[Plugin] file_new.rb Startup, Your Way
Postby MartinRinehart » Tue Nov 10, 2009 8:37 pm
I don't like the Line tool. I avoid it whenever possible. Naturally, I don't want to see it when I start SU, nor after File/New.
This Ruby starts My Way. I give the "New File" item in the Plugins menu "N" as keyboard shortcut.
Customize to make it start Your Way:
1) You may want to delete the line that opens the Ruby Console.
2) You may want to choose another tool. Your choices are:
Arc, Axis, Circle, Dimension, Dolly, Erase, Extrude, FieldOf, Freehand, Line, Measure, Move, Offset, Orbit, Paint, Polygon, PositionCamera, Protractor, PushPull, Rectangle, Rotate, Scale, SectionPlane, Selection, Text, Turn, Walk, Zoom, ZoomWindow
3) If you know Sketchup Ruby programming, the sky is the limit.
To install: copy this code, edit as you like, and save into a file named "file_new.rb" in your Plugins directory.
Code: Select all
# file_new.rb - start my way!
# Copyright 2009, Martin Rinehart
# Forbidden: remove copyright notice; use in "how to program ..." material.
# Permitted: everything else.
require 'sketchup'
def send_actions()
   Sketchup.file_new()
   Sketchup.send_action( 'selectSelectionTool:' )
end # of send_actions()
unless file_loaded?( "file_new.rb" )
   UI.menu("Plugins").add_item( 'New File ' ) { send_actions() }
   send_actions()
   Sketchup.send_action( 'showRubyPanel:' )
   file_loaded( "file_new.rb" )
MartinRinehart
Re: [Plugin] file_new.rb Startup, Your Way
Postby thomthom » Tue Nov 10, 2009 8:48 pm
You could attach it to the onNewModel event. Think there was a plugin that ensured the Select tool was activated upon opening or creating new models using that event....
User avatar
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Tue Nov 10, 2009 9:35 pm
The line tool is my favorite SU tool, with the eraser a close second, and then select comes in at No.3 I think. :)
And yes, someone did write a startup tool script....I don't recall who or what it was called exactly though. I never used it since I love the pencil so much :bounce:
User avatar
SketchUp Team
SketchUp Team
Postby thomthom » Tue Nov 10, 2009 9:43 pm
I'm with Martin here. The pencil is usually not the tool I start to use. Select all the way! :ugeek:
User avatar
PluginStore Author
PluginStore Author
Postby RickW » Tue Nov 10, 2009 10:35 pm
thomthom wrote:Think there was a plugin that ensured the Select tool was activated upon opening or creating new models using that event....
Chris Fullmer wrote:And yes, someone did write a startup tool script....I don't recall who or what it was called exactly though.
Perhaps you were thinking of SelectAtStartup by yours truly ;)
It used observers to check for SU launch, file load, and new file actions to ensure that the Select tool was the default tool any time the active model changed.
RickW
Postby MartinRinehart » Wed Nov 11, 2009 2:15 pm
RickW wrote:
thomthom wrote:Perhaps you were thinking of SelectAtStartup by yours truly ;)
Sweet and simple, Rick. Plus, you get model opening, which I missed.
MartinRinehart
Postby chrisjk » Wed Jan 27, 2010 8:35 pm
This doesn't seem to work for me on my setup (Mac 10.6 , latest SU Pro). Does the code need updating?
chrisjk
Premium Member
Premium Member
Postby Chris Fullmer » Wed Jan 27, 2010 8:52 pm
Which are you trying to use? Martin's code or Ricks?
User avatar
SketchUp Team
SketchUp Team
Postby chrisjk » Wed Jan 27, 2010 10:54 pm
I am trying to use Rick's code.
chrisjk
Premium Member
Premium Member
Postby xrok1 » Thu Jan 28, 2010 10:47 pm
YES! YES! YES! thankyou very much Rick. this has always bugged me since about 9 of 10 times i'm opening an existing model and have no use for the pencil. :D and thank you too Martin for bringing the topic up.
xrok1
Postby Ruturaj » Fri Jan 29, 2010 9:04 am
Hello MartinRinehart,
Thanks you very much, :thumb:
Thanks,
RuturaJ
Ruturaj
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: sas1976 and 12 guests
Visit our sponsors:
