by gaucho » Tue Sep 02, 2008 5:35 pm
Didier Bur wrote:would be possible to modify so we could extrude along square shapes as well?
Use a precision of 4 and you'll get square section prisms.(RTFM)
Simple anD easy.. MERCI!
"eat well, stay fit, die anyway..."
gaucho
- Name: Giovani Cervo
by Juju » Tue Sep 02, 2008 7:01 pm
Marian wrote:i think there should also be an option to make not round tubes but square hexagonal triangular ones.
I think if you downloaded the plugin and checked the manual you'd see that it already does what you want.
Save the Earth, it's the only planet with chocolate. Keeping things organised is not a sin.
Juju
- Name: Julian Smith
by Didier Bur » Tue Sep 02, 2008 9:48 pm
Read the doc and USE PRECISIOn  !!! You beat me on this Juju !
Didier Bur
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by CameronVan » Wed Sep 03, 2008 12:55 am
Boofredlay wrote:Pilou wrote:for the problems, maybe you must disable the old "line2cyl.rb"?  maybe...
I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up. Thanks.
Ahhh, great. Thanks Pilou!
CameronVan
- Name: Cameron Van
by Marian » Wed Sep 03, 2008 7:43 am
Silly me....i did download the plugin and tried it before posting that...which makes me a bigger fool...but i didn't try the options...and manuals...who ever reads them?
Marian
- Name: Marian
by Didier Bur » Wed Sep 03, 2008 7:55 am
Those who don't want to bother doc writers
Didier Bur
- License type: Pro
by lorca » Sat Sep 19, 2009 10:29 am
Great plugin. Is there a way to close the gaps in sharp corners just like in "Pipe Along Path"?
lorca
by lexmonteiro » Mon Sep 21, 2009 2:45 pm
gaucho wrote:Didier Bur wrote:would be possible to modify so we could extrude along square shapes as well?
Great plugin, I was trying to create a window and realized that using precision 4, the corners were at 45 degrees, can I control the orientation of the angles? Thanks!
lexmonteiro
by chango70 » Thu Nov 19, 2009 3:59 am
Doesn't show up for me. I don't have older version at all. Any ideas?
chango70
by xrok1 » Thu Nov 19, 2009 4:31 am
i just DLd and it showed up in tools menu. thanks dedier!
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.” http://www.Twilightrender.com try it!
xrok1
- Name: Rocky
by chango70 » Thu Nov 19, 2009 5:17 am
Whats DLd?
chango70
by chango70 » Thu Nov 19, 2009 5:22 am
Its working now! WOOHOO! Great plugin!
chango70
by xrok1 » Thu Nov 19, 2009 5:37 am
chango70 wrote:Whats DLd?
downloaded
xrok1
- Name: Rocky
by flipya » Mon Jan 25, 2010 9:53 pm
I love this plugin! It's so incredibly easy to use and all the options I need are included. A+ for ease of use! Combined with the soapskin bubble plugin it's almost addictive It does sometimes crash my sketchup. The progress percentage builds up, slows down, and eventually just stops. A second or third try (saving before starting) usually does the job though. All in all, pretty much brilliant!
flipya
- Name: Philip
by majid » Thu Feb 18, 2010 9:04 am
first I must thank you for your handy tool Dider, and then I thought if you could combine this plugin with a geosphere creator + an option to have sphere in junction points, then we would have A LATTIC TOOL ,right in sketchup, that makes space frames easy.
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
majid
- Top SketchUcator
- Name: majid
- License type: Free/Make
- Level of SketchUp: Intermediate
by Pilou » Thu Feb 18, 2010 9:18 am
@majid for some things you can use that  A cool use of this "Multiple Face Offset" By Remus If you don't use it in this case Windowizer(3 free or 4) By Rick Wilson @Smustard don't make the "Frame Inset"!  Windowizer is a crazzy plug : All types of piercing windows + multiple selections Selection Only faces by Selection Toys by Thomthom Invert Selection by TIG For Crazzy Geodesic domes By TaffGoch @ 3Dwarehouse His site Crazzy PDF collector!
Pilou
- Top SketchUcator
- SketchUp version: 6
- SketchUp use: hobby
by TIG » Thu Feb 18, 2010 11:12 am
My EEbyFace also does something similar but it allows you to define the extrusion's cross section by making a 'flat' face [it's Y green axis = extrusions initial Z blue axis] - the face can be any shape you like so you are no longer limited to circular tubes...
- Global Moderator
- Name: TIG
- SketchUp version: 2013
- License type: Pro
by harshal kshatriya » Sun Feb 21, 2010 10:08 am
wow its working man............ i love it thanks a lot
harshal kshatriya
- Name: harshal
- SketchUp version: 7
- License type: Pro
by cadmunkey » Mon Jul 05, 2010 4:32 pm
Just installed this plugin and its great for converting custom autocad hatches into solids. Thanks man!
cadmunkey
by Pilou » Mon Jul 05, 2010 4:35 pm
Didier Bur plug "Line to tubes" can make circles of 3 edges so a triangle, 4 edges so a square, etc...
Pilou
- Top SketchUcator
by agamemnus » Sat Nov 20, 2010 8:36 pm
I tried this, but the tubes don't get "welded" / smoothed at edges: http://img109.imageshack.us/i/tubes.png/Is there a plugin that does this? Edit: Ok, never mind.. I used BZ tools to convert my loop to a bezier curve (edit 2: polyline is better, actually, for this...), and then applied this plugin. It's all welded now!
agamemnus
by alvin_pox » Fri Oct 14, 2011 5:16 pm
Hi. I've downloaded the .rb file in the plugin folder but when I restart sketchup, I keep getting a pop-up window with the following...
Error Loading File lines2tubes.rb undefined local variable or method `book' for main:Object
This plugin would really help with my design project greatly, so I'm really hoping someone here could help me get it to work. I'm using sketchup 8 on mac btw. Thanks.
alvin_pox
- Name: Alvin Lin
by TIG » Fri Oct 14, 2011 10:46 pm
Sounds like the file is corrupted as there is no reference to 'book' in it. Get the file again and put the .rb file into the Plugins folder, and retry. Don't edit it with a word-processor or similar as this might corrupt it... The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ?
- Global Moderator
- Name: TIG
- License type: Pro
by alvin_pox » Sat Oct 15, 2011 2:05 am
TIG wrote:Sounds like the file is corrupted as there is no reference to 'book' in it. Get the file again and put the .rb file into the Plugins folder, and retry. Don't edit it with a word-processor or similar as this might corrupt it... The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ?
Have downloaded the file again and it works now! I noticed that the file I had yesterday had a big red "Rb" on the file icon thumbnail, but it doesn't today after I redownloaded it. I also tried other plugins yesterday and all seemed to get the same error message when loading and the big red Rb on their thumbnails, so it doesn't look like it was a single corrupted file. Weird. But it's all sorted now. Thanks so much:p
alvin_pox
- Name: Alvin Lin
by majid » Sat Oct 15, 2011 5:06 am
Thank you Pilou I was specting junction spheres. like this , 1 min try wings3d ( it is handy in some cases, while a different approach, and is easy enough for me that am not a 3dsmax fan)
Please, register (free) to access all the attachments on the forums. درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
majid
- Top SketchUcator
- Name: majid
by Pilou » Sat Oct 15, 2011 2:12 pm
And Wings3D can reload 3DS format from 3Dwharehouse or from SU
Pilou
- Top SketchUcator
by majid » Sat Oct 15, 2011 5:15 pm
yeap, it has wide range of import/export formats included. very handy,... sort of free subd/smooth
majid
- Top SketchUcator
- Name: majid
by btxscg » Sat Oct 29, 2011 7:52 am
it's great
btxscg
by irwanwr » Wed Nov 30, 2011 8:51 pm
i'd like to thank the author, Didier for this very useful plugin. i used to utilise the push/pull tool before. with this plugin, i could just do it on the line frames and one or two more clicks. thank you very much
irwanwr
- Name: irwanwr
- Level of SketchUp: Beginner
by Steuart » Sat Mar 03, 2012 1:17 pm
Hi Didier and all. I have just installed the Lines2tubes plug in. Initially I tried to use it and it crashed (of course before I had saved anything - auto save does not seem to work unless you have done at least an initial save). Then each time I tried to re:launch SU it would instantly crash. I also tried TubeAlongPath and pretty much the same thing happens. In each case it was fine once I had remeoved the plug in. Anyone any ideas? I am using a Macbook pro, with 10.5 and SU 8. I would love to be able to use the program as it would save a huge amount of time.
Steuart
- Name: Steuart
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
- Robot
Return to Plugins
