[Plugin] Select Outer Edges v1.0
Postby Chris Fullmer » Tue Jun 30, 2009 7:50 pm
This is pretty simple, from a request from John Clements here:
viewtopic.php?f=180&t=20267&p=168997&sid=195d6184b32fa0a6257f3883cb07a9f6#p168940
Select a group of faces and edges and run this plugin. It will select only the outer edges (perimeter edges) and also edges that border an interior hole. It only selects edges that you have selected before running the script. So hidden edges will not get added to the outer edges selection if they are not selected. Use the triple click selection method to make sure that hiiden edges are selected correctly. Also, single lines are not added to the selection either. Here is a video that sort of shows all of that. I hope it makes sense, and is helpful. Video (no sound):
PS this is a script I probably wont be updating or adding to. Maybe it should just be included in Thom's selection toys (maybe it already is?). So if its in another, more major script out there, you might just be best using that one. And if someone points me to it, I'll probably just remove this script and point people to the better script.
User avatar
SketchUp Team
SketchUp Team
Re: [Plugin] Select Outer Edges v1.0
Postby boofredlay » Tue Jun 30, 2009 7:58 pm
I could have used this last weekend when I made this:
Thanks Chris, works great.
User avatar
boofredlay
Global Moderator
Postby Dave R » Tue Jun 30, 2009 8:44 pm
Thanks Chris.
Eric, you going to build that?
User avatar
Global Moderator
Postby boofredlay » Tue Jun 30, 2009 9:12 pm
I already did, in SU, for FF ;)
http://www.formfonts.com/viewModel.php? ... 3&config=1
Build it physically... nope.
User avatar
boofredlay
Global Moderator
Postby simdidengelecege » Mon Jan 04, 2010 12:11 am
Thank you very much for this plug-in...
It is so functional.
simdidengelecege
Postby urs0815 » Mon Jan 04, 2010 8:03 pm
Thank you Chris, this is a very useful plugin! :thumb:
urs0815
Postby Panga » Fri Jan 08, 2010 1:26 pm
Thanks a lot for this simple but very usefull script !! Good work.
Panga
Premium Member
Premium Member
Postby 3dbuilder » Fri Jan 29, 2010 5:34 pm
Hey Google:
Hire. Chris. Fullmer.
And if they don't hire you Chris, you should apply for a position with Bonzai 3D.
Thanks for all your plug-ins. Whenever I need to be productive and find basic functionality like this that isn't in Sketchup, I just Google "Chris Fullmer tool"
Thanks again.
:berserk: :ecstatic: :sketchstatic:
3dbuilder
Postby Chris Fullmer » Fri Jan 29, 2010 8:15 pm
3dbuilder wrote:Hey Google:
Sounds like a good plan to me since I just got furloughed today, from a job that already paid too liitle :)
Glad you like the script!
User avatar
SketchUp Team
SketchUp Team
Postby JClements » Sat Jan 30, 2010 2:26 am
Bummer, Chris.
Got a resume?
User avatar
JClements
Premium Member
Premium Member
Postby Bertier » Thu Oct 06, 2011 10:38 am
handy one !
Bertier
Postby openhatch » Thu May 24, 2012 9:29 pm
This just saved me a lot of trouble. :D Thanks!
openhatch
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], comon3go and 6 guests
Visit our sponsors:
