[Plugin] UV Toolkit
Re: [Plugin] UV Toolkit (1.0.0) — 15 October 2009
Postby Pixero » Tue Dec 22, 2009 9:57 am
Ok, what would you suggest.
Center of face? Or a window where you can choose like in Profile Builder?
User avatar
Pixero
Postby thomthom » Tue Dec 22, 2009 10:04 am
That's the thing: what would you determine as centre of face for something like this? (or top,left,right,etc...)
User avatar
PluginStore Author
PluginStore Author
Postby Pixero » Tue Dec 22, 2009 10:17 am
Center of bounding box maybe?
User avatar
Pixero
Postby Gaieus » Tue Dec 22, 2009 11:05 am
What kind of a quad is that, Thom?
:shock:
User avatar
Postby thomthom » Tue Dec 22, 2009 12:06 pm
:D The exotic kind. ;)
My point was - that when you don't deal with regular quad-faces - it's much harder to predict desired result.
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Tue Dec 22, 2009 12:14 pm
thomthom wrote:That's the thing: what would you determine as centre of face for something like this? (or top,left,right,etc...)
There's a 'Center of Gravity' script somewhere - 'centroid.rb' - by TBD that adds a cpoint at the CoG of a face.
I can't find it so here it is again
centroid.rb
User avatar
Global Moderator
Postby Pixero » Tue Dec 22, 2009 12:15 pm
Would it be possible to have an option for it to automagicly recognise the lenght direction based on witch side is longest on a quad and rotate it to match that.
Like if I want to rotate some UVs on a branch to line up the texture with the trees branches length direction. Would be cool.
Am I making myself clear? :?
User avatar
Pixero
Postby thomthom » Tue Dec 22, 2009 12:17 pm
The thing is - would picking the "centre" (however it's defined) be any different, as just picking the first vertex I can get? At all seem rather arbitrary in terms of the result.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Tue Dec 22, 2009 12:18 pm
Pixero wrote:Would it be possible to have an option for it to automagicly recognise the lenght direction based on witch side is longest on a quad and rotate it to match that.
Are we talking about rotating on quads strictly? I was under the impression this would be a general purpose rotation.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Tue Dec 22, 2009 12:19 pm
Can you show a little screenshot of your starting point and your desired result?
User avatar
PluginStore Author
PluginStore Author
Postby Pixero » Tue Dec 22, 2009 12:20 pm
See image in my updated post above.
User avatar
Pixero
Postby thomthom » Tue Dec 22, 2009 12:21 pm
Pixero wrote:See image in my updated post above.
Can you show that with hidden geometry on so I can see the mesh?
User avatar
PluginStore Author
PluginStore Author
Postby Pixero » Tue Dec 22, 2009 1:10 pm
Here's another one with hard edges and lighter texture.
It would be useful for things like trees, railings, plumbing...
Here the texture is applied vertical but should of cause follow the direction of the branches.
User avatar
Pixero
Postby thomthom » Tue Dec 22, 2009 1:22 pm
The thing is, is's hard to determine the direction here. As far as I can see, there's no quad faces in that three, instead lots of triangles. The longest side of each triangle isn't necessarily the direction you want.
I now understand what you want. But ... it ain't easy. Trying to create predictability in organic shapes...
User avatar
PluginStore Author
PluginStore Author
Postby Pixero » Tue Dec 22, 2009 1:35 pm
To me it look like it's the direction of the second longest side in the triangles.
(Not the hypothenuse)
User avatar
Pixero
Postby thomthom » Tue Dec 22, 2009 1:39 pm
Pixero wrote:To me it look like it's the direction of the second longest side in the triangles.
If that is the rule throughout everything you use it one, then that could work.
But note, you would not get seamless texture between each triangle, in any case.
User avatar
PluginStore Author
PluginStore Author
Postby genma saotome » Thu Mar 18, 2010 8:36 pm
I know I'm coming in quite late on this thread but if I may comment anyway... just having some rather basic adjustments to the texture position on multiple selections would be a real time saver for me. There are many situations where I find I must first snap the red pin to a corner before I do a rotate and when I'm in that situation it almost always involves repeating the task. For example, take a model of a street intersection and the task at hand is to texture the gutter. The texture shows some moisture that should be closest to the curb. For every face, from the straight street thru all four curves of the intersection, each face in the gutter has to have the edge of the texture that's "moist" moved up against the curb. Same for the curb, the texture has to have the "moist" pixels down next to the gutter. That's a red-pin snap-to-corner for every face and a rotate for many.
So for me, doing a select some faces and do a snap-red-pin-to-lower left vertex, and a select some faces and do a rotate-texture-90d to would turn an ordeal into a 10 second event.
I find I often have the same sorts of problems texturing and set of radial oriented faces -- you need to get the red pin moved to a corner vertex before rotating to align the texture on the axis of the edges originating at the center point.
From such a basic beginning perhaps there might spring a more sophisticated tool but wanting the perfect shouldn't prevent the creation of the good-enough-for-now.
User avatar
genma saotome
Postby KXI System » Sun Mar 21, 2010 1:47 am
THOM YOU DID IT! :ecstatic: :ecstatic: :ecstatic: :ecstatic: :ecstatic:
You solved my problem!(for now)
Expect a crate full of "cookies*" by your door soon(if I could find a way, don't be disappointed though)
*Cookies can be substituted for beer, remember?
Getting the perfect sig is hard...
Google it!
KXI System
Postby bac9-flcl » Tue Aug 10, 2010 4:31 pm
Is it still in development? Those screenshots of Texture Along Path feature looked very promising.
And these poor things really need the help of updated UV plugin )
Anyway, thank you for awesome work, it's already the most advanced UV plugin I saw for SU )
User avatar
bac9-flcl
Postby thomthom » Tue Aug 10, 2010 4:46 pm
It is being developed yes. For the last six months I focused on Vertex Tools, but I am now back on my other projects. Can't give any estimate on when, but the new version should be of significant improvement.
User avatar
PluginStore Author
PluginStore Author
Postby bac9-flcl » Tue Aug 10, 2010 5:31 pm
thomthom wrote:It is being developed yes. For the last six months I focused on Vertex Tools, but I am now back on my other projects. Can't give any estimate on when, but the new version should be of significant improvement.
That's great to hear! :)
User avatar
bac9-flcl
Postby Gaieus » Wed Aug 11, 2010 12:51 pm
You know, Thom, that I am obsessed with this tool so do not get distracted with every silly component comparison plugin!
User avatar
Postby thomthom » Wed Aug 11, 2010 2:27 pm
I need to make my plugins TimeWare - as I really need more Time™. :shock:
UV Tools are high up on the list. Hope to get something to show soon. But it does compete with the component comparison plugin as I need that for my work.
I have so many plugin ideas - that I think I need to release them in stages. (I get all too easily carried away and start on big packages.) Focus on one feature, then release, then add the next and so on.
I should probably change my sig from "SketchUp Monkey" to "Plugin Monkey" :D oook!
User avatar
PluginStore Author
PluginStore Author
Postby coolcool » Thu Aug 19, 2010 3:45 am
Thank you
coolcool
Postby tfdesign » Thu Sep 23, 2010 9:54 am
Great work Thom! I just clocked this plug. Thx! :D
Tom
(who was actually christened "Thom" too- but that would get far too complicated here! :shock: :lol: )
You deserve some beer for this...
tfdesign
Top SketchUcator
Postby thomthom » Thu Sep 23, 2010 10:11 am
tfdesign wrote:You deserve some beer for this...
:berserk:
User avatar
PluginStore Author
PluginStore Author
Postby bentleykfrog » Sun Oct 31, 2010 3:51 pm
Finally wrapped my head around this plugin and its genius. Its saving me an amazing amount of time, thanks thomthom
bentleykfrog
Re: [Plugin] UV Toolkit (2.0.0) — 31 December 2010
Postby thomthom » Fri Dec 31, 2010 5:13 pm
New Version - 2.0.0
See first post!
viewtopic.php?f=323&t=18992#p155759
User avatar
PluginStore Author
PluginStore Author
Postby mitcorb » Fri Dec 31, 2010 5:24 pm
Hey, ThomThom:
Excellent video! Excellent Plugin! Excellent update!
User avatar
mitcorb
Top SketchUcator
Postby Gaieus » Fri Dec 31, 2010 6:18 pm
mitcorb wrote:Excellent video! Excellent Plugin! Excellent update!
You now, Thom, this is one of my favourite plugins! Thanks fo the updtae!
One question before downloading. I saw that you had it as UV Toolkit 2 in the menu - along with the original one (???).
Do I need to remove the previous version or will I (also) end up with two toolsets?
User avatar
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: arefine53, dcnet, ggaviola, MarcoPolo233, samuel_t and 16 guests
Visit our sponsors:
