Bert
I tried that page but my French is not good enough to see where the download link was for that ruby - can you post here s'il vous plait!
woodworking ruby.
• Page 2 of 2 • 1, 2
Re: woodworking ruby.Bert
I tried that page but my French is not good enough to see where the download link was for that ruby - can you post here s'il vous plait! When you burn your arse - you gotta sit on the blisters!!
Re: woodworking ruby.Hi Dermotcoll
If go on that page and goto Sketchup link on the left, you will have the choice of some very interesting plugins. For me 3 of them are very interesting for woodworkers like me one is "Queue d'arronde" which allows you to create a drawer with dovetails (If you need translation for the parameters windows, just let me know) The second one is "perçage" for making holes. Usefull when you have to create many holes like for Shelving adjustemt And the third one is "Coupe angulaire" or Angle cut. It allows you to cut a piece at any angles like a molding at 45 degrees All theese plugins have a small vidéos showing how to. Some have an english version. Whenever you see "télécharger xxx" it is the link for upload the pluging Salutations (Best regards) Bert
This plugin has already been presented here: viewtopic.php?f=183&t=19833 Jean-Franco
Try Google translate http://translate.google.com/translate?js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.premiumwanadoo.com%2Ftechnaulogis%2Fexemple_2.php&sl=fr&tl=en
Re: woodworking ruby.Bert, dedmin
Merci beaucoup. When you burn your arse - you gotta sit on the blisters!!
Re: woodworking ruby.Where can i find the woodwrk.rb file ?
Re: woodworking ruby.Did you read the first post in the thread?
Try this. Inspecting mirrors is a job I could easily see myself doing.
Re: woodworking ruby.Hello,
There was an error, we could make a good drilling only on one face of the volume. It is now possible on every face. You can download the version 04_03_en. Please make a test.
Re: woodworking ruby.I just tried the plugin for cutting angles that Bert mentioned and it seems to work quite well
Re: woodworking ruby.In the Plugins forum I have added an update the woodwrk.rb. It is now in a folder that has the various tools broken out. It now includes ktkoh mortise/ tenon ruby. One must copy the runwoodwrk.rb into the plugins folder. One can then edit that file to delete out any ruby's you don't want or add your own.
Thanks, Joel
Anybody has the "Coupe angulaire" plugin - the links are dead?
Re: woodworking ruby.Hi Dedmin,
Yvon, the guy behind those plugins has mentionned that his web site is beeing reworked and that the plugins should be availlable again in a near future Send me a PM with your e-mail and I will send you the plugin Salutations (Best regards) Bert
Re: woodworking ruby.Seems there is a new version for the SU8 - http://www.premiumwanadoo.com/technaulo ... mple_5.php
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
