Did it have time-limit?
No seems to works fine even today
Sorry for the model, it's just a test
[Plugin] 2 Faces + Path ver. 1.5.
• Page 2 of 3 • 1, 2, 3
Re: [Plugin] 2 Faces + Path ver. 1.0.@ Takesh san
No seems to works fine even today ![]() Sorry for the model, it's just a test ![]() Last edited by pilou on Tue Sep 08, 2009 2:06 pm, edited 1 time in total.
Re: [Plugin] 2 Faces + Path ver. 1.0.Strangely the same happened to me yesterday, just stopped working. I thought I'd forgotten how to use it but alas it was not, just stopped working.
Re: [Plugin] 2 Faces + Path ver. 1.0.There is a timer inside MAybe I am wrong but seems that is only if the calculate is too long for break it
Maybe this makes conflict with your program?
Re: [Plugin] 2 Faces + Path ver. 1.0.AMAZING (:
I was just waiting for something like that... it makes me feel i work with rhino ![]() ![]() ![]() ![]() ![]() ![]() ![]() Re: [Plugin] 2 Faces + Path ver. 1.1.Guys, plugin is free and open sorce. The time when you'll become surfeited with it is actually the only time limit
![]() It would be absurd to add time limit to open sorce script. Obviously ![]()
Re: [Plugin] 2 Faces + Path ver. 1.1.![]() simply amazing. thank you very much! Re: [Plugin] 2 Faces + Path ver. 1.2.This is got to be one of the coolest plugins. It reminds of control curves on grasshopper. speaking of which i wonder when someone will make grasshopper for SU. I can always dream can't I.
Re: [Plugin] 2 Faces + Path ver. 1.2.While collecting parts of my yaw from the table I don't yet know where to use this... but seriously amazing.
Re: [Plugin] 2 Faces + Path ver. 1.2.Wow Krill. This looks amazing. With This you have turned a simple program into an amazing modeling tool. Thanks.
Re: [Plugin] 2 Faces + Path ver. 1.2.Krill,
I am sitting in stunned amazement! You are smart, talented, creative, and just amazing. Thank you for sharing ![]() Humbled,
Re: [Plugin] 2 Faces + Path ver. 1.3.I discovered something and I am also having some problems...
First, here's a screenshot of my experiment file, I was looking at how the different orientation of the faces affected the outcome of the process. Interesting! Now, I'm having some problems. When I try to use the 2 Faces + Path plugin, it gives me an error: It is necessary to select two faces and one path curve. As far as I can tell, I have (1) one curve and (2) two faces selected. The curve is made with two arcs, welded together with the weld.rb. I've also attached the skp for this file. Any assistance would be greatly appreciated! I forgot to add, it worked yesterday. Then today it stopped. I've reloaded the rb, but no luck. Here's a shot of it working yesterday... Re: [Plugin] 2 Faces + Path ver. 1.3.All I want to be able to do is produce Reduced Pipe Elbows; have the one surface scale to other along a radius (or another user created path) in EQUAL increments.
Unless I am misusing the options all I get is a contraction of diameters along the path which eventually get smaller than the diameter of the face at the other end of the path as shown below. This is not what I was hoping for. Perhaps this not what this script is meant for. If not, could another script be developed that does equal incremental scaling? Perhaps only two options would be necessary, one to smooth the skin or not to smooth the skin. The below image is what I'd like a blend along path to be capable of (I manually drew the elbow). John | Illustrator | Beaverton, Oregon
Re: [Plugin] 2 Faces + Path ver. 1.4.Dear Kirill,
Thank you so much for this fantastic tool:---- which certainly needs to be studied and tamed.. ![]()
But hopefully, we now have your 2Faces+Path to solve the problem pretty easily ![]() ![]() ![]() Re: [Plugin] 2 Faces + Path ver. 1.4.
Yes, go to the first page, very first post. Cheers, . Diego . Re: [Plugin] 2 Faces + Path ver. 1.4.Great Ruby, thanks Krill.
People have been wanting this for a long time ![]() Re: [Plugin] 2 Faces + Path ver. 1.4.Hey Kiril, didn't know where to post this so that it would be easier, so i thought id post on both.
the 2 faces and path tool only works for faces along 1 path. is it possible to blend two lines (or splines) along a path ? heres an example. Re: [Plugin] 2 Faces + Path ver. 1.4.Kirill,
Thank you for this plugin. It's very useful. I am having some problems with it, however. I've attempted to reproduce what you've shown in the last video for v1.4 with a circle, square and arc. I can get the geometry alright but I cannot get the front face color on the outside (short of opening the group, selecting the faces and reversing them the old fashioned way) nor can I get the color change from one end to the other as you did when you painted one face red. What am I missing? I did just install version 1.4 so it should be a fresh install of the plugin. Thanks again. Dave Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Salut Pilou, C'est genial ce que tu as fait. Can you please show us how you did it? I would like to see the different shapes and the curve. Merci beaucoup! Have a wonderful day. _KN Follow Your Dreams.
An arc, an ellipse, a cross: when the drawing is made you can turn, move, scale original generators for explore variations ![]() Can't be more simple ![]() ![]() Et voila ![]()
Awesome! Thank you very much. Hmm..ok, so I tried it and here's what I got. Any ideas why? Thanks. Follow Your Dreams.
Hi, Ken. This is an issue ![]() "Process nearest indices" method does not depend on face bound topology. BTW, if someone try to process faces with more complex topology (I mean, faces with internal holes), then plugin will also fail to make an appropriate morphing, regardless of chosen shape morphing option. For example we have 2 faces: 1-st has circular outer loop and 3 square internal holes, 2-nd has square outer loop and 2 circular internal holes. Well... I must say, the decision what kind of morphing would be more appropriate becomes pretty unobvious ![]() Last edited by kirill2008 on Sat Dec 12, 2009 11:31 am, edited 2 times in total.
Re: [Plugin] 2 Faces + Path ver. 1.4.It's works for me because I use an oldest version
Thanks, Kirill! Looking forward to the updated plugin. Take care. Follow Your Dreams.
Re: [Plugin] 2 Faces + Path ver. 1.4.Hi,ken28875,I want 2 face+path give path just like this:
Hi hsjyangbin, I think you meant to ask Kirill. He's the one who wrote the plugin. I have no idea about code. lol _KN Follow Your Dreams.
Re: [Plugin] 2 Faces + Path ver. 1.5.Seems there is a little glitch !
![]() Don't works for all these sort of "pierced faces" ! CLick if scrollbars
