by Didier Bur » Wed Dec 16, 2009 10:25 pm
Hi all, After a long silence, here is another toy I wrote to export SU terrains to Unity3D game engine, which uses RAW heightmaps to create terrains. I thought it could be of any interest to others, so here it is. Features: - creates BMP or RAW images, greyscale or color, 8 bits or 16 bits from any view of your model (top view recommanded of course) - creates a colored mask where no faces found in the view - can crop the image to the model projection - can blur the heightmap before writing it. Extract in Plugins folder, PDF doc included. Regards, EDIT: new release May 5th 2010, instant bugsplat fix  Get the latest version from the PluginStore Download
Didier Bur Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
- Name: Didier Bur
- Operating system: Windows
- SketchUp version: 2020
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by thomthom » Wed Dec 16, 2009 10:28 pm
That is interesting. Could probably use the generated image as displacement texture in render engines.
- PluginStore Author
- Name: Thomas Thomassen
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
by CadFather » Wed Dec 16, 2009 11:06 pm
Thanks Didier, very interesting and good to see you around..
CadFather
- Name: CadFather
- SketchUp version: 2014
- License type: Pro
- SketchUp use: landscape architecture
by Gaieus » Thu Dec 17, 2009 8:48 am
Hi Didier, Indeed, long time no see and good to know you are still around. I have been looking at Unity for a while now so I guess this will come handy soon - thanks!
- Name: Csaba Pozsárkó
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
by Pixero » Thu Dec 17, 2009 10:49 am
I get a instant BugSplat upon starting SU. When I remove it from the plugins folder SU starts normally. Using latest SU and the english version of your script.
Pixero
- Name: Pixero
- License type: Pro
by TIG » Thu Dec 17, 2009 2:48 pm
Same here...
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by ilay7k » Thu Dec 17, 2009 6:28 pm
Thanks Works at 6 version, but slow, seems my pc is slow same thing at 7 as TIG and Pixero
ilay7k
- Name: Ilya Shpilkin
- SketchUp version: 8
- License type: Free/Make
by DIEGO-RODRIGUEZ » Thu Dec 17, 2009 7:48 pm
thank you very much for sharing. Could make the menu visible, in order to personalize it. the plugins *.rbs , and menu of plugins *.rb
DIEGO-RODRIGUEZ
- Banned
- Name: diego
by Didier Bur » Thu Dec 17, 2009 7:50 pm
I get a instant BugSplat upon starting SU.  Are you on Mac, guys ? or do you use 7.1. ? Always the same boring SU version update problems with rubies, I guess...
Didier Bur
- Name: Didier Bur
- License type: Pro
by TIG » Thu Dec 17, 2009 8:05 pm
PC, Vista, with latest SUp v7.1+M1
- Global Moderator
- Name: TIG
- License type: Pro
by Didier Bur » Thu Dec 17, 2009 8:29 pm
@TIG:
I'm on SU v7.0.8657 Do you know of any change in the API for 7.1. ?
Didier Bur
- Name: Didier Bur
- License type: Pro
by TIG » Thu Dec 17, 2009 8:37 pm
Didier Bur wrote:@TIG: I'm on SU v7.0.8657 Do you know of any change in the API for 7.1. ?
- arccurve.is_polygon? - adding entities to groups initially seems less bugsplatty but it's not documented... so none that should affect this...
- Global Moderator
- Name: TIG
- License type: Pro
by thomthom » Thu Dec 17, 2009 8:49 pm
Model.number_faces only additions AFIK
- License type: Pro
by TIG » Thu Dec 17, 2009 8:52 pm
Have you modified any 'built-in' methods that might clash with others mods ?
- Global Moderator
- Name: TIG
- License type: Pro
by Didier Bur » Thu Dec 17, 2009 11:15 pm
@TIG: No, I never do that !
Didier Bur
- Name: Didier Bur
- License type: Pro
by Didier Bur » Thu Dec 17, 2009 11:17 pm
Didier Bur
- Name: Didier Bur
- License type: Pro
by AcesHigh » Fri Dec 18, 2009 1:23 am
awesome Didier! I had asked for such a plugin some months ago! It will be great to create some bumpmaps (or displacement maps) to use with VRAY!
AcesHigh
by EarthMover » Fri Dec 18, 2009 3:14 am
Didier I extracted the plugin to the plugins folder and it causes SU to crash upon opening. I removed the plugin and SU opened fine.
3D Artist at Clearstory 3D Imaging Guide Tool at Winning With Sketchup Content Creator at Skapeup
EarthMover
- Premium Member
- Name: EarthMover
- SketchUp version: 2016
- License type: Pro
by Didier Bur » Fri Dec 18, 2009 6:53 pm
It seems that crappy Vista is causing the problem (as usual). Since the script writes binary BMP or RAW files, ensure you have the right to do this (be logged as admin ?) Any other clue anyone ?
Didier Bur
- Name: Didier Bur
- License type: Pro
by Pixero » Sat Dec 19, 2009 7:32 am
Well...I had the same problems on XP at work, so... it can't be just Vista.
Pixero
- Name: Pixero
- License type: Pro
by notareal » Sat Dec 19, 2009 1:27 pm
 Nice tool. Wonder if hdr or exr would be possible as file options.
notareal
- Thea Render Support
- Name: notareal
by TIG » Sat Dec 19, 2009 4:37 pm
Didier Bur wrote:It seems that crappy Vista is causing the problem (as usual). Since the script writes binary BMP or RAW files, ensure you have the right to do this (be logged as admin ?) Any other clue anyone ?
Where does it write these to? I am an admin so it shouldn't matter. Also it crashes SUp BEFORE you try to do anything - just by loading it you get the problem.
- Global Moderator
- Name: TIG
- License type: Pro
by charly2008 » Sat Dec 19, 2009 5:13 pm
Hi TIG,
i have the same problem with XP. SU7 was just by loading and then came a Bugsplat.
Karlheinz
charly2008
- Name: KHA
- License type: Pro
- SketchUp use: hobby
by Didier Bur » Sat Dec 19, 2009 6:58 pm
It writes images at the same location than the SKP is. it crashes SUp BEFORE you try to do anything - just by loading it
That's what is really strange. I don't overwrite built-in methods, don't do any 'require' or something that involve other files. Would you please test this version and tell me if the problem persists ?
Didier Bur
- Name: Didier Bur
- License type: Pro
by Pixero » Sat Dec 19, 2009 7:05 pm
Still crashes instantly while loading SU. Now on Windows 7 64bit. SU 7.1.
Pixero
- Name: Pixero
- License type: Pro
by charly2008 » Sat Dec 19, 2009 7:25 pm
it still crashes while loading SU.
Karlheinz
charly2008
- Name: KHA
- License type: Pro
by TIG » Sat Dec 19, 2009 8:19 pm
Test file = instant Bugsplat. Didier - why not PM or email the 'uncompiled' script to one of us for debugging - you can trust me  ... You know that I hack into your encrypted rb files all of the time, but the rbs ones are a bit harder... just easier if you supply it unencrypted... It must be simple to fix...
- Global Moderator
- Name: TIG
- License type: Pro
by georglorenz » Sat Jan 16, 2010 4:11 am
Slightly off topic here: Is there a plugin that does the exact opposite of this one? That is creating a terrain from an greyscale image (.jpg or anything else)? Thank you. G
georglorenz
- Name: georglorenz
by Chris Fullmer » Sat Jan 16, 2010 4:46 am
There is, Didier wrote a script that imports a heightmap image into SU. I forget what its called, but it was written by didier bur and should be posted here on the forum somewhere....
- SketchUp Team
- Name: Chris Fullmer
- License type: Pro
by notareal » Sat Jan 16, 2010 3:07 pm
Nice work!
notareal
- Name: notareal
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
