SketchUcation Plugin Store
Set.insert vs array << x unless array.include?(x)
Postby thomthom » Fri Nov 20, 2009 1:04 pm
I was curious of the difference between Set.insert vs array << x unless array.include?(x) when you want a collection with a unique set of values.
So I did some tests:
Test 1
A 10,000,000 times I tried to insert a number between 0-10.
t=Time.now;a=[];10000000.times{r=rand(10);a<<r unless a.include?(r)};puts Time.now - t
Result: 12.297
t=Time.now;a=Set.new;10000000.times{a.insert(rand(10))};puts Time.now - t
Result: 15.719
The array was faster here by three seconds. But that's with ten million iterations!
Test 2
But, when your collection of unique values increases:
t=Time.now;a=[];100000.times{r=rand(10000);a<<r unless a.include?(r)};puts Time.now - t
Result: 45.129
t=Time.now;a=Set.new;100000.times{a.insert(rand(10000))};puts Time.now - t
Result: 0.391
When your collection include a much higher number of elements - then the Array quickly starts to crumble. In this case, when the possible unique set was up to 100,000 the difference was 44.738 seconds!!!
I tried this in some of my scrips which on occasions require a unique set of entites (like collecting all vertices) and the speed difference was immense on larger models.
It doesn't take too many number of unique elements before Set becomes faster then array.include?.
Scaling
Just to illustrate how they scale:
Array.include?
t=Time.now;a=[];1000.times{r=rand(100);a<<r unless a.include?(r)};puts Time.now - t
0.0
t=Time.now;a=[];10000.times{r=rand(1000);a<<r unless a.include?(r)};puts Time.now - t
0.485
42.906
t=Time.now;a=[];1000000.times{r=rand(100000);a<<r unless a.include?(r)};puts Time.now - t
Took too long. I guess it'd take ~4000.0s
Set.insert
t=Time.now;a=Set.new;1000.times{a.insert(rand(100))};puts Time.now - t
0.0
t=Time.now;a=Set.new;10000.times{a.insert(rand(1000))};puts Time.now - t
0.047
0.422
t=Time.now;a=Set.new;1000000.times{a.insert(rand(100000))};puts Time.now - t
4.937
Conclusion (not!)
Use the Set class when you require a unique set of values - unless your set of unique values is very small.
Set class is the rule - Array.include? is the exception.
Update
None of the above is the fastest. A better way has appeared. Collect everything into an array and apply .unique! at the end.
viewtopic.php?f=180&t=23760&p=222231#p222221
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Set.insert vs array << x unless array.include?(x)
Postby thomthom » Fri Nov 20, 2009 1:10 pm
Also, Set.include? is faster than Array.include?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby fredo6 » Fri Nov 20, 2009 7:00 pm
Tom,
very useful actually.
It really looks that the processsing in C is a lot faster than in Ruby.
Top SketchUcator
Postby thomthom » Fri Nov 20, 2009 7:07 pm
Fredo6 wrote:Tom,
Set class makes more processing in C?
What I'm wondering is, the Set class in SU Ruby is not the same Set class you get in Ruby 1.8.0. The Set class in Ruby 1.8.0 includes Enumerable and the set.rb looks to be a pure ruby class that mixes arrays and hashes. From my Ruby 1.8.0. installation, the Set class seem to be a pure Ruby implementation. But maybe the Set class that comes with SU is a C implementation...? Maybe that's why they replaced it?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Nov 20, 2009 7:09 pm
I thought the speed difference was that the Set class used a more efficient Hash lookup as oppose to the Array functions that has to iterate the array every time... but that's just guesswork...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby fredo6 » Fri Nov 20, 2009 9:08 pm
thomthom wrote:I thought the speed difference was that the Set class used a more efficient Hash lookup as oppose to the Array functions that has to iterate the array every time... but that's just guesswork...
You're right.
I personally use Hash whenever I want to store lists that have unique elements.
The list itself is obtained via Hash.values.
Maybe, as you are on this, you extend your benchmark to Hash and see how it compares with Set.
Fred
Top SketchUcator
Postby Chris Fullmer » Fri Nov 20, 2009 10:10 pm
Great info Thom! I had played around with sets and arrays before and I was not impressed with sets. But I did not experiment with amount of unique objects, which apparently has an adverse effect on arrays. Thanks,
User avatar
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby thomthom » Sat Nov 21, 2009 3:09 am
[quote="Fredo6"
Maybe, as you are on this, you extend your benchmark to Hash and see how it compares with Set.[/quote]
Will have a look at that.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jernej Vidmar » Fri Feb 05, 2010 1:17 pm
How about using Array.uniq! method:
Test 1
Result: 12.297
Result: 15.719
t=Time.now;a=[];10000000.times{r=rand(10);a<<r};a.uniq!; puts Time.now - t
Result: 7.753
Test 2
t=Time.now;a=[];100000.times{r=rand(10000);a<<r unless a.include?(r)};puts Time.now-t
Result: 40.97
t=Time.now;a=Set.new;100000.times{a.insert(rand(10000))};puts Time.now-t
Result: 0.377
t=Time.now;a=[];100000.times{r=rand(10000);a<<r};a.uniq!;puts Time.now-t
Result: 0.087
Last edited by Jernej Vidmar on Fri Feb 05, 2010 1:40 pm, edited 2 times in total.
Jernej Vidmar
Modelur
Postby thomthom » Fri Feb 05, 2010 1:22 pm
I'll be damned!
Very interesting Jernej.
...looks like I need to do some more testing of my script and possibly refactor again.
So while the Array.include? is dead slow - the overhead of hash look-up is still faster than just adding everything into one big pile and so a single filtering afterwards...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Feb 05, 2010 1:24 pm
looking at the .uniq! source code: http://ruby-doc.org/core/classes/Array.src/M002215.html
Code: Select all
 *  call-seq:
 *     array.uniq! -> array or nil
 *  Removes duplicate elements from _self_.
 *  Returns <code>nil</code> if no changes are made (that is, no
 *  duplicates are found).
 *     a = [ "a", "a", "b", "b", "c" ]
 *     a.uniq!   #=> ["a", "b", "c"]
 *     b = [ "a", "b", "c" ]
 *     b.uniq!   #=> nil
static VALUE
rb_ary_uniq_bang(ary)
    VALUE ary;
    VALUE hash, v, vv;
    long i, j;
    hash = ary_make_hash(ary, 0);
    if (RARRAY(ary)->len == RHASH(hash)->tbl->num_entries) {
        return Qnil;
    for (i=j=0; i<RARRAY(ary)->len; i++) {
        v = vv = rb_ary_elt(ary, i);
        if (st_delete(RHASH(hash)->tbl, (st_data_t*)&vv, 0)) {
            rb_ary_store(ary, j++, v);
    RARRAY(ary)->len = j;
    return ary;
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Feb 05, 2010 1:26 pm
Jernej: how about larger iterations and higher number of random values?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jernej Vidmar » Fri Feb 05, 2010 1:42 pm
thomthom wrote:Jernej: how about larger iterations and higher number of random values?
t=Time.now;a=Set.new;10000000.times{a.insert(rand(10000))};puts Time.now - t
Result: 37.911
t=Time.now;a=[];10000000.times{r=rand(10000);a<<r};a.uniq!; puts Time.now - t
Result: 8.282
Still a winner?
Jernej Vidmar
Modelur
Postby thomthom » Fri Feb 05, 2010 1:49 pm
It's refactoring time!
Nice find! :thumb:
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby RickW » Mon Feb 08, 2010 9:34 pm
That's all great (using .uniq!) until you start dealing with Point3d objects :)
In that case, always use Set.
RickW
Postby TIG » Mon Feb 08, 2010 9:40 pm
....or make all of your Point3d's into arrays so they will sort!/uniq! etc as arrays...
User avatar
Global Moderator
SketchUp version: 2013
License type: Pro
Postby thomthom » Mon Feb 08, 2010 10:29 pm
TIG wrote:....or make all of your Point3d's into arrays so they will sort!/uniq! etc as arrays...
But is the overhead of converting the Point3d's into arrays and uniq! faster than using a Set?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Mon Feb 08, 2010 11:31 pm
Who knows ?
Time for you to do another test... ;)
User avatar
Global Moderator
License type: Pro
Postby honoluludesktop » Wed Feb 02, 2011 3:34 am
I probably don't know what I am doing, but I ran the following test, and obtained the attached results. I typically use array.push variable, and don't understand the situations when the other examples might be used. Btw, when I applied the other forms to my app, it failed in ways that leave me to believe that those forms are data sensitive. Can anyone explaine to a Ruby beginner what's up?
Code: Select all
t=Time.now
a=[]
100000.times do r=rand(10000)
  a<<r
a.uniq!
puts Time.now-t
0.125
Code: Select all
t=Time.now
a=[]
  a.push r
a.uniq!
puts Time.now-t
0.141
Code: Select all
t=Time.now
a=[]
  a.push r
puts Time.now-t
0.094
Code: Select all
t=Time.now
a=[]
  a<<r
puts Time.now-t
0.093
User avatar
honoluludesktop
In Remembrance
by Ad Machine » 5 minutes ago
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: Anton_S, bbzwbbzw and 3 guests
