The "Duh!" thread (aka the Doh! thread)
General discussion related to SketchUp Pro and Make
Re: The "Duh!" thread
Postby Align » Fri Nov 06, 2009 7:18 pm
thomthom wrote:A more recent Duh I had:
Being able to select only a few edges from a face and offset them instead of the whole face.
how do you do this?
Align
Re: The "Duh!" thread (aka the Doh! thread)
Postby thomthom » Fri Nov 06, 2009 7:21 pm
Select the edges and and activate offset...
User avatar
PluginStore Author
PluginStore Author
Postby EscapeArtist » Sat Nov 07, 2009 7:09 pm
plot-paris wrote:wow, cool. didn't know about that eihter. but what I would even more like to see is a push/pull :pushpull: like this:
It exists! Here: viewtopic.php?f=180&t=23341
User avatar
EscapeArtist
Top SketchUcator
Postby pilou » Fri Nov 13, 2009 8:26 pm
Select an element (lines, surface)
Open Entity Info yes ;)
Then when you select with Shift , Shift + Ctrl or Ctrl
all surfaces or length lines are added , subbstracted, modified, visible and updated in the Entity info! :D :roll:
Speedy Galerie
User avatar
Top SketchUcator
Postby Ecuadorian » Sun Nov 15, 2009 12:51 am
I was working in a "mysterious" file that did not allow me to pushpull anything, and I was about to post the mysterious file here. After checking, "Snap to length" was set to a very high value. Duh!
Ecuadorian
Postby Chris Fullmer » Sun Nov 15, 2009 4:50 am
I just found one for me tonight. I change the model axis pretty often when I work. But I never noticed that you can activate the axis tool (or change axis inside of a component tool) and click twice somewhere and it will move the axis to that point without changing its orientation. Normally I would have clicked once, then lined up the the axes and click and line up and click. So a double click (not too fast though!) is much faster for moving the axis.
User avatar
SketchUp Team
SketchUp Team
Postby Gaieus » Sun Nov 15, 2009 5:04 pm
OK, this is a very painful duh:
My system seemed to crash and I could not even start windows in safe mode (Mac users, don't sneer, please) so I decided to at least try to repair my system. It didn't allow me as whatever imaginable I entered, it didn't accept it as the password of the system admin.
So I reinstalled (I have a recent backup of my documents at least). Then I realised that I didn1t even have a password and should have just hit Enter without entering any password.
:oops:
So basically this is what I wasted my Sunday for. I have a deadline tomorrow. :?
User avatar
Postby plot-paris » Mon Nov 16, 2009 10:22 am
oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter :roflmao: , feel terribly sorry for you :( or just blush with embarassment, because that could just as well have happened to me :oops:
User avatar
plot-paris
Postby plot-paris » Mon Nov 16, 2009 11:04 am
another one. after importing a messy 3Ds model and cleaning it up with Thomthoms cleanup-script (thanks again, thom), I started entering every single one of the over 1500 groups/components, to smooth their surfaces.
then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
User avatar
plot-paris
Postby thomthom » Mon Nov 16, 2009 11:08 am
plot-paris wrote:then I just discovered, that you can apply the smoothing to groups/components, without entering them. so you can select all the groups at once and only have to do the proces once! (doesn't work with nested groups though)
I recently discovered that as well!
In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
User avatar
PluginStore Author
PluginStore Author
Postby plot-paris » Mon Nov 16, 2009 12:00 pm
thomthom wrote:In regards to CleanUp - it does have a function to smooth the geometry it cleans up. If you use CleanUp Entire Model you have a field "Smooth Edges by Angle".
yet another 'Doh'
I can put my Homer button to quite some use today :D
User avatar
plot-paris
Postby Gaieus » Thu Nov 19, 2009 1:15 pm
plot-paris wrote:oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter :roflmao: , feel terribly sorry for you :( or just blush with embarassment, because that could just as well have happened to me :oops:
Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. :cry:
User avatar
Postby plot-paris » Thu Nov 19, 2009 2:01 pm
uh, thats bad!
actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
User avatar
plot-paris
Postby broomstick » Fri Nov 20, 2009 9:07 pm
I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
DUH!!
