[Plugin] CleanUp
[Plugin] CleanUp
Postby thomthom » Wed Oct 21, 2009 6:36 pm
Overview
This plugin does it best at optimize and clean up a model.
Access
Plugins > CleanUp
Features
  • Fixes duplicate component definition names ( When in model scope )
  • Purge unused items
  • Erase hidden geometry
  • Erase duplicate faces
  • Erase lonely edges ( Except edges on cut plane )
  • Remove edge material
  • Repair split edges
  • Smooth & soft edges
  • Put edges and faces to Layer0
  • Merge identical materials
  • Merge connected co-planar faces
Requirements
  • SketchUp 7.1 or newer - You can run it on older versions, but it will not yield a predictable result - you will be warned about this.
  • TT_Lib2 (v2.7.0)
Guide: How to install RBZ Files
Download
Footprint
<Sketchup>/Plugins/
tt_cleanup.rb
History
Both the Sketchup Importers option too remove coplanar edges and the deletecoplanaredges plugin have given me mixed result. Geometry tend to disappear in some cases. Part of that is due to a Sketchup bug: http://forums.sketchucation.com/viewtop ... 30#p164501 and another part is due to what seem to be some inconstancy with the way Sketchup and the Ruby API deal with numbers.
As of 7.1 the first issue appear to have been fixed. (Yay! :berserk: ) And I have found a work around for the other issue.
If you experience geometry to be lost, while using SU 7.1 - please let me know so I can look into it.
If you have geometry selected it will work on those only. Otherwise it will iterate over the current context.
Technical Jabber
Prior to SU 7.1 there was a bug where in some cases deleting an coplanar edge, either via Ruby or the Eraser tool, would make its connected faces disappear. See this thread for more info and samples: http://forums.sketchucation.com/viewtop ... 30#p164496
I tried to work around that previously, but the code ended up stupidly complex trying to keep track of all the edges I couldn't erase, and no matter what I did I always ended up loosing geometry, or not managing to remove everything. With this issue fixed in SU 7.1 it's now dead easy; Find'em and Erase'em!
Update — 22 April 2010
New and improved method to detect coplanar faces. No more messing about with tolerances. :berserk:
25
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Cleanup (1.0.0) — 21 October 2009
Postby Ecuadorian » Wed Oct 21, 2009 6:42 pm
Thank you, man. I have the perfect file to test it. :D
Ecuadorian
Postby thomthom » Wed Oct 21, 2009 6:44 pm
Ecuadorian wrote:Thank you, man. I have the perfect file to test it. :D
A particular troublesome file? Please let me know how it goes. Not sure if I've got it fully tuned in yet.
User avatar
PluginStore Author
PluginStore Author
Postby remus » Wed Oct 21, 2009 6:45 pm
Cheers thom, a very useful script.
remus
Postby Ecuadorian » Wed Oct 21, 2009 6:51 pm
:shock: Wow... no more lost faces (as happened with other cleanup scripts), and cleanup is top-notch.
Here it is applied only to the horizontal white borders:
You do realize the importance of this script in the history of SketchUp, do you? Thanks again! :thumb:
Ecuadorian
Postby thomthom » Wed Oct 21, 2009 6:56 pm
Good to see it working on other complex models. I only tried it against one complex one, large triangulated terrain with 80K+ faces. (Though that model had all the potential problems you could run into AFIK.)
User avatar
PluginStore Author
PluginStore Author
Postby Jim » Wed Oct 21, 2009 7:05 pm
Ack! it doesn't look at materials?
Oh, and thank you! :thumb:
Jim
Global Moderator
Postby thomthom » Wed Oct 21, 2009 7:07 pm
Jim wrote:Ack! it doesn't look at materials?
No, but that's a very good suggestion.
Ecuadorian did find some issues with some geometry, so I'll push an update when I've gotten around to look at it.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Wed Oct 21, 2009 7:13 pm
Ecuadorian:
I had a look at your sample file. I see the issues. I think it's a tolerance issue. I'll have to investigate a little more to tune in the tolerance.
User avatar
PluginStore Author
PluginStore Author
Postby Ecuadorian » Wed Oct 21, 2009 7:25 pm
Thanks! I think I now remember what the problem might be, also. The model is scaled a lot. :?
Ecuadorian
Postby thomthom » Wed Oct 21, 2009 7:42 pm
This is strange. When I compare the dot product of various faces, I find an overlap in the return value for faces where you can erase the connecting edge:
Code: Select all
   # Not coplanar
   # 0.999999999898786
   # 0.999999999901467
   # 0.99999999992968
   # 0.99999999995352
   # 0.999999999959393
   # 0.999999999974808
   # Coplanar
   # 0.999999999917881
   # 0.999999999918562
   # 0.999999999984962
   # 0.999999999999148
   # 0.999999999999408
User avatar
PluginStore Author
PluginStore Author
Ecuadorian wrote:Thanks! I think I now remember what the problem might be, also. The model is scaled a lot. :?
I did notice that - but I exploded it and it still occurs...
User avatar
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Wed Oct 21, 2009 8:46 pm
Could you take the edge, find its connected faces. Then get the object id for those faces, and get all their vertices positions. Then delete the edge if it is planar. Then test to see if those faces still exist. If they do, move on. If they do not, then rebuild them using their vertices' positions? Painful yes, but maybe useful?
User avatar
SketchUp Team
SketchUp Team
Postby thomthom » Wed Oct 21, 2009 8:48 pm
Chris Fullmer wrote:Could you take the edge, find its connected faces. Then get the object id for those faces, and get all their vertices positions. Then delete the edge if it is planar. Then test to see if those faces still exist. If they do, move on. If they do not, then rebuild them using their vertices' positions? Painful yes, but maybe useful?
I did that kind of stuff in my previous version, prior to 7.1 - wasn't stable. So many cases to take into account. Faces with inner holes etc...
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Wed Oct 21, 2009 8:49 pm
I think I might have misunderstood this whole DOT product from vectors... will have to look deeper into it.
User avatar
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Wed Oct 21, 2009 8:49 pm
Can you hit ctrl-z in ruby? :)
User avatar
SketchUp Team
SketchUp Team
Postby remus » Wed Oct 21, 2009 8:57 pm
thomthom wrote:I think I might have misunderstood this whole DOT product from vectors... will have to look deeper into it.
What do you think is not working? from my quick browse of your script the dot product should do what you want.
remus
Postby thomthom » Wed Oct 21, 2009 8:58 pm
Chris Fullmer wrote:Can you hit ctrl-z in ruby? :)
Yea, http://code.google.com/intl/nb/apis/ske ... .html#undo
But that would ruin any kind of possibility to undo the whole erase coplanar operation.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Wed Oct 21, 2009 9:00 pm
...could create a temp group and use that to replicate the two faces (when within a range where we can't be certain.)
but I'd still try to avoid that if I can calculate this.
User avatar
PluginStore Author
PluginStore Author
Postby honoluludesktop » Wed Oct 21, 2009 9:50 pm
Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor). Didn't read all the post, so sorry if already covered.
User avatar
honoluludesktop
In Remembrance
Postby thomthom » Wed Oct 21, 2009 9:52 pm
honoluludesktop wrote:Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor).
At the moment it doesn't take into account materials. Only geometry.
Images? You mean an actual Image entity (It says "Image" in Entity Info when you select it?)
User avatar
PluginStore Author
PluginStore Author
Postby honoluludesktop » Wed Oct 21, 2009 9:55 pm
Well, I often import images (as images, not textures), and place them on textured faces.
Last edited by honoluludesktop on Wed Oct 21, 2009 10:00 pm, edited 1 time in total.
User avatar
honoluludesktop
In Remembrance
Postby thomthom » Wed Oct 21, 2009 9:57 pm
honoluludesktop wrote:Well, I often import images (as images, not textures), and place them on textured faces.
They would be ignored.
However, I do plan on adding an option for it to respect the material of the geometry. Just got to sort out some other issue first.
User avatar
PluginStore Author
PluginStore Author
Postby honoluludesktop » Wed Oct 21, 2009 10:01 pm
Opps, added image after your post.
User avatar
honoluludesktop
In Remembrance
Postby pilou » Thu Oct 22, 2009 3:00 am
Seems another very useful plug :enlight:
About the Ecuadorian file
Why not scale the file *10, apply the plug, then scale 1/10 ? ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Thu Oct 22, 2009 7:01 am
Pilou wrote:Seems another very useful plug :enlight:
The scale isn't the issue.
User avatar
PluginStore Author
PluginStore Author
Postby chango70 » Thu Oct 22, 2009 12:29 pm
This works very well. I have made Ctrl Shift C short cut for it. Thank you!
chango70
Postby thomthom » Thu Oct 22, 2009 1:20 pm
honoluludesktop wrote:Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor). Didn't read all the post, so sorry if already covered.
Option to respect materials applied added. On by default.
Ecuadorian:
I adjusted the tolerance so it shouldn't loose any geometry on the model you sent me. Hopefully it won't loose anything in other models either.
But there is some cases where which can be removed is left behind. I hope to address this. I figured it's best to be defensive than aggressive.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Cleanup (1.0.1) — 22 October 2009
Postby Ecuadorian » Thu Oct 22, 2009 1:24 pm
Sounds nice, Thom!
Perhaps you could give the user two or three threshold options.
Ecuadorian
Postby thomthom » Thu Oct 22, 2009 1:34 pm
Ecuadorian wrote:Sounds nice, Thom!
I added an debug option which you can use for now. You can see it in the screenshot.
The closer to 1.0 the stricter it is.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
cron
Who is online
Users browsing this forum: Batik35890, Beastofarch, coco16778, jeff0805, marcelp102, Niktn, porschegt2, rv1974 and 21 guests
Visit our sponsors:
