SketchUcation Premium Membership
[Plugin] Lines to tubes
Re: [Plugin] Lines to tubes
Postby gaucho » Tue Sep 02, 2008 5:35 pm
Didier Bur wrote:
would be possible to modify so we could extrude along square shapes as well?
Use a precision of 4 and you'll get square section prisms.(RTFM)
Simple anD easy.. MERCI!
"eat well, stay fit, die anyway..."
gaucho
Postby Juju » Tue Sep 02, 2008 7:01 pm
Marian wrote:i think there should also be an option to make not round tubes but square hexagonal triangular ones.
I think if you downloaded the plugin and checked the manual you'd see that it already does what you want.
Keeping things organised is not a sin. ;)
Juju
Postby Didier Bur » Tue Sep 02, 2008 9:48 pm
Read the doc and USE PRECISIOn :bounce: !!!
You beat me on this Juju !
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby CameronVan » Wed Sep 03, 2008 12:55 am
Boofredlay wrote:
Pilou wrote:for the problems, maybe you must disable the old "line2cyl.rb"? ;)
maybe...
I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up.
Thanks. :thumb:
Ahhh, great.
Thanks Pilou!
CameronVan
Postby Marian » Wed Sep 03, 2008 7:43 am
Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them? :P
User avatar
Marian
Postby Didier Bur » Wed Sep 03, 2008 7:55 am
Those who don't want to bother doc writers :lol:
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Postby lorca » Sat Sep 19, 2009 10:29 am
Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
lorca
Postby lexmonteiro » Mon Sep 21, 2009 2:45 pm
Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles?
lexmonteiro
Postby chango70 » Thu Nov 19, 2009 3:59 am
Doesn't show up for me. I don't have older version at all. Any ideas?
chango70
Postby xrok1 » Thu Nov 19, 2009 4:31 am
i just DLd and it showed up in tools menu.
thanks dedier! :D
xrok1
Postby chango70 » Thu Nov 19, 2009 5:17 am
Whats DLd?
chango70
Postby chango70 » Thu Nov 19, 2009 5:22 am
Its working now! WOOHOO! Great plugin!
chango70
Postby xrok1 » Thu Nov 19, 2009 5:37 am
chango70 wrote:Whats DLd?
downloaded :oops:
xrok1
Postby flipya » Mon Jan 25, 2010 9:53 pm
I love this plugin! It's so incredibly easy to use and all the options I need are included. A+ for ease of use!
Combined with the soapskin bubble plugin it's almost addictive :shock:
It does sometimes crash my sketchup. The progress percentage builds up, slows down, and eventually just stops. A second or third try (saving before starting) usually does the job though.
All in all, pretty much brilliant!
flipya
Postby majid » Thu Feb 18, 2010 9:04 am
first I must thank you for your handy tool Dider, and then I thought if you could combine this plugin with a geosphere creator + an option to have sphere in junction points, then we would have A LATTIC TOOL ,right in sketchup, that makes space frames easy.
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Level of SketchUp: Intermediate
Postby Pilou » Thu Feb 18, 2010 9:18 am
@majid
for some things you can use that ;)
A cool use of this "Multiple Face Offset" By Remus :fro:
If you don't use it in this case Windowizer(3 free or 4) By Rick Wilson @Smustard
don't make the "Frame Inset"! ;)
Windowizer is a crazzy plug : All types of piercing windows + multiple selections :shock:
Selection Only faces by Selection Toys by Thomthom :enlight:
Invert Selection by TIG :enlight:
For Crazzy Geodesic domes By TaffGoch @ 3Dwarehouse :shock:
His site :ugeek: Crazzy PDF collector! :fro:
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Thu Feb 18, 2010 11:12 am
My EEbyFace also does something similar but it allows you to define the extrusion's cross section by making a 'flat' face [it's Y green axis = extrusions initial Z blue axis] - the face can be any shape you like so you are no longer limited to circular tubes...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby harshal kshatriya » Sun Feb 21, 2010 10:08 am
wow its working man............
i love it
thanks a lot :thumb:
harshal kshatriya
SketchUp version: 7
License type: Pro
Postby cadmunkey » Mon Jul 05, 2010 4:32 pm
Just installed this plugin and its great for converting custom autocad hatches into solids. Thanks man!
cadmunkey
Postby Pilou » Mon Jul 05, 2010 4:35 pm
Didier Bur plug "Line to tubes" can make circles of 3 edges so a triangle, 4 edges so a square, etc...:enlight: ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby agamemnus » Sat Nov 20, 2010 8:36 pm
I tried this, but the tubes don't get "welded" / smoothed at edges:
http://img109.imageshack.us/i/tubes.png/
Is there a plugin that does this?
Edit: Ok, never mind.. I used BZ tools to convert my loop to a bezier curve (edit 2: polyline is better, actually, for this...), and then applied this plugin. It's all welded now! :)
agamemnus
Postby alvin_pox » Fri Oct 14, 2011 5:16 pm
Hi.
I've downloaded the .rb file in the plugin folder but when I restart sketchup, I keep getting a pop-up window with the following...
Error Loading File lines2tubes.rb
undefined local variable or method `book' for main:Object
This plugin would really help with my design project greatly, so I'm really hoping someone here could help me get it to work.
I'm using sketchup 8 on mac btw.
Thanks.
alvin_pox
Postby TIG » Fri Oct 14, 2011 10:46 pm
Sounds like the file is corrupted as there is no reference to 'book' in it. :?
Get the file again and put the .rb file into the Plugins folder, and retry.
Don't edit it with a word-processor or similar as this might corrupt it...
The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ? :?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby alvin_pox » Sat Oct 15, 2011 2:05 am
TIG wrote:Sounds like the file is corrupted as there is no reference to 'book' in it. :?
Have downloaded the file again and it works now!
I noticed that the file I had yesterday had a big red "Rb" on the file icon thumbnail, but it doesn't today after I redownloaded it.
I also tried other plugins yesterday and all seemed to get the same error message when loading and the big red Rb on their thumbnails, so it doesn't look like it was a single corrupted file. Weird.
But it's all sorted now. Thanks so much:p
alvin_pox
Postby majid » Sat Oct 15, 2011 5:06 am
Thank you Pilou
I was specting junction spheres. like this , 1 min try wings3d ( it is handy in some cases, while a different approach, and is easy enough for me that am not a 3dsmax fan)
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Pilou » Sat Oct 15, 2011 2:12 pm
And Wings3D can reload 3DS format from 3Dwharehouse or from SU ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby majid » Sat Oct 15, 2011 5:15 pm
yeap, it has wide range of import/export formats included. very handy,... sort of free subd/smooth ;)
User avatar
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby btxscg » Sat Oct 29, 2011 7:52 am
it's great :berserk:
btxscg
Postby irwanwr » Wed Nov 30, 2011 8:51 pm
i'd like to thank the author, Didier for this very useful plugin.
i used to utilise the push/pull tool before. with this plugin, i could just do it on the line frames and one or two more clicks.
thank you very much :thumb:
User avatar
irwanwr
SketchUp version: 8
License type: Free
SketchUp use: hobby
Level of SketchUp: Beginner
Postby Steuart » Sat Mar 03, 2012 1:17 pm
Hi Didier and all.
I have just installed the Lines2tubes plug in. Initially I tried to use it and it crashed (of course before I had saved anything - auto save does not seem to work unless you have done at least an initial save). Then each time I tried to re:launch SU it would instantly crash. I also tried TubeAlongPath and pretty much the same thing happens. In each case it was fine once I had remeoved the plug in. Anyone any ideas? I am using a Macbook pro, with 10.5 and SU 8. I would love to be able to use the program as it would save a huge amount of time.
Steuart
by Ad Machine » 5 minutes ago
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: adeleklein, alce2, bart82, dem, Harmpie, mp1963 and 17 guests