User avatar
broomstick
Postby Ecuadorian » Fri Nov 20, 2009 10:10 pm
Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. :shock:
Ecuadorian
Postby pilou » Sat Nov 21, 2009 12:05 am
:thumb: Tricky and speedy :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby Chris Fullmer » Wed Dec 30, 2009 7:02 am
I just discovered that you can use more than one modifier key when setting up shortcut keys. example
ctrl + shift + alt + Q
or snything along those lines. I never reazlied that... :oops:
User avatar
SketchUp Team
SketchUp Team
Postby plot-paris » Thu Jan 07, 2010 3:08 pm
just out of interest: what function did you assign to
Ctrl + Shift + Alt + Q???
User avatar
plot-paris
Postby Gaieus » Thu Jan 07, 2010 3:32 pm
When I press that, it triggers an automatic poking of you on Facebook.
:roflmao:
(I dare not try if there is anything assigned to it by default because I am rendering an animation) :?
User avatar
Postby Chris Fullmer » Thu Jan 07, 2010 7:44 pm
It is my auto-assinate button in SU :)
I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
User avatar
SketchUp Team
SketchUp Team
Postby pilou » Thu Jan 07, 2010 10:56 pm
A list of shortcuts :mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
Postby mitcorb » Thu Jan 07, 2010 11:07 pm
Chris Fullmer wrote:It is my auto-assinate button in SU :)
Now, what would an "auto-assinate" button do, exactly?
Hee Hee!
User avatar
mitcorb
Top SketchUcator
Postby Chris Fullmer » Thu Jan 07, 2010 11:19 pm
I struggle...
User avatar
SketchUp Team
SketchUp Team
Postby pilou » Fri Jan 08, 2010 4:10 pm
Triangulate a simple rectangle surface with the Sand box? :oops:
Just draw a diagonal first! :o
Then apply the Sand box "Add détails" :mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Thu Jan 28, 2010 6:16 pm
A cool one! :oops:
The Duhduh of the day! Never used! :roll:
Thx Jeff :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby KXI System » Fri Jan 29, 2010 1:17 am
:roflmao:
Thing was, the people who I looked up to as pro's...
Are the ones that had the most "duh!"s
:roflmao:
Getting the perfect sig is hard...
Google it!
KXI System
Postby Gaieus » Fri Jan 29, 2010 10:19 am
KXI System wrote:Thing was, the people who I looked up to as pro's...
That's because only those who think have genuine doh moments... :roll:
User avatar
Postby ely862me » Fri Jan 29, 2010 11:48 am
:D
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
User avatar
ely862me
Top SketchUcator
Postby KXI System » Sun Jan 31, 2010 10:12 pm
OK, I'll share a duh moment.
THE COMPONENT DIALOG BOX IS JUST A MINI 3-D WAREHOUSE WINDOW!
I found out by trying to search for a component and ended up with the same search results as the first page in the 3-D warehouse.
WARNING, THE FOLLOWING DUH MOMENT IS PROVEN TO DECREASE PRODUCTION BY 1000%!
OK, first I found one of the antics figures off the warehouse (not through the component dialog window). Now all antic models have a link to the same youtube video, so I clicked on it and next thing you know I have youtube fully working inside sketchup! :lol: I got nothing done that day...
Google it!
KXI System
Postby Jim » Thu Mar 04, 2010 3:14 am
Just learned the physical size of the SU window matters when trying to print to scale.
No matter what I did I could not get my unscaled print on a single page, even though it would have easily fit on a single page. After making the SU window narrower than the height, SketchUp decided it would fit a a single sheet after all.
Jim
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: BearEnthusiast99, TharLaingMar and 2 guests
Visit our sponsors:
