SketchUcation Premium Membership
[plugin] Ruby Code Editor - UPDATED to v3.0 3/4/2013
Postby alexschreyer » Thu Feb 04, 2010 7:01 pm
Hi All,
EDIT (3/4/2013): This plugin has been updated to version 3.0. The plugin got a major update! Some of the new features are: better environment stability (editor, scrolling, results, etc.), code completion for SketchUp classes and methods and a variety of other minor updates.
This code editor plugin offers an easy-to-use and visually appealing way to create and modify Ruby scripts directly within SketchUp. These scripts can then be used to create geometry, add functionality or add data within the SketchUp 3D modeling environment. The SketchUp Ruby API provides an extensive set of functions to automatize SketchUp in many ways or create scripted, computational geometry.
I created this editor mainly for two reasons: One is that when I write code, I permanently need to look up documentation. To make this easier, I added a bunch of reference webpages to a browser in a tab. Also, a dropdown above the editor contains some common code snippets that can be inserted at the current cursor position. Version 3.0 also introduces a code-completion feature that you can invoke at any point by clicking CTRL-SHIFT. It contains SketchUp’s classes and methods.
The other reason I wrote this as a plugin that works right inside of SketchUp is that I wanted it to give easy access to the Ruby coding environment and behave a bit more like a real code editor. To accomplish this, I added a bit of jQuery magic to make it look good and have some additional features. I also added the excellent CodeMirror 3.1 syntax highlighting engine. This provides the editor with multi-language code highlighting, correct TAB control, bracket matching and many more features. Just load the plugin and give it a try to see for yourself!
The following video gives a brief overview of the current version:
www.youtube.com Video from : www.youtube.com
You can get this editor from my website (and see a changelog) at:
http://www.alexschreyer.net/projects/sketchup-ruby-code-editor/
For more on what you can do with it, check out my book "Architectural Design with SketchUp" (especially chapter 6):
http://sketchupfordesign.com/
Cheers,
Alex
Author of "Architectural Design with SketchUp":
User avatar
alexschreyer
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: education
Level of SketchUp: Advanced
Re: [plugin] Ruby Code Editor as an extended WebConsole
Postby remus » Thu Feb 04, 2010 7:28 pm
:shock: thank you! this is awesome!
remus
Postby thomthom » Thu Feb 04, 2010 7:40 pm
Looking very nice.
got a couple of questions though:
The Ruby Console reports no error - but does output the puts statements.
User avatar
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Postby Chris Fullmer » Thu Feb 04, 2010 8:00 pm
Ooh I'm excited to test this out. i'm a huge believer in Jim's web console. The thought of anything to improve it make me giddy.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby alexschreyer » Thu Feb 04, 2010 8:13 pm
@thomthom: The bottom of the page disappears when the window width gets so small that the file name breaks into the next row. I wanted to keep the layout fluid so that elements adjust on resize, but maybe I can find a better way to arrange the page more reliably.
Not sure why there is no output. I didn't touch Jim's code that deals with capturing the Ruby response - does this also happen with the original Web Console?
Cheers, Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Postby Jim » Thu Feb 04, 2010 8:44 pm
A most excellent update Alex!
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
Postby Chris Fullmer » Thu Feb 04, 2010 9:01 pm
As far as the bottom output goes, I see it behaving exactly as Jim's does. What ever the script returns is output below. All puts statements get output in the Ruby Console.
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Fri Feb 05, 2010 1:55 am
So one thought, if its possible to clean this up I don't know - but the ruby console errors that get output are trying to display a lot of html markup now. A simple spelling error in model.selection returned this:
Code: Select all
model = Sketchup.active_model
<br/>ent = model.active_entities
<br/>sel = modqerel.selection
<br/>
<br/>dist = 100
<br/>
<br/>sel.to_a.each do |e|
<br/>  if e.is_a? Sketchup::Face
<br/>    e.pushpull dist
<br/>  end
<br/>
<br/>
<br/>end
"(eval):3:in&nbsp;&lsquo;initialize&rsquo;:&nbsp;undefined&nbsp;local&nbsp;variable&nbsp;or&nbsp;method&nbsp;&lsquo;modqerel&rsquo;&nbsp;for&nbsp;#&lt;RubyEditor:0x9912568>"
I added an image since I think it shows the error more clearly than the code block above.
I have no clue how that would be fixed.
Also, I am a little torn on the undo button. You set it so that it automatically wraps everything into a single undo command, which is nice so that a single press of "undo" will undo everything that was done in the script. But at the same time, I kind of don't like that because I'm worried I might forget to to write in my own start and commit operation methods. Don't know if that makes sense? I also don't know if I really would want it back how it was. Maybe this is a better workflow that I just need to adapt to.
Still though, I am liking it a lot!
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
Why can't we coordinate effort
Postby chrisglasier » Fri Feb 05, 2010 2:53 am
I know it is common for researchers to do their own thing but surely in this technically connected world we few should work together for the benefit of others.
A link and a pic ...
For my part I would like to incorporate these things into one interface.
Whatthink?
User avatar
chrisglasier
SketchUp version: 8
License type: Free/Make
SketchUp use: other
Postby alexschreyer » Fri Feb 05, 2010 4:49 am
Thanks for the feedback, everybody! Keep it coming...
@Chris Fullmer: Looking at the result capture code, it appears to convert characters such as the newline into HTML characters before sending it to the dialog. I tried to find a way around this - to no avail. Sending a newline \n to the execute_script doesn't work for me. Apparently that's why Jim put these conversions in there. I'll try later if there is an easier way to "encode" these before sending and "decode" them in Javascript in the dialog.
@chrisglasier: I remember your nameset approach from earlier. It can very well work with my editor. At some point, it would be great to have a code completion available, which could be your method. I am thinking of the user placing the caret, then clicking a key combination and then having a window pop up (like yours), where the method can be selected. How is your window implemented? I can easily incorporate something that resides in a DIV with Javascript.
Cheers,
Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Re: [plugin] WebConsoleEX - Themed Controls
Postby Dan Rathbun » Fri Feb 05, 2010 12:39 pm
alexschreyer wrote:I have also not tested this on a mac.
For the PC, put the following META tag in the HEAD section, so the browser displays Themed Controls instead of those old ugly plain Win 3.x style controls (ie buttons, scrollbars, etc.)
The Mac (Safari) should just ignore the tag.
HTML
Code: Select all
   <!-- Use MS Common Controls ver 6+ if available -->
   <!--  (also known as XP style themed controls.)  -->
   <META HTTP-EQUIV="MSThemeCompatible" CONTENT="Yes">
_
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Re: [plugin] WebConsoleEX - filename location
Postby Dan Rathbun » Fri Feb 05, 2010 12:43 pm
alexschreyer wrote:@thomthom: The bottom of the page disappears when the window width gets so small that the file name breaks into the next row. I wanted to keep the layout fluid so that elements adjust on resize, but maybe I can find a better way to arrange the page more reliably.
I'd like to see the rb filename on the line below the toolbar (as a step towards future tabbed multi-snippet interface where the filename would be on the tabs anyway.)
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Re: [plugin] WebConsoleEX - puts output
Postby Dan Rathbun » Fri Feb 05, 2010 12:57 pm
ThomThom wrote:(No output?) The Ruby Console reports no error - but does output the puts statements.
alexschreyer wrote:@thomthom: Not sure why there is no output. I didn't touch Jim's code that deals with capturing the Ruby response - does this also happen with the original Web Console?
Yes it happens with the original WebConsole.
(1) Keep in mind that the output pane in the WebConsole (currently) displays the result of the eval method, NOT the output stream of STDERR and/or STDOUT as the SUConsole does. (This is why for multiple statements you see only the result from the LAST statement.)
(2) The puts method returns nil so you won't see anything if Jim's code stripped textstring "nil" out.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Re: [plugin] WebConsoleEX - result capture code
Postby Dan Rathbun » Fri Feb 05, 2010 2:53 pm
alexschreyer wrote:@Chris Fullmer: Looking at the result capture code, it appears to convert characters such as the newline into HTML characters before sending it to the dialog. I tried to find a way around this - to no avail. Sending a newline \n to the execute_script doesn't work for me. Apparently that's why Jim put these conversions in there. I'll try later if there is an easier way to "encode" these before sending and "decode" them in Javascript in the dialog.
Yes the HTML conversion may be necessary for the WebDialog side but not for the STDOUT.
Alex YOU caused the HTML tags to also go to STDOUT by inserting the line "p r" AFTER the conversion gsub! statements. IF "p r" is needed, move it up before the conversion statements.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Re: [plugin] WebConsoleEX - nil evaluation
Postby Dan Rathbun » Fri Feb 05, 2010 3:07 pm
Dan Rathbun wrote:(2) The puts method returns nil so you won't see anything if Jim's code stripped textstring "nil" out.
OK if a var evaluates to nil, and then you convert it to a String with .to_s, the result is an empty length String.
So line 73 needs a nil test, thus:
r!=nil ? r=r.to_s : r='nil'
(Don't just have "r" as the boolean expression, because false values would get set to 'nil' instead of 'false'.)
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby alexschreyer » Fri Feb 05, 2010 4:26 pm
Thanks, Dan, for going through this so thoroughly. Everyone, please feel free to suggest code improvements. I would like to make this as useful as possible. Of course, I'll mention every help on the "About" tab.
@Dan: I'll incorporate your revisions into the output code. That is really the part here that I had looked at the least.
I like the idea of having tabbed multiple files. With the current tab support that should be relatively easy to implement.
And thanks for the hint on the Windows UI look for IE. I didn't even know about the tag.
Cheers,
Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Re: [plugin] WebConsoleEX - abort operation
Postby Dan Rathbun » Fri Feb 05, 2010 6:16 pm
I think I see another problem. If an error occurs don't you need to abort the operation instead of committing it?
Try something like this:
Code: Select all
  add_action_callback("exec") do |webconsole_dialog, p|
    v = webconsole_dialog.get_element_value('console').strip
    # puts v    # what's this for -- testing ??
    r = nil
    begin
      Sketchup.active_model.start_operation "RubyEditor"
      begin # evaluation
        r = eval v
      rescue => e
        r = e
        raise # pass to outer rescue clause
      end # eval
    rescue
      Sketchup.active_model.abort_operation
    else # only do if NO errors
      Sketchup.active_model.commit_operation
    ensure # always do this
      r!=nil ? r = r.to_s : r='nil'
      p r
      r.gsub!(/ /, "&nbsp;")
      r.gsub!(/\n/, "<br>")
      r.gsub!(/'/, "&rsquo;")
      r.gsub!(/`/, "&lsquo;")
      r.gsub!(/</, "&lt;")
      webconsole_dialog.execute_script("document.getElementById('results').innerHTML='#{r}'")
  end # callback
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Re: [plugin] WebConsoleEX - default key
Postby Dan Rathbun » Fri Feb 05, 2010 6:30 pm
Alex.. you did not change the Name of the DefaultSettings Key ('WebCon'), so your plugin is overwriting the values for Jim's standard WebConsole in the registry.
There is always the possibilty that some people may still wish to use Jim's "plain Jane" version from time to time, even with yours installed.
You should setup a unique Keyname for your defaults.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby alexschreyer » Fri Feb 05, 2010 7:45 pm
I'll change the dialog name. Must have overlooked that one. I changed the class name.
In the meantime, I figured out how to get linebreaks from a file into a dialog.
Code: Select all
filename = UI.openpanel
f = File.new(filename,"r")
text = f.readlines.join.gsub!(/\n/, '<KghBr31sD>')
ndlg = UI::WebDialog.new("Ruby Web Console", true, "WebCon123", 600, 400, 100, 100, true)
ndlg.set_html ("<html><head></head><body><textarea style='width:100%;height:100%' name='mybox' id='mybox'></textarea></body></html>")
ndlg.show {
  ndlg.execute_script("var text = '#{text}';var asddsa = text.replace(/<KghBr31sD>/g,String.fromCharCode(13));document.getElementById('mybox').value = asddsa")
I think I saw the method (i.e. using a gibberish tag) discussed recently in the developers forum. I'll give that a try soon.
Cheers,
Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Postby chrisglasier » Sat Feb 06, 2010 2:41 am
alexschreyer wrote:
@chrisglasier: ... It can very well work with my editor.
It is not your editor it belongs to Jim; what you did, as I did, was to dress it up. But I don't want to focus on individual efforts but more on why the cognoscenti allow software companies to fob us off with metaphors for paperwork rather than providing digital machines.
Take for example your original cheat sheets and my/Jim's Sketchup API digital device which provided an opportunity to link up many other devices like the console. The style is not an issue and you are more adept at implementing the links than an amateur and reluctant coder like me; the code is freely available here.
I am very disappointed that you ignored this opportunity to exploit a way to link up data (that belongs to objects that have names) and digital devices (that can automate common tasks).
User avatar
chrisglasier
SketchUp version: 8
SketchUp use: other
Postby alexschreyer » Sat Feb 06, 2010 4:38 am
@chrisglasier: I see now where you are coming from. My idea with my revision of Jim's Web Console was to make it more functional and spruce up the visuals but keep it easy enough for the beginning coder. I'll look again at your approach with the namesets but it seemed to me at the time to complicate things. I guess I just don't fully understand it yet.
I am all for collaboration and combining efforts, though.
Cheers,
Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Re: buttons
Postby Dan Rathbun » Tue Feb 09, 2010 2:03 pm
Just a note on personal preference.
If you use the META tag I gave you previously, the buttons (New, Open, Save, Quit) take on the look of the nice XP style buttons (rounded corners & which hilite on hover, etc.) They look just as they do in native dialogs.
The jQuery buttons you have used take up more space (especilally height-wise) and have the look of the old MS Frontpage styling, which I have always hated.
I prefer the native XP look.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby alexschreyer » Tue Feb 09, 2010 3:34 pm
@Dan: You are right, going with the OS styling also makes sense to keep elements looking "native" on Win and Mac.
I wanted to go with the jQuery UI framework, though, so that a) the dialog looks exactly the same on Win and Mac and b) later I could offer different styling to users, so that they can pick their preference from a dropdown. The UI system has various nice templates:
http://jqueryui.com/themeroller/
One question: I have to save some preferences (like the UI selection) locally. Can I reliably use cookies or should I go with an ini file?
Cheers,
Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Feb 09, 2010 3:41 pm
Cookies can be purged by the user or utilities that clean the browser data. Safest is to store it separately.
User avatar
Global Moderator
License type: Pro
Re: WebConsole Preferences
Postby Dan Rathbun » Wed Feb 10, 2010 12:46 am
thomthom wrote:Cookies can be purged by the user or utilities that clean the browser data. Safest is to store it separately.
Agreed.
You can use Sketchup.write_default and Sketchup.read_default to save settings in the Registry (Win32) or plist files (Mac) but they have a few disadvantages.
Once you create a key, you cannot remove it, so they can become cluttered with old setting keys that are not used anymore.
And they can be only 1 level of heirarchy, even though the Windows Registry supports any numbers of levels. (It's a tree structered database.) Perhaps this is a limitation of the Mac plists and Google is enforcing it on both platforms for 'sameness'?
Also.. XP Home has a Registry limit size (I'm constantly on the edge of it and often get the Registry Limit reached Warnings. If I'd known about it I would have paid the extra and bought XP Pro.)
Anyhow.. an ini (or any settings file,) would give you complete freedom.
It doesn't need to be an ini format. It can be simply a ruby script that decalres a Settings Hash wrapped in your plugin namespace. Did you know that Module and Class definitions can be split up into multiple files? They can. The main file can be the functional part of the class definition, and the other can be just a Hash declaration inside the same class namespace, that gets loaded by the first (if it exists,) and gets RE-written by the first file, when changes to the settings are made.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby thomthom » Wed Feb 10, 2010 8:31 am
Dan Rathbun wrote:Also.. XP Home has a Registry limit size (I'm constantly on the edge of it and often get the Registry Limit reached Warnings. If I'd known about it I would have paid the extra and bought XP Pro.)
Never knew that.
...how much stuff you got installed? I've installed lots of random stuff on my old xp box through up the years - never had that warning.
User avatar
Global Moderator
License type: Pro
Re: Registry Limit
Postby Dan Rathbun » Wed Feb 10, 2010 11:41 pm
Never knew that.
TOO much stuff! OpenOffice Suite, AutoCAD, Epson Scanner Software, Windows SDK, MS VisualStudio (w/ VB, C#, C++, SQL Server), Debugging Tools for Windows, Windows Support Tools, PowerToys for Windows XP, MS HTML Help Workshop, PCB123, AdobeReader, Paint.NET, NotePad++, SciTE, FamilyOrigins (Genealogy dBase), Google Sketchup 7.x, Google Earth. ..etc...
(And at one time 2 full versions of MS Flight Simulator; which I uninstalled.)
I believe I didn't get the errors until after I installed AutoCAD. I can't find the exact error message at a MS search, but did find an article dated 2007 that says the RSL (Registry Size Limit) "no longer applies" to Windows XP or Windows Server 2003. But I know I have got the error popup after that.
@Alex: Thinking more about this. You don't need need to worry at all regarding this issue. The RSL applies only (if it even does anymore,) to the System Hive of the Registry. Sketchup settings are saved in the User Hive, which does not have (or never had) any size limit.
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby Dan Rathbun » Wed Feb 10, 2010 11:50 pm
Dan Rathbun wrote:Anyhow.. an ini (or any settings file,) would give you complete freedom.
It doesn't need to be an ini format. It can be simply a ruby script that decalres a Settings Hash wrapped in your plugin namespace. ... that gets loaded by the first (if it exists,) and gets RE-written by the first file, when changes to the settings are made.
If Js is more comfy for you, the same technique can be used but in Js. A ruby method can write out a Js script that is a JS object holding settings, or an Array of settings, or global varibales, whatever.
The file just gets loaded with the webpage.. no complex parsing required.
If the user makes settings changes.. you send them to a ruby callback that overwrites the settings .js file.
Also if you wish to change CSS dynamically you'll need to assign ID attributes to the stylesheets (whether inline or loaded via LINK tag.)
User avatar
Dan Rathbun
Top SketchUcator
License type: Pro
Postby alexschreyer » Thu Feb 11, 2010 5:26 am
Thanks for the recommendations, guys. I actually went with the easiest version (cookies) for now since I was able to implement this without hassle. I'll look at file storage later.
Didn't know that the registry could actually become too large. I never ran into this problem. And I have several Autodesk products installed (those are huuuge - though mostly by filesize! When will ADSK finally cut down on bloating their own software).
Cheers,
Alex
User avatar
alexschreyer
SketchUp version: 8
License type: Pro
Postby driven » Sat Feb 13, 2010 9:16 pm
a possibly naive question from one your target end users,
I'm teaching myself ruby on a mac
I have a very Ruby for SU text book that is in PDF format on my hard-drive, I want to access it through the reference menu on your console, (which does throw up some code errors, but still mostly works)
Is it possible, or could I put it on my website and read it from there (less preferable as the books not published yet)?
driven
Top SketchUcator
Operating system: Mac
License type: Pro
SketchUp use: engineering and mechanical design
by Ad Machine » 5 minutes ago
Artisan Organic Toolset - a set of powerful organic modeling tools.
Premium Members get 20% discount!
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: Jacobs00001, vantin and 9 guests
