[Plugin] Make Named Group (1.0.0) — 12 November 2009
• Page 1 of 1
[Plugin] Make Named Group (1.0.0) — 12 November 2009By request-ish: viewtopic.php?f=180&t=23567
(Code sample turned out to become full plugin.) Adds Make Named Group to the Edit menu. Please, register (free) to access all the attachments on the forums. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Nice! I like the Layer addition.
What about defaulting it so the GROUP NAME field is highlighted first? Then you can immediately enter a group name, instead of selecting it, then naming it?
hm... don't think I have control of that. Unless I swap the order of them. Or I could make a custom window. Will see. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Unfortunately with the basic inputbox the last set field is always highlighted...
I filed a bug on this. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009In this order of idea: a ruby who take the name of a group (or Component) selected then create the same "Layer name" and put the group (or Component) in this new Layer named will ne fine
Untested, but this should place all groups/components into a layer based on their name.
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Would it be possible to put the entry from the "Edit Menu" to the context menu?
greets din
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009I will see if I can add support for UI Manager - so you can choose. There are people who prefer not to have their context menu filled with more items. So it's not easy to get a balance. But when the user can choose then it's not an issue any more.
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Thanks for the plugin, a great idea.
Regards, JGA Regards,
JGA
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009I just saw this - very useful! I started recently using groups instead of components and I'm using this wonderful plugin - viewtopic.php?t=9318
If there is a way to combine them into one - perfect!
Is there different functionality? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009It has a drop-down list of 20 names to choose from
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009That seems very specific...
I still don't see what combination it is you're looking for. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Your plugin plus a drop-down list for the group names. Jim's plugin allows You to write 20 most used names in a text file for later use - useful in many fields where the parts are common - furniture and the like.
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Hey Thomas, love your plugins....
With this one; do you think you could have the group added to a layer of the same name? If no layer, ask the user do you want to add a layer? Would be a great timesaver..... Thanks. A purpose/expression/purpose/....
It would be interesting if there was a box or drop down menu where it appeared the possibility to create and now include the object in a layer with the same name. Create components instead of groups might be interesting too.
Thom? purpose/expression/purpose/....
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Great plug in.Thanks.
I`ve assigned `G' as a shortcut to it so I don`t have to keep going to the Edit menu.
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Thanks a lot for this plugin.
I would love to see this plugin "Make Named Group" in the right-click-menu. Is that possible?
It is possible - but if I where to add it I'd get requests about removing it from people who want to reduce the amount of items in the context menu. Right now I don't have the time to make a UI for controlling this option. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009Hello just tried to download and says the .rb file is locked. How do I unlock I have a macbook pro.
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
• Page 1 of 1
