tools. The Entity Info window will indicate "Solid Group" when a Group is manifold.
And here's a great plugin for trouble-shooting non-manifold Groups that should be: Solid Inspector by thomthom
Jim
- Global Moderator
- Name: Jim
- SketchUp version: 8
- License type: Pro
- SketchUp use: other
by Gaieus » Sun Dec 12, 2010 3:36 pm
The new solid tools. Outer shell (available in the free version, too), should do (more or less) what manifold plugin would (unless I am completely mistaken as I have never used this plugin yet)
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by pdwyer » Sun Dec 12, 2010 4:27 pm
Cheers! I found a tool called solid Inspector which shows some red and orange lines. I'm not 100% sure what the problem is in some cases (although in others it's obvious). I'll see if I can track down where to ask about those tools  Thanks again
pdwyer
by thomthom » Sun Dec 12, 2010 5:27 pm
pdwyer wrote:Cheers! I found a tool called solid Inspector which shows some red and orange lines. I'm not 100% sure what the problem is in some cases (although in others it's obvious). I'll see if I can track down where to ask about those tools  Thanks again
You can ask about Solid Inspector here: viewtopic.php?f=323&t=30504&p=267832#p267832IT circles red/orange around edges where there is a hole, or the edge connect to internal faces. In a solid all edges should have two connected faces - if there are more or less it means it's not a solid. These are the areas which the inspector highlights. So check if the faces are connected to internal faces, or if it's a hole. Note that the whole could be very small and you'd have to zoom a lot to see it.
- Global Moderator
- License type: Pro
by Sellberg » Fri May 25, 2012 10:01 am
Hi!
Thanx for creating this awsome plugin! I have been working on converting 3D objects from some GIS application and it has been so difficult, until now, that is.
I just have one small and kind of silly question but please bear with me: After running Manifold a copy of the selected group is created. Wich one is the fixed one? Are both fixed? The way i interpret what happens right now is that the one created is just a "showcase" of what changes have been made and that it should be removed.
/ KJ
Sellberg
- Name: Karl-Johan Sellberg
by Rich O Brien » Fri May 25, 2012 10:23 am
It then processes the group, making a modified copy of it set off to one side. If it has errors then a nested group is overlaid that has these errors highlighted - red for removals, green for healing. This error-group has a 'text-handle' so you can easily select it to move it away or erase it later... There is a closing dialog which either tells there were no major errors [although it might have removed non-face/edge entities or oriented faces and done some triangulation] or it reports the number of errors. If X-ray mode is off it asks you if you want to change to X-ray Mode to look inside the group to see what has been affected. On Yes/No the tool closes, with the new 'manifold' group now selected. Otherwise OK to end, with the new 'manifold' group now selected.
Does this answer your query?
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
by Sellberg » Fri May 25, 2012 11:06 am
Thanx for the quick reply! Sadly the answer is no. This quoted text is the reason I wrote this post in the first place. And no: I am not trying to be a pain in the ass, I just don´t get it. "It then processes the group, making a modified copy of it set off to one side." This sentence kind of implies that the first "original" group has not been modified but that the generated one has. "This error-group has a 'text-handle' so you can easily select it to move it away or erase it later..." This implies both groups have changed, but in different ways. So I am thinking the logic could be that the program leaves the original group unchanged for comparison, as that seems to be a big deal further down the text, or that the original group is fixed along with the generated group but that the latter one is just a showcase. / KJ
Sellberg
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
- Robot
Return to Plugins
