Silvershadow's Eye Candy 3 - H.M.C.S SNOWBERRY
Re: Silvershadow's Eye Candy 3 - H.M.C.S SNOWBERRY
Postby accabrera » Wed Jul 22, 2009 3:29 am
Just...the best! :ugeek:
accabrera
Postby plot-paris » Thu Jul 23, 2009 10:32 am
absolutely mindblowing, once again, silvershadow!
have been away from the forum for quite a while (involuntarily of course). and now I am back - and here it is, your third, long anticipated Eye Candy! such a incredible amount of detail. stunning. although I also think you can do even better renderings, when going a bit closer, so one can behold the high level of detail...
by the way. do you know, when it will be possible do download your models again? do we have to wait until august? or are there maybe some resources left at the scf server, Coen? can't wait to lay my hands on these models
User avatar
plot-paris
Postby Chris Fullmer » Fri Jul 24, 2009 8:10 am
I could put it on my ftp. If you are interested silvershadow, I can give you an ftp login. Once uploaded, it has a standard url for download.
User avatar
SketchUp Team
SketchUp Team
Postby majid » Fri Jul 24, 2009 8:16 pm
dear Silvercandy, if you don't bother let me know what is your machine property plz, and how much is the file size? does your machine works smooth with that file and doesn;t jump out or crashes?
User avatar
majid
Top SketchUcator
Postby smokinbakin » Fri Jul 24, 2009 10:24 pm
The detail on this model is simply insane!!!! If you actually textured the rest of that thing, you would definitely need to split it into a thousand layers.
"Set your goals low, and hope you don't get lower"
smokinbakin
Postby Khai » Mon Jul 27, 2009 6:07 pm
silver_shadow wrote:i bought this cool plugin, scene exporter, and this allowed me to set up a main model, and the made 3 separate files with portions of the model in.
what plugin was this? I use the same workflow in other apps so being able to do so in SU....
Khai
Postby silver_shadow » Tue Jul 28, 2009 5:50 am
majid wrote:dear Silvercandy, if you don't bother let me know what is your machine property plz, and how much is the file size? does your machine works smooth with that file and doesn;t jump out or crashes?
i got a pretty slow machine, dual core 3.4 with 2 gig ram and 8600 gt card.Windows 32 bit.
Im gonna upgrade the end of the year to a 8 core yay.
this plugin is a simple plugin you buy at http://www.smustard.com/script/PageExIm
I took my model with everything in it, set up the scenes i would like. Made 3 files for example, and copied the parts into that to make the model smaller. So then i have 3 files all containing parts of the model, and with this plugin i just import my scenes to them. Because its smaller file sizes and less detail, it can be rendered bigger in vray without crashing.
silver_shadow
Postby majid » Wed Jul 29, 2009 1:14 am
thanx for descriptions mate :)
User avatar
majid
Top SketchUcator
Postby pbacot » Wed Jul 29, 2009 5:39 am
Is it possible to see these images somewhere else? All I see here is icons saying "bandwidth exceeded".
Thanks, Peter
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby silver_shadow » Wed Jul 29, 2009 7:05 am
we are working on this issue, thanx for the notify.
silver_shadow
Postby Thunderaijin » Wed Jul 29, 2009 5:47 pm
Hello Silver_Shadow
I can not download your files, is there a problem due to your files?
Thunderaijin
Postby pbacot » Fri Aug 07, 2009 6:42 pm
These are now visible to me, and this deserves a bump! The modeling is incredible and all the images are just beautiful. Just as I expected, but still... congratulations and many thanks for posting, SS. I appreciate the background information and your opening comments.
Peter
User avatar
Top SketchUcator
Postby fymoro » Fri Aug 07, 2009 8:26 pm
Very amazing... :shock: How many mega is you file ? you must have a very stong computer to move and render everything, bravo :thumb:
fymoro
Postby notareal » Sat Aug 08, 2009 9:12 pm
Simply stunning work!
notareal
Thea Render Support
Thea Render Support
Postby Gaieus » Mon Aug 17, 2009 11:13 am
Hi Jacques,
Here is the current "official" 3D Challenge; Battleship. I know you won't do that but I guess if you participated, you'd have a good chance to win.
:D
User avatar
Postby rombout » Thu Sep 03, 2009 2:19 am
silver_shadow wrote:Tomorrow there will be more content to download :D
He silver shadow,
thanks for the tut about the model. But i'm very curious how you exactly made the texture for this one. Could you make a small tut about this??? :fro:
User avatar
rombout
Postby silver_shadow » Thu Sep 03, 2009 5:45 am
He silver shadow,
Hi there
How i made that hull texture. I exported the hull in 3ds format, imported it into cinema 4d. Created a UV map of the mesh, and saved the texture as a photoshop file. Opened it in photoshop, and start painting. As i paint and save, it updates in Cinema 4d. Once i was happy, i saved the photoshop file as a jpg. Exported the cinema 4d file back to 3ds mode and imported it into sketchup. Becasue i wanted a higher resolution texture, and to keep my sketchup file not to fall apart, i saved a low resolution of the texture, with a smaller pixel size say like 1025x1025 and replaced that on the model. When i render the final shot, i just went and in the Vray material section, add the original higher resolution texture to the diffuse tab and pressed render. There are different ways to approach this to uv map ect, but in that time, i thought that was not to too hard to do that and gave it a shot.
silver_shadow
Postby FlapsyD » Thu Sep 03, 2009 8:33 am
I've got just one thing to say: "I'm not worthy, I'm not worthy"
Meanwhile, I saw your other models too. This was actually the reason why I hesitated so long to post some of my own attempts on the forum (The blackhawk was my first encounter with your work). I was a little ashamed about the amateurism of my models.
Anyway, keep posting man. You're work is fantastic, mindblowing, ... (fill in your own superlative)
Flapsyd
FlapsyD
Postby pbacot » Fri Sep 04, 2009 4:07 pm
This is very enlightening. Many thanks to Jacques for creating this tutorial!
Now all I need is a tutorial on how to be a genius and I can model like that too.
User avatar
Top SketchUcator
Postby j3nsen » Fri Sep 04, 2009 11:09 pm
Ohh my good! I relay want your water to my models! The texture and.... everything looks realistic! Just got problems to make water like that, so it end with flat bad textured water...
Great work with the ship! Its not many users out in the world who models ships.
j3nsen
Postby publied » Mon Sep 21, 2009 6:27 am
simply phantastic.
publied
Postby Frodoro » Wed Sep 08, 2010 7:11 am
The prototype of this ship is definitely good and attractive to the eyes. I want to have this prototype. I can go to a plastic molding company to mold this model.
Frodoro
Postby sketchygal » Tue Feb 08, 2011 8:40 pm
Wow that ship is simply stunning. I hope to be able to get that good at modeling at some point in my life. So beautiful!
sketchygal
Postby sara135 » Mon Jul 11, 2011 2:32 pm
very interesting, even have no words :roll:
sara135
Postby Supreme Line » Wed Oct 12, 2011 2:43 pm
The Ship Is Amazing :sketchstatic:
Supreme Line
Postby iou » Wed Jun 13, 2018 10:32 am
Amazing modeling and rendering! :thumb: :thumb: :thumb:
iou
Postby Bryan K » Thu Jun 14, 2018 5:36 pm
Where has Silver Shadow gone?
User avatar
Postby HornOxx » Fri Jun 15, 2018 7:16 am
ely862me wrote::shock: :o i quit
:shock: I'll come with you :!: :!: :D
This is definitively a "Hall of Fame"-model !!!!
never trust a skinny cook
User avatar
HornOxx
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Gallery
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
